This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Single Command
If your shell application is made for exactly a single purpose having only one command it may be beneficial to configure it for this. Property spring.shell.noninteractive.primary-command if defined will disable all other runners than NonInteractiveShellRunner and configures it to use defined Primary Command.spring-doc.cn
spring:
  shell:
    noninteractive:
      primary-command: mycommand
For example if you have a command mycommand with option arg it had to be executed with <shellapp> mycommand --arg hi, but with above setting it can be executed with <shellapp> --arg hi.spring-doc.cn
