For the latest stable version, please use Spring Data Redis 3.4.4! |
Upgrading Spring Data
Instructions for how to upgrade from earlier versions of Spring Data are provided on the project wiki. Follow the links in the release notes section to find the version that you want to upgrade to.
Upgrading instructions are always the first item in the release notes. If you are more than one release behind, please make sure that you also review the release notes of the versions that you jumped.
Once you’ve decided to upgrade your application, you can find detailed information regarding specific features in the rest of the document. You can find migration guides specific to major version migrations at the end of this document.
Spring Data’s documentation is specific to that version, so any information that you find in here will contain the most up-to-date changes that are in that version.
