For the latest stable version, please use Spring Data Redis 3.4.4! |
Drivers
One of the first tasks when using Redis and Spring is to connect to the store through the IoC container.
To do that, a Java connector (or binding) is required.
No matter the library you choose, you need to use only one set of Spring Data Redis APIs (which behaves consistently across all connectors).
The org.springframework.data.redis.connection
package and its RedisConnection
and RedisConnectionFactory
interfaces for working with and retrieving active connections to Redis.
RedisConnection and RedisConnectionFactory
RedisConnection
provides the core building block for Redis communication, as it handles the communication with the Redis backend.
It also automatically translates underlying connecting library exceptions to Spring’s consistent DAO exception hierarchy so that you can switch connectors without any code changes, as the operation semantics remain the same.
For the corner cases where the native library API is required, RedisConnection provides a dedicated method (getNativeConnection ) that returns the raw, underlying object used for communication.
Active RedisConnection
objects are created through RedisConnectionFactory
In addition, the factory acts as PersistenceExceptionTranslator
objects, meaning that, once declared, they let you do transparent exception translation.
For example, you can do exception translation through the use of the @Repository
annotation and AOP.
For more information, see the dedicated section in the Spring Framework documentation.
RedisConnection classes are not Thread-safe.
While the underlying native connection, such as Lettuce’s StatefulRedisConnection , may be Thread-safe, Spring Data Redis’s LettuceConnection class itself is not.
Therefore, you should not share instances of a RedisConnection across multiple Threads.
This is especially true for transactional, or blocking Redis operations and commands, such as BLPOP .
In transactional and pipelining operations, for instance, RedisConnection holds onto unguarded mutable state to complete the operation correctly, thereby making it unsafe to use with multiple Threads.
This is by design.
If you need to share (stateful) Redis resources, like connections, across multiple Threads, for performance reasons or otherwise, then you should acquire the native connection and use the Redis client library (driver) API directly.
Alternatively, you can use the RedisTemplate , which acquires and manages connections for operations (and Redis commands) in a Thread-safe manner.
See documentation on RedisTemplate for more details.
Depending on the underlying configuration, the factory can return a new connection or an existing connection (when a pool or shared native connection is used). |
The easiest way to work with a RedisConnectionFactory
is to configure the appropriate connector through the IoC container and inject it into the using class.
Unfortunately, currently, not all connectors support all Redis features.
When invoking a method on the Connection API that is unsupported by the underlying library, an UnsupportedOperationException
is thrown.
The following overview explains features that are supported by the individual Redis connectors:
Supported Feature | Lettuce | Jedis |
Standalone Connections |
X |
X |
X |
Master Lookup, Sentinel Authentication, Replica Reads |
Master Lookup |
Cluster Connections, Cluster Node Connections, Replica Reads |
Cluster Connections, Cluster Node Connections |
Transport Channels |
TCP, OS-native TCP (epoll, kqueue), Unix Domain Sockets |
TCP |
Connection Pooling |
X (using |
X (using |
Other Connection Features |
Singleton-connection sharing for non-blocking commands |
Pipelining and Transactions mutually exclusive. Cannot use server/connection commands in pipeline/transactions. |
SSL Support |
X |
X |
X |
X |
X |
X (Pipelining and Transactions mutually exclusive) |
X |
Datatype support |
Key, String, List, Set, Sorted Set, Hash, Server, Stream, Scripting, Geo, HyperLogLog |
Reactive (non-blocking) API |
X |
Configuring the Lettuce Connector
Lettuce is a Netty-based open-source connector supported by Spring Data Redis through the org.springframework.data.redis.connection.lettuce
package.
dependencies
element:<dependencies>
<!-- other dependency elements omitted -->
<dependency>
<groupId>io.lettuce</groupId>
<artifactId>lettuce-core</artifactId>
<version>6.3.2.RELEASE</version>
</dependency>
</dependencies>
The following example shows how to create a new Lettuce connection factory:
class AppConfig {
public LettuceConnectionFactory redisConnectionFactory() {
return new LettuceConnectionFactory(new RedisStandaloneConfiguration("server", 6379));
There are also a few Lettuce-specific connection parameters that can be tweaked.
By default, all LettuceConnection
instances created by the LettuceConnectionFactory
share the same thread-safe native connection for all non-blocking and non-transactional operations.
To use a dedicated connection each time, set shareNativeConnection
to false
. LettuceConnectionFactory
can also be configured to use a LettucePool
for pooling blocking and transactional connections or all connections if shareNativeConnection
is set to false
The following example shows a more sophisticated configuration, including SSL and timeouts, that uses LettuceClientConfigurationBuilder
public LettuceConnectionFactory lettuceConnectionFactory() {
LettuceClientConfiguration clientConfig = LettuceClientConfiguration.builder()
.useSsl().and()
.commandTimeout(Duration.ofSeconds(2))
.shutdownTimeout(Duration.ZERO)
return new LettuceConnectionFactory(new RedisStandaloneConfiguration("localhost", 6379), clientConfig);
For more detailed client configuration tweaks, see LettuceClientConfiguration
Lettuce integrates with Netty’s native transports, letting you use Unix domain sockets to communicate with Redis.
Make sure to include the appropriate native transport dependencies that match your runtime environment.
The following example shows how to create a Lettuce Connection factory for a Unix domain socket at /var/run/redis.sock
class AppConfig {
return new LettuceConnectionFactory(new RedisSocketConfiguration("/var/run/redis.sock"));
Netty currently supports the epoll (Linux) and kqueue (BSD/macOS) interfaces for OS-native transport. |
Configuring the Jedis Connector
Jedis is a community-driven connector supported by the Spring Data Redis module through the org.springframework.data.redis.connection.jedis
package.
dependencies
<dependency>
<groupId>redis.clients</groupId>
<artifactId>jedis</artifactId>
<version>5.0.2</version>
</dependency>
</dependencies>
In its simplest form, the Jedis configuration looks as follow:
class AppConfig {
public JedisConnectionFactory redisConnectionFactory() {
return new JedisConnectionFactory();
For production use, however, you might want to tweak settings such as the host or password, as shown in the following example:
class RedisConfiguration {
RedisStandaloneConfiguration config = new RedisStandaloneConfiguration("server", 6379);
return new JedisConnectionFactory(config);
