对于最新的稳定版本,请使用 Spring Data Neo4j 7.4.5! |
不使用 Spring Boot
我们在自己的集成测试中大量使用抽象基类进行配置。它们可以像这样使用:
一种可能的测试设置,没有 Spring Boot
import org.junit.jupiter.api.Test;
import org.junit.jupiter.api.extension.ExtendWith;
import org.neo4j.driver.AuthTokens;
import org.neo4j.driver.Driver;
import org.neo4j.driver.GraphDatabase;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.data.neo4j.config.AbstractNeo4jConfig;
import org.springframework.data.neo4j.core.Neo4jTemplate;
import org.springframework.data.neo4j.repository.config.EnableNeo4jRepositories;
import org.springframework.test.context.junit.jupiter.SpringExtension;
import org.springframework.transaction.annotation.EnableTransactionManagement;
@ExtendWith(SpringExtension.class)
class YourIntegrationTest {
@Test
void thingsShouldWork(@Autowired Neo4jTemplate neo4jTemplate) {
// Add your test
@EnableNeo4jRepositories(considerNestedRepositories = true)
@EnableTransactionManagement
static class Config extends AbstractNeo4jConfig {
public Driver driver() {
return GraphDatabase.driver("bolt://yourtestserver:7687", AuthTokens.none()); (1)
Here you should provide a connection to your test server or container.
Similar classes are provided for reactive tests.
