For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
DaoAuthenticationProvider
DaoAuthenticationProvider is an AuthenticationProvider implementation that uses a UserDetailsService and PasswordEncoder to authenticate a username and password.spring-doc.cn
This section examines how DaoAuthenticationProvider works within Spring Security. The following figure explains the workings of the AuthenticationManager in figures from the Reading the Username & Password section.spring-doc.cn
daoauthenticationprovider
Figure 1. DaoAuthenticationProvider Usage
number 1 The authentication Filter from the Reading the Username & Password section passes a UsernamePasswordAuthenticationToken to the AuthenticationManager, which is implemented by ProviderManager.spring-doc.cn
number 2 The ProviderManager is configured to use an AuthenticationProvider of type DaoAuthenticationProvider.spring-doc.cn
number 3 DaoAuthenticationProvider looks up the UserDetails from the UserDetailsService.spring-doc.cn
number 4 DaoAuthenticationProvider uses the PasswordEncoder to validate the password on the UserDetails returned in the previous step.spring-doc.cn
number 5 When authentication is successful, the Authentication that is returned is of type UsernamePasswordAuthenticationToken and has a principal that is the UserDetails returned by the configured UserDetailsService. Ultimately, the returned UsernamePasswordAuthenticationToken is set on the SecurityContextHolder by the authentication Filter.spring-doc.cn
