For the latest stable version, please use Spring Data Neo4j 7.4.5!spring-doc.cn
Without Spring Boot
We work a lot with our abstract base classes for configuration in our own integration tests. They can be used like this:spring-doc.cn
One possible test setup without Spring Boot
import org.junit.jupiter.api.Test;
import org.junit.jupiter.api.extension.ExtendWith;
import org.neo4j.driver.AuthTokens;
import org.neo4j.driver.Driver;
import org.neo4j.driver.GraphDatabase;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.data.neo4j.config.AbstractNeo4jConfig;
import org.springframework.data.neo4j.core.Neo4jTemplate;
import org.springframework.data.neo4j.repository.config.EnableNeo4jRepositories;
import org.springframework.test.context.junit.jupiter.SpringExtension;
import org.springframework.transaction.annotation.EnableTransactionManagement;
@ExtendWith(SpringExtension.class)
class YourIntegrationTest {
	@Test
	void thingsShouldWork(@Autowired Neo4jTemplate neo4jTemplate) {
		// Add your test
	@EnableNeo4jRepositories(considerNestedRepositories = true)
	@EnableTransactionManagement
	static class Config extends AbstractNeo4jConfig {
		public Driver driver() {
			return GraphDatabase.driver("bolt://yourtestserver:7687", AuthTokens.none()); (1)
  1. Here you should provide a connection to your test server or container.spring-doc.cn
Similar classes are provided for reactive tests.spring-doc.cn
