This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Redis 3.4.4! |
Scripting
Redis versions 2.6 and higher provide support for running Lua scripts through the eval and evalsha commands. Spring Data Redis provides a high-level abstraction for running scripts that handles serialization and automatically uses the Redis script cache.
Scripts can be run by calling the execute
methods of RedisTemplate
and ReactiveRedisTemplate
. Both use a configurable ScriptExecutor
(or ReactiveScriptExecutor
) to run the provided script. By default, the ScriptExecutor
) takes care of serializing the provided keys and arguments and deserializing the script result. This is done through the key and value serializers of the template. There is an additional overload that lets you pass custom serializers for the script arguments and the result.
The default ScriptExecutor
optimizes performance by retrieving the SHA1 of the script and attempting first to run evalsha
, falling back to eval
if the script is not yet present in the Redis script cache.
The following example runs a common “check-and-set” scenario by using a Lua script. This is an ideal use case for a Redis script, as it requires that running a set of commands atomically, and the behavior of one command is influenced by the result of another.
public RedisScript<Boolean> script() {
ScriptSource scriptSource = new ResourceScriptSource(new ClassPathResource("META-INF/scripts/checkandset.lua"));
return RedisScript.of(scriptSource, Boolean.class);
Imperative
Reactive
public class Example {
@Autowired
RedisOperations<String, String> redisOperations;
@Autowired
RedisScript<Boolean> script;
public boolean checkAndSet(String expectedValue, String newValue) {
return redisOperations.execute(script, singletonList("key"), expectedValue, newValue);
@Autowired
ReactiveRedisOperations<String, String> redisOperations;
@Autowired
public Flux<Boolean> checkAndSet(String expectedValue, String newValue) {
return redisOperations.execute(script, singletonList("key"), asList(expectedValue, newValue));
-- checkandset.lua
local current = redis.call('GET', KEYS[1])
if current == ARGV[1]
then redis.call('SET', KEYS[1], ARGV[2])
return true
end
return false
The preceding code configures a RedisScript
pointing to a file called checkandset.lua
, which is expected to return a boolean value. The script resultType
should be one of Long
, Boolean
, List
, or a deserialized value type. It can also be null
if the script returns a throw-away status (specifically, OK
It is ideal to configure a single instance of DefaultRedisScript in your application context to avoid re-calculation of the script’s SHA1 on every script run.
The checkAndSet
method above then runs the scripts. Scripts can be run within a SessionCallback
as part of a transaction or pipeline. See “Redis Transactions” and “Pipelining” for more information.
The scripting support provided by Spring Data Redis also lets you schedule Redis scripts for periodic running by using the Spring Task and Scheduler abstractions. See the Spring Framework documentation for more details.
