This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Redis 3.4.4!
Getting Started
An easy way to bootstrap setting up a working environment is to create a Spring-based project via start.spring.io or create a Spring project in Spring Tools.
Examples Repository
The GitHub spring-data-examples repository hosts several examples that you can download and play around with to get a feel for how the library works.
Hello World
First, you need to set up a running Redis server. Spring Data Redis requires Redis 2.6 or above and Spring Data Redis integrates with Lettuce and Jedis, two popular open-source Java libraries for Redis.
Now you can create a simple Java application that stores and reads a value to and from Redis.
Create the main application to run, as the following example shows:
import org.apache.commons.logging.Log;
import org.apache.commons.logging.LogFactory;
import org.springframework.data.redis.connection.lettuce.LettuceConnectionFactory;
import org.springframework.data.redis.core.RedisTemplate;
import org.springframework.data.redis.serializer.StringRedisSerializer;
public class RedisApplication {
	private static final Log LOG = LogFactory.getLog(RedisApplication.class);
		LettuceConnectionFactory connectionFactory = new LettuceConnectionFactory();
		connectionFactory.afterPropertiesSet();
		RedisTemplate<String, String> template = new RedisTemplate<>();
		template.setConnectionFactory(connectionFactory);
		template.setDefaultSerializer(StringRedisSerializer.UTF_8);
		template.afterPropertiesSet();
		template.opsForValue().set("foo", "bar");
		LOG.info("Value at foo:" + template.opsForValue().get("foo"));
		connectionFactory.destroy();
Even in this simple example, there are a few notable things to point out:
APP信息
