For the latest stable version, please use Spring Session 3.5.0!spring-doc.cn
Redis Configurations
Now that you have your application configured, you might want to start customizing things:spring-doc.cn
Serializing the Session using JSON
By default, Spring Session uses Java Serialization to serialize the session attributes. Sometimes it might be problematic, especially when you have multiple applications that use the same Redis instance but have different versions of the same class. You can provide a RedisSerializer bean to customize how the session is serialized into Redis. Spring Data Redis provides the GenericJackson2JsonRedisSerializer that serializes and deserializes objects using Jackson’s ObjectMapper.spring-doc.cn
Configuring the RedisSerializer
public class SessionConfig implements BeanClassLoaderAware {
	private ClassLoader loader;
	 * Note that the bean name for this bean is intentionally
	 * {@code springSessionDefaultRedisSerializer}. It must be named this way to override
	 * the default {@link RedisSerializer} used by Spring Session.
	public RedisSerializer<Object> springSessionDefaultRedisSerializer() {
		return new GenericJackson2JsonRedisSerializer(objectMapper());
	 * Customized {@link ObjectMapper} to add mix-in for class that doesn't have default
	 * constructors
	 * @return the {@link ObjectMapper} to use
	private ObjectMapper objectMapper() {
		ObjectMapper mapper = new ObjectMapper();
		mapper.registerModules(SecurityJackson2Modules.getModules(this.loader));
		return mapper;
	 * @see
	 * org.springframework.beans.factory.BeanClassLoaderAware#setBeanClassLoader(java.lang
	 * .ClassLoader)
	public void setBeanClassLoader(ClassLoader classLoader) {
		this.loader = classLoader;
The above code snippet is using Spring Security, therefore we are creating a custom ObjectMapper that uses Spring Security’s Jackson modules. If you do not need Spring Security Jackson modules, you can inject your application’s ObjectMapper bean and use it like so:spring-doc.cn
public RedisSerializer<Object> springSessionDefaultRedisSerializer(ObjectMapper objectMapper) {
    return new GenericJackson2JsonRedisSerializer(objectMapper);
Specifying a Different Namespace
It is not uncommon to have multiple applications that use the same Redis instance. For that reason, Spring Session uses a namespace (defaults to spring:session) to keep the session data separated if needed.spring-doc.cn
Using Spring Boot Properties
You can specify it by setting the spring.session.redis.namespace property.spring-doc.cn
application.properties
spring.session.redis.namespace=spring:session:myapplication
application.yml
spring:
  session:
    redis:
      namespace: "spring:session:myapplication"
Using the Annotation’s Attributes
You can specify the namespace by setting the redisNamespace property in the @EnableRedisHttpSession, @EnableRedisIndexedHttpSession, or @EnableRedisWebSession annotations:spring-doc.cn
@EnableRedisHttpSession(redisNamespace = "spring:session:myapplication")
public class SessionConfig {
@EnableRedisIndexedHttpSession(redisNamespace = "spring:session:myapplication")
@EnableRedisWebSession(redisNamespace = "spring:session:myapplication")
Choosing Between RedisSessionRepository and RedisIndexedSessionRepository
When working with Spring Session Redis, you will likely have to choose between the RedisSessionRepository and the RedisIndexedSessionRepository. Both are implementations of the SessionRepository interface that store session data in Redis. However, they differ in how they handle session indexing and querying.spring-doc.cn
  • RedisSessionRepository: RedisSessionRepository is a basic implementation that stores session data in Redis without any additional indexing. It uses a simple key-value structure to store session attributes. Each session is assigned a unique session ID, and the session data is stored under a Redis key associated with that ID. When a session needs to be retrieved, the repository queries Redis using the session ID to fetch the associated session data. Since there is no indexing, querying sessions based on attributes or criteria other than the session ID can be inefficient.spring-doc.cn
  • RedisIndexedSessionRepository: RedisIndexedSessionRepository is an extended implementation that provides indexing capabilities for sessions stored in Redis. It introduces additional data structures in Redis to efficiently query sessions based on attributes or criteria. In addition to the key-value structure used by RedisSessionRepository, it maintains additional indexes to enable fast lookups. For example, it may create indexes based on session attributes like user ID or last access time. These indexes allow for efficient querying of sessions based on specific criteria, enhancing performance and enabling advanced session management features. In addition to that, RedisIndexedSessionRepository also supports session expiration and deletion.spring-doc.cn
When using RedisIndexedSessionRepository with Redis Cluster you must be aware that it only subscribe to events from one random redis node in the cluster, which can cause some session indexes not being cleaned up if the event happened in a different node.
