This version is still in development and is not considered stable yet. For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
Container Thread Naming
A TaskExecutor
is used to invoke the consumer and the listener.
You can provide a custom executor by setting the consumerExecutor
property of the container’s ContainerProperties
When using pooled executors, be sure that enough threads are available to handle the concurrency across all the containers in which they are used.
When using the ConcurrentMessageListenerContainer
, a thread from the executor is used for each consumer (concurrency
If you do not provide a consumer executor, a SimpleAsyncTaskExecutor
is used for each container.
This executor creates threads with names similar to <beanName>-C-<n>
For the ConcurrentMessageListenerContainer
, the <beanName>
part of the thread name becomes <beanName>-m
, where m
represents the consumer instance.
n
increments each time the container is started.
So, with a bean name of container
, threads in this container will be named container-0-C-1
, container-1-C-1
etc., after the container is started the first time; container-0-C-2
, container-1-C-2
etc., after a stop and subsequent start.
Starting with version 3.0.1
, you can now change the name of the thread, regardless of which executor is used.
Set the AbstractMessageListenerContainer.changeConsumerThreadName
property to true
and the AbstractMessageListenerContainer.threadNameSupplier
will be invoked to obtain the thread name.
This is a Function<MessageListenerContainer, String>
, with the default implementation returning container.getListenerId()
