This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Vault 3.2.0!spring-doc.cn
New & Noteworthy
What’s new in Spring Vault 3.0
What’s new in Spring Vault 2.4
What’s new in Spring Vault 2.3
  • Support for PEM-encoded certificates for keystore and truststore usage.spring-doc.cn
  • ReactiveVaultEndpointProvider for non-blocking lookup of VaultEndpoint.spring-doc.cn
  • VaultKeyValueMetadataOperations for Key-Value metadata interaction.spring-doc.cn
  • Support for transform secrets engine (Enterprise Feature).spring-doc.cn
  • Documentation of how to use Vault secret backends.spring-doc.cn
  • Login credentials for Kubernetes and PCF authentication are reloaded for each login attempt.spring-doc.cn
  • SecretLeaseContainer publishes SecretLeaseRotatedEvent instead of SecretLeaseExpiredEvent and SecretLeaseCreatedEvent on successful secret rotation.spring-doc.cn
  • AbstractVaultConfiguration.threadPoolTaskScheduler() bean type changed to TaskSchedulerWrapper instead of ThreadPoolTaskScheduler.spring-doc.cn
  • Since 2.3.2: GcpIamCredentialsAuthenticationspring-doc.cn
What’s new in Spring Vault 2.2
  • Support for Key-Value v2 (versioned secrets engine) secrets through @VaultPropertySource.spring-doc.cn
  • SpEL support in @Secret.spring-doc.cn
  • Add support for Jetty as reactive HttpClient.spring-doc.cn
  • LifecycleAwareSessionManager and ReactiveLifecycleAwareSessionManager emit now AuthenticationEvents.spring-doc.cn
  • PCF Authentication.spring-doc.cn
  • Deprecation of AppIdAuthentication. Use AppRoleAuthentication instead as recommended by HashiCorp Vault.spring-doc.cn
  • CubbyholeAuthentication and wrapped AppRoleAuthentication now use sys/wrapping/unwrap endpoints by default.spring-doc.cn
  • Kotlin Coroutines support for ReactiveVaultOperations.spring-doc.cn
What’s new in Spring Vault 2.1
What’s new in Spring Vault 2.0
What’s new in Spring Vault 1.1.0
What’s new in Spring Vault 1.0
