This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Bindings
As stated earlier, Bindings provide a bridge between the external messaging system (e.g., queue, topic etc.) and application-provided Producers and Consumers.spring-doc.cn
The following example shows a fully configured and functioning Spring Cloud Stream application that receives the payload of the message as a String type (see Content Type Negotiation section), logs it to the console and sends it down stream after converting it to upper case.spring-doc.cn
@SpringBootApplication
public class SampleApplication {
		SpringApplication.run(SampleApplication.class, args);
	public Function<String, String> uppercase() {
	    return value -> {
	        System.out.println("Received: " + value);
	        return value.toUpperCase();
The above example looks no different than any vanilla spring-boot application. It defines a single bean of type Function and that is it. So, how does it become a spring-cloud-stream application? It becomes a spring-cloud-stream application simply because of the presence of spring-cloud-stream and binder dependencies and auto-configuration classes on the classpath, effectively setting the context for your boot application as a spring-cloud-stream application. And in this context beans of type Supplier, Function or Consumer are treated as defacto message handlers triggering binding of to destinations exposed by the provided binder following certain naming conventions and rules to avoid extra configuration.spring-doc.cn
