For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Authorization Events
For each authorization that is denied, an AuthorizationDeniedEvent is fired. Also, it’s possible to fire an AuthorizationGrantedEvent for authorizations that are granted.spring-doc.cn
To listen for these events, you must first publish an AuthorizationEventPublisher.spring-doc.cn
Spring Security’s SpringAuthorizationEventPublisher will probably do fine. It comes publishes authorization events using Spring’s ApplicationEventPublisher:spring-doc.cn
public AuthorizationEventPublisher authorizationEventPublisher
        (ApplicationEventPublisher applicationEventPublisher) {
    return new SpringAuthorizationEventPublisher(applicationEventPublisher);
fun authorizationEventPublisher
        (applicationEventPublisher: ApplicationEventPublisher?): AuthorizationEventPublisher {
    return SpringAuthorizationEventPublisher(applicationEventPublisher)
Then, you can use Spring’s @EventListener support:spring-doc.cn
@Component
public class AuthenticationEvents {
    @EventListener
    public void onFailure(AuthorizationDeniedEvent failure) {
@Component
    @EventListener
    fun onFailure(failure: AuthorizationDeniedEvent?) {
Authorization Granted Events
Because AuthorizationGrantedEvents have the potential to be quite noisy, they are not published by default.spring-doc.cn
In fact, publishing these events will likely require some business logic on your part to ensure that your application is not inundated with noisy authorization events.spring-doc.cn
You can create your own event publisher that filters success events. For example, the following publisher only publishes authorization grants where ROLE_ADMIN was required:spring-doc.cn
@Component
public class MyAuthorizationEventPublisher implements AuthorizationEventPublisher {
    private final ApplicationEventPublisher publisher;
    private final AuthorizationEventPublisher delegate;
    public MyAuthorizationEventPublisher(ApplicationEventPublisher publisher) {
        this.publisher = publisher;
        this.delegate = new SpringAuthorizationEventPublisher(publisher);
    public <T> void publishAuthorizationEvent(Supplier<Authentication> authentication,
            T object, AuthorizationDecision decision) {
        if (decision == null) {
            return;
        if (!decision.isGranted()) {
            this.delegate.publishAuthorizationEvent(authentication, object, decision);
            return;
        if (shouldThisEventBePublished(decision)) {
            AuthorizationGrantedEvent granted = new AuthorizationGrantedEvent(
            this.publisher.publishEvent(granted);
    private boolean shouldThisEventBePublished(AuthorizationDecision decision) {
        if (!(decision instanceof AuthorityAuthorizationDecision)) {
            return false;
        Collection<GrantedAuthority> authorities = ((AuthorityAuthorizationDecision) decision).getAuthorities();
        for (GrantedAuthority authority : authorities) {
            if ("ROLE_ADMIN".equals(authority.getAuthority())) {
                return true;
        return false;
@Component
class MyAuthorizationEventPublisher(val publisher: ApplicationEventPublisher,
    val delegate: SpringAuthorizationEventPublisher = SpringAuthorizationEventPublisher(publisher)):
    override fun <T : Any?> publishAuthorizationEvent(
        authentication: Supplier<Authentication>?,
        `object`: T,
        decision: AuthorizationDecision?
            return
        if (!decision.isGranted) {
            this.delegate.publishAuthorizationEvent(authentication, `object`, decision)
            return
            val granted = AuthorizationGrantedEvent(authentication, `object`, decision)
    private fun shouldThisEventBePublished(decision: AuthorizationDecision): Boolean {
        if (decision !is AuthorityAuthorizationDecision) {
            return false
        val authorities = decision.authorities
        for (authority in authorities) {
            if ("ROLE_ADMIN" == authority.authority) {
                return true
        return false
