This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Redis 3.4.4!spring-doc.cn
Keyspaces
Keyspaces define prefixes used to create the actual key for the Redis Hash. By default, the prefix is set to getClass().getName(). You can alter this default by setting @RedisHash on the aggregate root level or by setting up a programmatic configuration. However, the annotated keyspace supersedes any other configuration.spring-doc.cn
The following example shows how to set the keyspace configuration with the @EnableRedisRepositories annotation:spring-doc.cn
Example 1. Keyspace Setup via @EnableRedisRepositories
@EnableRedisRepositories(keyspaceConfiguration = MyKeyspaceConfiguration.class)
public class ApplicationConfig {
  //... RedisConnectionFactory and RedisTemplate Bean definitions omitted
  public static class MyKeyspaceConfiguration extends KeyspaceConfiguration {
    protected Iterable<KeyspaceSettings> initialConfiguration() {
      return Collections.singleton(new KeyspaceSettings(Person.class, "people"));
The following example shows how to programmatically set the keyspace:spring-doc.cn
Example 2. Programmatic Keyspace setup
  public RedisMappingContext keyValueMappingContext() {
    return new RedisMappingContext(
      new MappingConfiguration(new IndexConfiguration(), new MyKeyspaceConfiguration()));
