请访问:https://docs.spring.io/spring-framework/reference/6.1-SNAPSHOT/integration/cache/specific-config.html Spring Framework Integration Cache Abstraction How can I Set the TTL/TTI/Eviction policy/XXX feature? Plugging-in Different Back-end Caches Observability Support
