@KafkaListener Attribute Modification
Starting with version 2.7.2, you can now programmatically modify annotation attributes before the container is created. To do so, add one or more KafkaListenerAnnotationBeanPostProcessor.AnnotationEnhancer to the application context. AnnotationEnhancer is a BiFunction<Map<String, Object>, AnnotatedElement, Map<String, Object> and must return a map of attributes. The attribute values can contain SpEL and/or property placeholders; the enhancer is called before any resolution is performed. If more than one enhancer is present, and they implement Ordered, they will be invoked in order.spring-doc.cn
AnnotationEnhancer bean definitions must be declared static because they are required very early in the application context’s lifecycle.
An example follows:spring-doc.cn
public static AnnotationEnhancer groupIdEnhancer() {
    return (attrs, element) -> {
        attrs.put("groupId", attrs.get("id") + "." + (element instanceof Class
                ? ((Class<?>) element).getSimpleName()
                : ((Method) element).getDeclaringClass().getSimpleName()
                        +  "." + ((Method) element).getName()));
        return attrs;
