This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.2.0! |
Mechanics
To better understand the mechanics and the necessity behind content-type negotiation, we take a look at a very simple use case by using the following message handler as an example:
public Function<Person, String> personFunction {..}
For simplicity, we assume that this is the only handler function in the application (we assume there is no internal pipeline). |
The handler shown in the preceding example expects a Person
object as an argument and produces a String
type as an output.
In order for the framework to succeed in passing the incoming Message
as an argument to this handler, it has to somehow transform the payload of the Message
type from the wire format to a Person
type.
In other words, the framework must locate and apply the appropriate MessageConverter
To accomplish that, the framework needs some instructions from the user.
One of these instructions is already provided by the signature of the handler method itself (Person
type).
Consequently, in theory, that should be (and, in some cases, is) enough.
However, for the majority of use cases, in order to select the appropriate MessageConverter
, the framework needs an additional piece of information.
That missing piece is contentType
Spring Cloud Stream provides three mechanisms to define contentType
(in order of precedence):
HEADER: The
contentType
can be communicated through the Message itself. By providing acontentType
header, you declare the content type to use to locate and apply the appropriateMessageConverter
BINDING: The
contentType
can be set per destination binding by setting thespring.cloud.stream.bindings.input.content-type
property.The input
segment in the property name corresponds to the actual name of the destination (which is “input” in our case). This approach lets you declare, on a per-binding basis, the content type to use to locate and apply the appropriateMessageConverter
DEFAULT: If
contentType
is not present in theMessage
header or the binding, the defaultapplication/json
content type is used to locate and apply the appropriateMessageConverter
As mentioned earlier, the preceding list also demonstrates the order of precedence in case of a tie. For example, a header-provided content type takes precedence over any other content type. The same applies for a content type set on a per-binding basis, which essentially lets you override the default content type. However, it also provides a sensible default (which was determined from community feedback).
Another reason for making application/json
the default stems from the interoperability requirements driven by distributed microservices architectures, where producer and consumer not only run in different JVMs but can also run on different non-JVM platforms.
When the non-void handler method returns, if the return value is already a Message
, that Message
becomes the payload. However, when the return value is not a Message
, the new Message
is constructed with the return value as the payload while inheriting
headers from the input Message
minus the headers defined or filtered by SpringIntegrationProperties.messageHandlerNotPropagatedHeaders
By default, there is only one header set there: contentType
. This means that the new Message
does not have contentType
header set, thus ensuring that the contentType
can evolve.
You can always opt out of returning a Message
from the handler method where you can inject any header you wish.
If there is an internal pipeline, the Message
is sent to the next handler by going through the same process of conversion. However, if there is no internal pipeline or you have reached the end of it, the Message
is sent back to the output destination.
Content Type versus Argument Type
As mentioned earlier, for the framework to select the appropriate MessageConverter
, it requires argument type and, optionally, content type information.
The logic for selecting the appropriate MessageConverter
resides with the argument resolvers (HandlerMethodArgumentResolvers
), which trigger right before the invocation of the user-defined handler method (which is when the actual argument type is known to the framework).
If the argument type does not match the type of the current payload, the framework delegates to the stack of the
pre-configured MessageConverters
to see if any one of them can convert the payload.
As you can see, the Object fromMessage(Message<?> message, Class<?> targetClass);
operation of the MessageConverter takes targetClass
as one of its arguments.
The framework also ensures that the provided Message
always contains a contentType
header.
When no contentType header was already present, it injects either the per-binding contentType
header or the default contentType
header.
The combination of contentType
argument type is the mechanism by which framework determines if message can be converted to a target type.
If no appropriate MessageConverter
is found, an exception is thrown, which you can handle by adding a custom MessageConverter
(see User-defined Message Converters
But what if the payload type matches the target type declared by the handler method? In this case, there is nothing to convert, and the
payload is passed unmodified. While this sounds pretty straightforward and logical, keep in mind handler methods that take a Message<?>
or Object
as an argument.
By declaring the target type to be Object
(which is an instanceof
everything in Java), you essentially forfeit the conversion process.
Do not expect Message to be converted into some other type based only on the contentType .
Remember that the contentType is complementary to the target type.
If you wish, you can provide a hint, which MessageConverter may or may not take into consideration.
Message Converters
MessageConverters
define two methods:
Message<?> toMessage(Object payload, @Nullable MessageHeaders headers);
It is important to understand the contract of these methods and their usage, specifically in the context of Spring Cloud Stream.
The fromMessage
method converts an incoming Message
to an argument type.
The payload of the Message
could be any type, and it is
up to the actual implementation of the MessageConverter
to support multiple types.
For example, some JSON converter may support the payload type as byte[]
, String
, and others.
This is important when the application contains an internal pipeline (that is, input → handler1 → handler2 →. . . → output) and the output of the upstream handler results in a Message
which may not be in the initial wire format.
However, the toMessage
method has a more strict contract and must always convert Message
to the wire format: byte[]
So, for all intents and purposes (and especially when implementing your own converter) you regard the two methods as having the following signatures:
Message<byte[]> toMessage(Object payload, @Nullable MessageHeaders headers);
