For the latest stable version, please use Spring Session 3.5.0! |
Reactive Redis Indexed Configurations
To start using the Redis Indexed Web Session support, you need to add the following dependency to your project:
Maven
Gradle
<dependency>
<artifactId>spring-session-data-redis</artifactId>
</dependency>
implementation 'org.springframework.session:spring-session-data-redis'
And add the @EnableRedisIndexedWebSession
annotation to a configuration class:
public class SessionConfig {
That is it. Your application now has a reactive Redis backed Indexed Web Session support. Now that you have your application configured, you might want to start customizing things:
I want to serialize the session using JSON.
I want to specify a different namespace for keys used by Spring Session.
I want to know how Spring Session cleans up expired sessions.
I want to change the frequency of the session cleanup.
I want to take control over the cleanup task.
I want to listen to session events.
Serializing the Session using JSON
By default, Spring Session Data Redis uses Java Serialization to serialize the session attributes.
Sometimes it might be problematic, especially when you have multiple applications that use the same Redis instance but have different versions of the same class.
You can provide a RedisSerializer
bean to customize how the session is serialized into Redis.
Spring Data Redis provides the GenericJackson2JsonRedisSerializer
that serializes and deserializes objects using Jackson’s ObjectMapper
public class SessionConfig implements BeanClassLoaderAware {
private ClassLoader loader;
* Note that the bean name for this bean is intentionally
* {@code springSessionDefaultRedisSerializer}. It must be named this way to override
* the default {@link RedisSerializer} used by Spring Session.
public RedisSerializer<Object> springSessionDefaultRedisSerializer() {
return new GenericJackson2JsonRedisSerializer(objectMapper());
* Customized {@link ObjectMapper} to add mix-in for class that doesn't have default
* constructors
* @return the {@link ObjectMapper} to use
private ObjectMapper objectMapper() {
ObjectMapper mapper = new ObjectMapper();
mapper.registerModules(SecurityJackson2Modules.getModules(this.loader));
return mapper;
* @see
* org.springframework.beans.factory.BeanClassLoaderAware#setBeanClassLoader(java.lang
* .ClassLoader)
public void setBeanClassLoader(ClassLoader classLoader) {
this.loader = classLoader;
The above code snippet is using Spring Security, therefore we are creating a custom ObjectMapper
that uses Spring Security’s Jackson modules.
If you do not need Spring Security Jackson modules, you can inject your application’s ObjectMapper
bean and use it like so:
public RedisSerializer<Object> springSessionDefaultRedisSerializer(ObjectMapper objectMapper) {
return new GenericJackson2JsonRedisSerializer(objectMapper);
The |
Specifying a Different Namespace
It is not uncommon to have multiple applications that use the same Redis instance or to want to keep the session data separated from other data stored in Redis.
For that reason, Spring Session uses a namespace
(defaults to spring:session
) to keep the session data separated if needed.
You can specify the namespace
by setting the redisNamespace
property in the @EnableRedisIndexedWebSession
annotation:
@EnableRedisIndexedWebSession(redisNamespace = "spring:session:myapplication")
Understanding How Spring Session Cleans Up Expired Sessions
Spring Session relies on Redis Keyspace Events to clean up expired sessions.
More specifically, it listens to events emitted to the __keyevent@*__:expired
and __keyevent@*__:del
channels and resolve the session id based on the key that was destroyed.
As an example, let’s imagine that we have a session with id 1234
and that the session is set to expire in 30 minutes.
When the expiration time is reached, Redis will emit an event to the __keyevent@*__:expired
channel with the message spring:session:sessions:expires:1234
which is the key that expired.
Spring Session will then resolve the session id (1234
) from the key and delete all the related session keys from Redis.
One problem with relying on Redis expiration exclusively is that Redis makes no guarantee of when the expired event will be fired if the key has not been accessed. For additional details see How Redis expires keys in the Redis documentation. To circumvent the fact that expired events are not guaranteed to happen we can ensure that each key is accessed when it is expected to expire. This means that if the TTL is expired on the key, Redis will remove the key and fire the expired event when we try to access the key. For this reason, each session expiration is also tracked by storing the session id in a sorted set ranked by its expiration time. This allows a background task to access the potentially expired sessions to ensure that Redis expired events are fired in a more deterministic fashion. For example:
ZADD spring:session:sessions:expirations "1.702402961162E12" "648377f7-c76f-4f45-b847-c0268bb48381"
We do not explicitly delete the keys since in some instances there may be a race condition that incorrectly identifies a key as expired when it is not. Short of using distributed locks (which would kill our performance) there is no way to ensure the consistency of the expiration mapping. By simply accessing the key, we ensure that the key is only removed if the TTL on that key is expired.
By default, Spring Session will retrieve up to 100 expired sessions every 60 seconds. If you want to configure how often the cleanup task runs, please refer to the Changing the Frequency of the Session Cleanup section.
Configuring Redis to Send Keyspace Events
By default, Spring Session tries to configure Redis to send keyspace events using the ConfigureNotifyKeyspaceEventsReactiveAction
which, in turn, might set the notify-keyspace-events
configuration property to Egx
However, this strategy will not work if the Redis instance has been properly secured.
In that case, the Redis instance should be configured externally and a Bean of type ConfigureReactiveRedisAction.NO_OP
should be exposed to disable the autoconfiguration.
public ConfigureReactiveRedisAction configureReactiveRedisAction() {
return ConfigureReactiveRedisAction.NO_OP;
Depending on your application’s needs, you might want to change the frequency of the session cleanup.
To do that, you can expose a ReactiveSessionRepositoryCustomizer<ReactiveRedisIndexedSessionRepository>
bean and set the cleanupInterval
property:
public ReactiveSessionRepositoryCustomizer<ReactiveRedisIndexedSessionRepository> reactiveSessionRepositoryCustomizer() {
return (sessionRepository) -> sessionRepository.setCleanupInterval(Duration.ofSeconds(30));
You can also set invoke disableCleanupTask()
to disable the cleanup task.
return (sessionRepository) -> sessionRepository.disableCleanupTask();
Taking Control Over the Cleanup Task
Sometimes, the default cleanup task might not be enough for your application’s needs.
You might want to adopt a different strategy to clean up expired sessions.
Since you know that the session ids are stored in a sorted set under the key spring:session:sessions:expirations
and ranked by their expiration time, you can disable the default cleanup task and provide your own strategy.
For example:
@Component
public class SessionEvicter {
private ReactiveRedisOperations<String, String> redisOperations;
@Scheduled
public Mono<Void> cleanup() {
Instant now = Instant.now();
Instant oneMinuteAgo = now.minus(Duration.ofMinutes(1));
Range<Double> range = Range.closed((double) oneMinuteAgo.toEpochMilli(), (double) now.toEpochMilli());
Limit limit = Limit.limit().count(1000);
return this.redisOperations.opsForZSet().reverseRangeByScore("spring:session:sessions:expirations", range, limit)
// do something with the session ids
.then();
Listening to Session Events
Often times it is valuable to react to session events, for example, you might want to do some kind of processing depending on the session lifecycle.
You configure your application to listen to SessionCreatedEvent
, SessionDeletedEvent
and SessionExpiredEvent
events.
There are a few ways to listen to application events in Spring, for this example we are going to use the @EventListener
annotation.
@Component
public class SessionEventListener {
@EventListener
public Mono<Void> processSessionCreatedEvent(SessionCreatedEvent event) {
// do the necessary work
@EventListener
public Mono<Void> processSessionDeletedEvent(SessionDeletedEvent event) {
@EventListener
public Mono<Void> processSessionExpiredEvent(SessionExpiredEvent event) {
