此版本仍在开发中,尚未被视为稳定版本。如需最新的稳定版本,请使用 Spring Data Elasticsearch 5.4.5! |
Join-Type 实现
Spring Data Elasticsearch 支持 Join 数据类型,用于创建相应的索引映射和存储相关信息。
设置数据
对于要在父子联接关系中使用的实体,它必须具有JoinField
必须进行注释。
我们假设Statement
实体,其中语句可以是问题、答案、评论或投票(此示例中还显示了 Builder,这不是必需的,但稍后在示例代码中使用):
@Document(indexName = "statements")
@Routing("routing") (1)
public class Statement {
@Id
private String id;
@Field(type = FieldType.Text)
private String text;
@Field(type = FieldType.Keyword)
private String routing;
@JoinTypeRelations(
relations =
@JoinTypeRelation(parent = "question", children = {"answer", "comment"}), (2)
@JoinTypeRelation(parent = "answer", children = "vote") (3)
private JoinField<String> relation; (4)
private Statement() {
public static StatementBuilder builder() {
return new StatementBuilder();
public String getId() {
return id;
public void setId(String id) {
this.id = id;
public String getRouting() {
return routing;
public void setRouting(String routing) {
this.routing = routing;
public String getText() {
return text;
public void setText(String text) {
this.text = text;
public JoinField<String> getRelation() {
return relation;
public void setRelation(JoinField<String> relation) {
this.relation = relation;
public static final class StatementBuilder {
private String id;
private StatementBuilder() {
public StatementBuilder withId(String id) {
this.id = id;
return this;
public StatementBuilder withRouting(String routing) {
return this;
public StatementBuilder withText(String text) {
this.text = text;
return this;
public StatementBuilder withRelation(JoinField<String> relation) {
return this;
public Statement build() {
Statement statement = new Statement();
statement.setId(id);
statement.setRouting(routing);
statement.setText(text);
statement.setRelation(relation);
return statement;
1 | 有关路由相关信息,请参阅路由值 |
2 | 问题可以有答案和评论 |
3 | 答案可以有投票 |
4 | 这JoinField 属性用于将关系的名称 (问题、答案、评论或投票) 与父 ID 组合在一起。
泛型类型必须与@Id annotated 属性。 |
Spring Data Elasticsearch 将为此类构建以下映射:
"statements": {
"mappings": {
"properties": {
"_class": {
"type": "text",
"fields": {
"keyword": {
"type": "keyword",
"ignore_above": 256
"routing": {
"type": "keyword"
"relation": {
"type": "join",
"eager_global_ordinals": true,
"relations": {
"question": [
"answer",
"comment"
"answer": "vote"
"text": {
"type": "text"
存储数据
给定此类的存储库,以下代码插入一个问题、两个答案、一个评论和一个投票:
void init() {
repository.deleteAll();
Statement savedWeather = repository.save(
Statement.builder()
.withText("How is the weather?")
.withRelation(new JoinField<>("question")) (1)
.build());
Statement sunnyAnswer = repository.save(
Statement.builder()
.withText("sunny")
.withRelation(new JoinField<>("answer", savedWeather.getId())) (2)
.build());
repository.save(
Statement.builder()
.withText("rainy")
.withRelation(new JoinField<>("answer", savedWeather.getId())) (3)
.build());
repository.save(
Statement.builder()
.withText("I don't like the rain")
.withRelation(new JoinField<>("comment", savedWeather.getId())) (4)
.build());
repository.save(
Statement.builder()
.withText("+1 for the sun")
.withRouting(savedWeather.getId())
.withRelation(new JoinField<>("vote", sunnyAnswer.getId())) (5)
.build());
1 | 创建问题陈述 |
2 | 问题的第一个答案 |
3 | 第二个答案 |
4 | 对问题的评论 |
5 | 投票给第一个答案,这需要将路由设置为天气文档,请参阅路由值。 |
检索数据
当前必须使用本机查询来查询数据,因此标准存储库方法不支持。可以改用 Custom Repository Implementations。
下面的代码作为示例展示了如何使用 ElasticsearchOperations
实例:
SearchHits<Statement> hasVotes() {
Query query = NativeQuery.builder()
.withQuery(co.elastic.clients.elasticsearch._types.query_dsl.Query.of(qb -> qb
.hasChild(hc -> hc
.type("answer")
.queryName("vote")
.query(matchAllQueryAsQuery())
.scoreMode(ChildScoreMode.None)
return operations.search(query, Statement.class);
