For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
CORS
Spring Framework provides first class support for CORS. CORS must be processed before Spring Security, because the pre-flight request does not contain any cookies (that is, the JSESSIONID). If the request does not contain any cookies and Spring Security is first, the request determines that the user is not authenticated (since there are no cookies in the request) and rejects it.spring-doc.cn
The easiest way to ensure that CORS is handled first is to use the CorsFilter. Users can integrate the CorsFilter with Spring Security by providing a CorsConfigurationSource. Note that Spring Security will automatically configure CORS only if a UrlBasedCorsConfigurationSource instance is present. For example, the following will integrate CORS support within Spring Security:spring-doc.cn
UrlBasedCorsConfigurationSource corsConfigurationSource() {
    CorsConfiguration configuration = new CorsConfiguration();
    configuration.setAllowedOrigins(Arrays.asList("https://example.com"));
    configuration.setAllowedMethods(Arrays.asList("GET","POST"));
    UrlBasedCorsConfigurationSource source = new UrlBasedCorsConfigurationSource();
    source.registerCorsConfiguration("/**", configuration);
    return source;
fun corsConfigurationSource(): UrlBasedCorsConfigurationSource {
    val configuration = CorsConfiguration()
    configuration.allowedOrigins = listOf("https://example.com")
    configuration.allowedMethods = listOf("GET", "POST")
    val source = UrlBasedCorsConfigurationSource()
    return source
The following listing does the same thing in XML:spring-doc.cn
<http>
	<cors configuration-source-ref="corsSource"/>
</http>
<b:bean id="corsSource" class="org.springframework.web.cors.UrlBasedCorsConfigurationSource">
</b:bean>
If you use Spring MVC’s CORS support, you can omit specifying the CorsConfigurationSource and Spring Security uses the CORS configuration provided to Spring MVC:spring-doc.cn
@EnableWebSecurity
public class WebSecurityConfig {
		http
			// if Spring MVC is on classpath and no CorsConfigurationSource is provided,
			// Spring Security will use CORS configuration provided to Spring MVC
			.cors(withDefaults())
		return http.build();
@EnableWebSecurity
open class WebSecurityConfig {
        http {
            cors { }
        return http.build()
<http>
	<!-- Default to Spring MVC's CORS configuration -->
	<cors />
</http>
If you have more than one CorsConfigurationSource bean, Spring Security won’t automatically configure CORS support for you, that is because it cannot decide which one to use. If you want to specify different CorsConfigurationSource for each SecurityFilterChain, you can pass it directly into the .cors() DSL.spring-doc.cn
@EnableWebSecurity
	@Order(0)
	public SecurityFilterChain apiFilterChain(HttpSecurity http) throws Exception {
		http
			.securityMatcher("/api/**")
			.cors((cors) -> cors
				.configurationSource(apiConfigurationSource())
	@Order(1)
	public SecurityFilterChain myOtherFilterChain(HttpSecurity http) throws Exception {
		http
				.configurationSource(myWebsiteConfigurationSource())
	UrlBasedCorsConfigurationSource apiConfigurationSource() {
		configuration.setAllowedOrigins(Arrays.asList("https://api.example.com"));
		return source;
	UrlBasedCorsConfigurationSource myWebsiteConfigurationSource() {
		return source;
    return source
