This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Vault 3.2.0! |
Introduction to VaultTemplate
The class VaultTemplate
, located in the package org.springframework.vault.core
is the central class of the Spring’s Vault support providing a rich feature set to
interact with Vault. The template offers convenience operations to read, write and
delete data in Vault and provides a mapping between your domain objects and Vault data.
Once configured, VaultTemplate is thread-safe and can be reused across
multiple instances.
The mapping between Vault documents and domain classes is done by delegating to
RestTemplate
. Spring Web support provides the mapping infrastructure.
The VaultTemplate
class implements the interface
VaultOperations
In as much as possible, the methods on VaultOperations
are named after methods
available on the Vault API to make the API familiar to existing Vault developers
who are used to the API and CLI. For example, you will find methods such as
"write", "delete", "read", and "revoke".
The design goal was to make it as easy as possible to transition between
the use of the Vault API and VaultOperations
. A major difference in between
the two APIs is that VaultOperations
can be passed domain objects instead of
JSON Key-Value pairs.
The preferred way to reference the operations on VaultTemplate instance
is via its interface VaultOperations .
While there are many convenience methods on VaultTemplate
to help you easily
perform common tasks if you should need to access the Vault API directly to access
functionality not explicitly exposed by the VaultTemplate
you can use one of
several execute callback methods to access underlying APIs. The execute callbacks
will give you a reference to a RestOperations
object.
Please see the section Execution Callbacks for more information.
Now let’s look at a examples of how to work with Vault in the context of the Spring container.
Registering and configuring Spring Vault beans
Using Spring Vault does not require a Spring Context. However, instances of VaultTemplate
and
SessionManager
registered inside a managed context will participate
in lifecycle events
provided by the Spring IoC container. This is useful to dispose active Vault sessions upon
application shutdown. You also benefit from reusing the same VaultTemplate
instance across your application.
Spring Vault comes with a supporting configuration class that provides bean definitions
for use inside a Spring context. Application configuration
classes typically extend from AbstractVaultConfiguration
and are required to
provide additional details that are environment specific.
Extending from AbstractVaultConfiguration
requires to implement
VaultEndpoint vaultEndpoint()
and ClientAuthentication clientAuthentication()
methods.
public class AppConfig extends AbstractVaultConfiguration {
* Specify an endpoint for connecting to Vault.
public VaultEndpoint vaultEndpoint() {
return new VaultEndpoint(); (1)
* Configure a client authentication.
* Please consider a more secure authentication method
* for production use.
public ClientAuthentication clientAuthentication() {
return new TokenAuthentication("…"); (2)
1 | Create a new VaultEndpoint that points by default to https://localhost:8200 . |
2 | This sample uses TokenAuthentication to get started quickly.
See [vault.core.authentication] for details on supported authentication methods. |
@Value("${vault.uri}")
URI vaultUri;
* Specify an endpoint that was injected as URI.
return VaultEndpoint.from(vaultUri); (1)
* Configure a Client Certificate authentication.
* {@link RestOperations} can be obtained from {@link #restOperations()}.
return new ClientCertificateAuthentication(restOperations()); (2)
1 | VaultEndpoint can be constructed using various factory methods such as
from(URI uri) or VaultEndpoint.create(String host, int port) . |
2 | Dependencies for ClientAuthentication methods can be obtained either from
AbstractVaultConfiguration or provided by your configuration. |
Creating a custom configuration class might be cumbersome in some cases.
Take a look at EnvironmentVaultConfiguration that allows configuration by using
properties from existing property sources and Spring’s Environment . Read more
in Using EnvironmentVaultConfiguration .
Session Management
Spring Vault requires a ClientAuthentication
to login and access Vault.
See [vault.core.authentication] on details regarding authentication.
Vault login should not occur on each authenticated Vault interaction but
must be reused throughout a session. This aspect is handled by a
SessionManager
implementation. A SessionManager
decides how often it
obtains a token, about revocation and renewal. Spring Vault comes with two implementations:
SimpleSessionManager
: Just obtains tokens from the suppliedClientAuthentication
without refresh and revocation -
LifecycleAwareSessionManager
: ThisSessionManager
schedules token renewal if a token is renewable and revoke a login token on disposal. Renewal is scheduled with anAsyncTaskExecutor
.LifecycleAwareSessionManager
is configured by default if usingAbstractVaultConfiguration
Spring Vault includes EnvironmentVaultConfiguration
configure the Vault client from Spring’s Environment
and a set of predefined
property keys.
supports frequently applied configurations. Other configurations are supported by deriving from the most appropriate configuration class.