Configuring the RedisSessionRepository
If you are using Spring Boot, the RedisSessionRepository is the default implementation. However, if you want to be explicit about it, you can set the following property in your application:spring-doc.cn
spring.session.redis.repository-type=default
application.yml
spring:
  session:
    redis:
      repository-type: default
Using Annotations
You can configure the RedisSessionRepository by using the @EnableRedisHttpSession annotation:spring-doc.cn
Configuring the RedisIndexedSessionRepository
You can configure the RedisIndexedSessionRepository by setting the following properties in your application:spring-doc.cn
spring.session.redis.repository-type=indexed
application.yml
spring:
  session:
    redis:
      repository-type: indexed
Using Annotations
You can configure the RedisIndexedSessionRepository by using the @EnableRedisIndexedHttpSession annotation:spring-doc.cn
Listening to Session Events
Often times it is valuable to react to session events, for example, you might want to do some kind of processing depending on the session lifecycle. In order to be able to do that, you must be using the indexed repository. If you do not know the difference between the indexed and the default repository, you can go to this section.spring-doc.cn
With the indexed repository configured, you can now start to listen to SessionCreatedEvent, SessionDeletedEvent, SessionDestroyedEvent and SessionExpiredEvent events. There are a few ways to listen to application events in Spring, we are going to use the @EventListener annotation.spring-doc.cn
@Component
public class SessionEventListener {
    @EventListener
    public void processSessionCreatedEvent(SessionCreatedEvent event) {
        // do the necessary work
    @EventListener
    public void processSessionDeletedEvent(SessionDeletedEvent event) {
    @EventListener
    public void processSessionDestroyedEvent(SessionDestroyedEvent event) {
    @EventListener
    public void processSessionExpiredEvent(SessionExpiredEvent event) {
Finding All Sessions of a Specific User
By retrieving all sessions of a specific user, you can track the user’s active sessions across devices or browsers. For example, you can use this information session management purposes, such as allowing the user to invalidate or logout from specific sessions or performing actions based on the user’s session activity.spring-doc.cn
To do that, first you must be using the indexed repository, and then you can inject the FindByIndexNameSessionRepository interface, like so:spring-doc.cn
@Autowired
public FindByIndexNameSessionRepository<? extends Session> sessions;
public Collection<? extends Session> getSessions(Principal principal) {
    Collection<? extends Session> usersSessions = this.sessions.findByPrincipalName(principal.getName()).values();
    return usersSessions;
public void removeSession(Principal principal, String sessionIdToDelete) {
    Set<String> usersSessionIds = this.sessions.findByPrincipalName(principal.getName()).keySet();
    if (usersSessionIds.contains(sessionIdToDelete)) {
        this.sessions.deleteById(sessionIdToDelete);
In the example above, you can use the getSessions method to find all sessions of a specific user, and the removeSession method to remove a specific session of a user.spring-doc.cn
Configuring Redis Session Mapper
Spring Session Redis retrieves session information from Redis and stores it in a Map<String, Object>. This map needs to undergo a mapping process to be transformed into a MapSession object, which is then utilized within RedisSession.spring-doc.cn
The default mapper used for this purpose is called RedisSessionMapper. If the session map doesn’t contain the minimum necessary keys to construct the session, like creationTime, this mapper will throw an exception. One possible scenario for the absence of required keys is when the session key is deleted concurrently, usually due to expiration, while the save process is in progress. This occurs because the HSET command is employed to set fields within the key, and if the key doesn’t exist, this command will create it.spring-doc.cn
If you want to customize the mapping process, you can create your implementation of BiFunction<String, Map<String, Object>, MapSession> and set it into the session repository. The following example shows how to delegate the mapping process to the default mapper, but if an exception is thrown, the session is deleted from Redis:spring-doc.cn
    SessionRepositoryCustomizer<RedisSessionRepository> redisSessionRepositoryCustomizer() {
        return (redisSessionRepository) -> redisSessionRepository
                .setRedisSessionMapper(new SafeRedisSessionMapper(redisSessionRepository));
    static class SafeRedisSessionMapper implements BiFunction<String, Map<String, Object>, MapSession> {
        private final RedisSessionMapper delegate = new RedisSessionMapper();
        private final RedisSessionRepository sessionRepository;
        SafeRedisSessionMapper(RedisSessionRepository sessionRepository) {
            this.sessionRepository = sessionRepository;
        public MapSession apply(String sessionId, Map<String, Object> map) {
            try {
                return this.delegate.apply(sessionId, map);
            catch (IllegalStateException ex) {
                this.sessionRepository.deleteById(sessionId);
                return null;
    SessionRepositoryCustomizer<RedisIndexedSessionRepository> redisSessionRepositoryCustomizer() {
        return (redisSessionRepository) -> redisSessionRepository.setRedisSessionMapper(
                new SafeRedisSessionMapper(redisSessionRepository.getSessionRedisOperations()));
        private final RedisOperations<String, Object> redisOperations;
        SafeRedisSessionMapper(RedisOperations<String, Object> redisOperations) {
            this.redisOperations = redisOperations;
            try {
                // if you use a different redis namespace, change the key accordingly
                this.redisOperations.delete("spring:session:sessions:" + sessionId); // we do not invoke RedisIndexedSessionRepository#deleteById to avoid an infinite loop because the method also invokes this mapper
                return null;
    ReactiveSessionRepositoryCustomizer<ReactiveRedisSessionRepository> redisSessionRepositoryCustomizer() {
    static class SafeRedisSessionMapper implements BiFunction<String, Map<String, Object>, Mono<MapSession>> {
        private final ReactiveRedisSessionRepository sessionRepository;
        SafeRedisSessionMapper(ReactiveRedisSessionRepository sessionRepository) {
        public Mono<MapSession> apply(String sessionId, Map<String, Object> map) {
            return Mono.fromSupplier(() -> this.delegate.apply(sessionId, map))
                .onErrorResume(IllegalStateException.class,
                    (ex) -> this.sessionRepository.deleteById(sessionId).then(Mono.empty()));
