This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
History
The history command shows the history of commands that has been executed.spring-doc.cn
There are a few configuration options that you can use to configure behavior of a history. History is kept in a log file, which is enabled by default and can be turned off by setting spring.shell.history.enabled. The name of a log file is resolved from spring.application.name and defaults to spring-shell.log, which you can change by setting spring.shell.history.name.spring-doc.cn
By default, a log file is generated to a current working directory, which you can dictate by setting spring.shell.config.location. This property can contain a placeholder ({userconfig}), which resolves to a common shared config directory.spring-doc.cn
Run the Spring Shell application to see how the sample application works as it uses these options.
