@KafkaListener as a Meta Annotation
Starting with version 2.2, you can now use @KafkaListener as a meta annotation. The following example shows how to do so:spring-doc.cn
@Target(ElementType.METHOD)
@KafkaListener
public @interface MyThreeConsumersListener {
    @AliasFor(annotation = KafkaListener.class, attribute = "id")
    String id();
    @AliasFor(annotation = KafkaListener.class, attribute = "topics")
    String[] topics();
    @AliasFor(annotation = KafkaListener.class, attribute = "concurrency")
    String concurrency() default "3";
You must alias at least one of topics, topicPattern, or topicPartitions (and, usually, id or groupId unless you have specified a group.id in the consumer factory configuration). The following example shows how to do so:spring-doc.cn
@MyThreeConsumersListener(id = "my.group", topics = "my.topic")
public void listen1(String in) {
