Dynamically Creating Containers
There are several techniques that can be used to create listener containers at runtime. This section explores some of those techniques.spring-doc.cn
MessageListener Implementations
If you implement your own listener directly, you can simply use the container factory to create a raw container for that listener:spring-doc.cn
User Listener
public class MyListener implements MessageListener<String, String> {
    public void onMessage(ConsumerRecord<String, String> data) {
private ConcurrentMessageListenerContainer<String, String> createContainer(
        ConcurrentKafkaListenerContainerFactory<String, String> factory, String topic, String group) {
    ConcurrentMessageListenerContainer<String, String> container = factory.createContainer(topic);
    container.getContainerProperties().setMessageListener(new MyListener());
    container.getContainerProperties().setGroupId(group);
    container.setBeanName(group);
    container.start();
    return container;
class MyListener : MessageListener<String?, String?> {
    override fun onMessage(data: ConsumerRecord<String?, String?>) {
private fun createContainer(
    factory: ConcurrentKafkaListenerContainerFactory<String, String>, topic: String, group: String
): ConcurrentMessageListenerContainer<String, String> {
    val container = factory.createContainer(topic)
    container.containerProperties.messageListener = MyListener()
    container.containerProperties.groupId = group
    container.beanName = group
    container.start()
    return container
Prototype Beans
Containers for methods annotated with @KafkaListener can be created dynamically by declaring the bean as prototype:spring-doc.cn
Prototype
public class MyPojo {
    private final String id;
    private final String topic;
    public MyPojo(String id, String topic) {
        this.id = id;
        this.topic = topic;
    public String getId() {
        return this.id;
    public String getTopic() {
        return this.topic;
    @KafkaListener(id = "#{__listener.id}", topics = "#{__listener.topic}")
    public void listen(String in) {
        System.out.println(in);
@Scope(ConfigurableBeanFactory.SCOPE_PROTOTYPE)
MyPojo pojo(String id, String topic) {
    return new MyPojo(id, topic);
applicationContext.getBean(MyPojo.class, "one", "topic2");
applicationContext.getBean(MyPojo.class, "two", "topic3");
class MyPojo(val id: String, val topic: String) {
    @KafkaListener(id = "#{__listener.id}", topics = ["#{__listener.topic}"])
    fun listen(`in`: String?) {
        println(`in`)
fun pojo(id: String, topic: String): MyPojo {
    return MyPojo(id, topic)
applicationContext.getBean(MyPojo::class.java, "one", "topic2")
applicationContext.getBean(MyPojo::class.java, "two", "topic3")
Listeners must have unique IDs. Starting with version 2.8.9, the KafkaListenerEndpointRegistry has a new method unregisterListenerContainer(String id) to allow you to re-use an id. Unregistering a container does not stop() the container, you must do that yourself.
