This version is still in development and is not considered stable yet. For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
What’s new?
What’s New in 3.3 Since 3.2
This section covers the changes made from version 3.2 to version 3.3. For changes in earlier version, see Change History.
DLT Topic Naming Convention
The naming convention for DLT topics has been standardized to use the "-dlt" suffix consistently. This change ensures compatibility and avoids conflicts when transitioning between different retry solutions. Users who wish to retain the ".DLT" suffix behavior need to opt-in explicitly by setting the appropriate DLT name property.
Enhanced Seek Operations for Consumer Groups
A new method, getGroupId()
, has been added to the ConsumerSeekCallback
interface.
This method allows for more selective seek operations by targeting only the desired consumer group.
The AbstractConsumerSeekAware
can also now register, retrieve, and remove all callbacks for each topic partition in a multi-group listener scenario without missing any.
See the new APIs (getSeekCallbacksFor(TopicPartition topicPartition)
, getTopicsAndCallbacks()
) for more details.
For more details, see Seek API Docs.
Configurable Handling of Empty Batches in Kafka Listener with RecordFilterStrategy
now supports ignoring empty batches that result from filtering.
This can be configured through overriding default method ignoreEmptyBatch()
, which defaults to false, ensuring KafkaListener
is invoked even if all ConsumerRecords
are filtered out.
For more details, see Message receive filtering Docs.
ConcurrentContainerStoppedEvent
The ConcurentContainerMessageListenerContainer
emits now a ConcurrentContainerStoppedEvent
when all of its child containers are stopped.
For more details, see Application Events and ConcurrentContainerStoppedEvent
Javadocs.
Original Record Key in Reply
When using ReplyingKafkaTemplate
, if the original record from the request contains a key, then that same key will be part of the reply as well.
For more details, see Sending Messages section of the reference docs.
Customizing Logging in DeadLetterPublishingRecovererFactory
When using DeadLetterPublishingRecovererFactory
, the user applications can override the maybeLogListenerException
method to customize the logging behavior.
Customize Admin client in KafkaAdmin
When extending KafkaAdmin
, user applications may override the createAdmin
method to customize Admin client creation.
Customizing The Implementation of Kafka Streams
When using KafkaStreamsCustomizer
it is now possible to return a custom implementation of the KafkaStreams
object by overriding the initKafkaStreams
method.
KafkaHeaders.DELIVERY_ATTEMPT for batch listeners
When using a BatchListener
, the ConsumerRecord
can have the KafkaHeaders.DELIVERY_ATTMPT
header in its headers fields.
If the DeliveryAttemptAwareRetryListener
is set to error handler as retry listener, each ConsumerRecord
has delivery attempt header.
For more details, see Kafka Headers for Batch Listener.
Kafka Metrics Listeners and TaskScheduler
The MicrometerProducerListener
, MicrometerConsumerListener
and KafkaStreamsMicrometerListener
can now be configured with a TaskScheduler
See KafkaMetricsSupport
JavaDocs and Micrometer Support for more information.
