This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Destination Binders
Destination Binders are extension components of Spring Cloud Stream responsible for providing the necessary configuration and implementation to facilitate integration with external messaging systems. This integration is responsible for connectivity, delegation, and routing of messages to and from producers and consumers, data type conversion, invocation of the user code, and more.spring-doc.cn
Binders handle a lot of the boiler plate responsibilities that would otherwise fall on your shoulders. However, to accomplish that, the binder still needs some help in the form of minimalistic yet required set of instructions from the user, which typically come in the form of some type of binding configuration.spring-doc.cn
While it is out of scope of this section to discuss all of the available binder and binding configuration options (the rest of the manual covers them extensively), Binding as a concept, does require special attention. The next section discusses it in detail.spring-doc.cn
