For the latest stable version, please use Spring Data Redis 3.4.4!spring-doc.cn
Publishing Events from Aggregate Roots
Entities managed by repositories are aggregate roots. In a Domain-Driven Design application, these aggregate roots usually publish domain events. Spring Data provides an annotation called @DomainEvents that you can use on a method of your aggregate root to make that publication as easy as possible, as shown in the following example:spring-doc.cn
Exposing domain events from an aggregate root
class AnAggregateRoot {
    @DomainEvents (1)
    Collection<Object> domainEvents() {
        // … return events you want to get published here
    @AfterDomainEventPublication (2)
    void callbackMethod() {
       // … potentially clean up domain events list
1 The method that uses @DomainEvents can return either a single event instance or a collection of events. It must not take any arguments.
2 After all events have been published, we have a method annotated with @AfterDomainEventPublication. You can use it to potentially clean the list of events to be published (among other uses).
The methods are called every time one of the following a Spring Data repository methods are called:spring-doc.cn
Note, that these methods take the aggregate root instances as arguments. This is why deleteById(…) is notably absent, as the implementations might choose to issue a query deleting the instance and thus we would never have access to the aggregate instance in the first place.spring-doc.cn
