This version is still in development and is not considered stable yet. For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
Changing KafkaBackOffException Logging Level
When a message in the retry topic is not due for consumption, a KafkaBackOffException
is thrown.
Such exceptions are logged by default at DEBUG
level, but you can change this behavior by setting an error handler customizer in the ListenerContainerFactoryConfigurer
in a @Configuration
class.
For example, to change the logging level to WARN you might add:
protected void configureCustomizers(CustomizersConfigurer customizersConfigurer) {
customizersConfigurer.customizeErrorHandler(defaultErrorHandler ->
defaultErrorHandler.setLogLevel(KafkaException.Level.WARN))