Include EnvironmentVaultConfiguration
with @Import(EnvironmentVaultConfiguration.class)
to existing
Java-based configuration classes and supply configuration properties through any of Spring’s PropertySource
s.
@PropertySource("vault.properties")
public class MyConfiguration{
vault.uri=https://localhost:8200
vault.token=00000000-0000-0000-0000-000000000000
Property keys
Vault URI:
vault.uri
SSL Configuration
Keystore resource:
vault.ssl.key-store
(optional) -
Keystore password:
vault.ssl.key-store-password
(optional) -
Keystore type:
vault.ssl.key-store-type
(optional, typicallyjks
, supports alsopem
Truststore resource:
vault.ssl.trust-store
(optional) -
Truststore password:
vault.ssl.trust-store-password
(optional) -
Truststore type:
vault.ssl.trust-store-type
, supports alsopem
Enabled SSL/TLS protocols:
vault.ssl.enabled-protocols
(since 2.3.2, optional, protocols separated with comma) -
Enabled SSL/TLS cipher suites:
vault.ssl.enabled-cipher-suites
(since 2.3.2, optional, cipher suites separated with comma)
Authentication method:
vault.authentication
(defaults toTOKEN
, supported authentication methods are:TOKEN
,APPID
,APPROLE
,AWS_EC2
,AWS_IAM
,AZURE
,CERT
,CUBBYHOLE
,KUBERNETES
Authentication-specific property keys
Vault Token:
vault.token
AppId path:
vault.app-id.app-id-path
(defaults toapp-id
AppId:
vault.app-id.app-id
UserId:
vault.app-id.user-id
.MAC_ADDRESS
andIP_ADDRESS
useMacAddressUserId
, respectiveIpAddressUserId
user id mechanisms. Any other value is used withStaticUserId
AppRole path:
vault.app-role.app-role-path
(defaults toapprole
RoleId:
vault.app-role.role-id
SecretId:
vault.app-role.secret-id
(optional)
AWS EC2 path:
vault.aws-ec2.aws-ec2-path
(defaults toaws-ec2
Role:
vault.aws-ec2.role
RoleId:
vault.aws-ec2.role-id
(deprecated: usevault.aws-ec2.role
instead) -
Identity Document URL:
vault.aws-ec2.identity-document
(defaults to169.254.169.254/latest/dynamic/instance-identity/pkcs7
Role:
vault.aws-iam.role
Azure MSI path:
vault.azure-msi.azure-path
(defaults toazure
Role:
vault.azure-msi.role
Metadata Service URL:
vault.azure-msi.metadata-service
(defaults to169.254.169.254/metadata/instance?api-version=2017-08-01
Identity TokenService URL:
vault.azure-msi.identity-token-service
(defaults to169.254.169.254/metadata/identity/oauth2/token?resource=https://vault.hashicorp.com&api-version=2018-02-01
No configuration options.
Initial Vault Token:
vault.token
Kubernetes path:
vault.kubernetes.kubernetes-path
(defaults tokubernetes
Role:
vault.kubernetes.role
Path to service account token file:
vault.kubernetes.service-account-token-file
(defaults to/var/run/secrets/kubernetes.io/serviceaccount/token
Execution callbacks
One common design feature of all Spring template classes is that all functionality is routed into one of the templates execute callback methods.
This helps ensure that exceptions and any resource management that maybe required are performed consistency.
While this was of much greater need in the case of JDBC and JMS than with Vault, it still offers a single spot for access and logging to occur.
As such, using the execute callback is the preferred way to access the Vault API
to perform uncommon operations that we’ve not exposed as methods on VaultTemplate
Here is a list of execute callback methods.
<T> T
doWithVault(RestOperationsCallback<T> callback)
Executes the givenRestOperationsCallback
, allows to interact with Vault usingRestOperations
without requiring a session. -
<T> T
doWithSession(RestOperationsCallback<T> callback)
, allows to interact with Vault in an authenticated session.
Here is an example that uses the ClientCallback
to initialize Vault:
vaultOperations.doWithVault(new RestOperationsCallback<VaultInitializationResponse>() {
public VaultInitializationResponse doWithRestOperations(RestOperations restOperations) {
ResponseEntity<VaultInitializationResponse> exchange = restOperations
.exchange("/sys/init", HttpMethod.PUT,
new HttpEntity<Object>(request),
VaultInitializationResponse.class);
return exchange.getBody();
