This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.2.0!spring-doc.cn
Post processing (after sending message)
Once function is invoked, its result is sent by the framework to a target destination which effectively completes function invocation cycle.spring-doc.cn
However such cycle may not be fully complete from the business standpoint until some additional tasks are performed after completion of this cycle. While this could be accomplished with a simple combination of Consumer and StreamBridge as described in this Stack Overflow post, since version 4.0.3 the framework provides a more idiomatic approach to solve this issue via PostProcessingFunction provided by Spring Cloud Function project. The PostProcessingFunction is a special semi-marker function which contains one additional method postProcess(Message>) designed to provide a place for implementing such post processing task.spring-doc.cn
package org.springframework.cloud.function.context
public interface PostProcessingFunction<I, O> extends Function<I, O> {
	default void postProcess(Message<O> result) {
So, now you have two options.spring-doc.cn
Option 1: You can implement your function as PostProcessingFunction and also include the additional post processing behavior by implementing its postProcess(Message>) method.spring-doc.cn
private static class Uppercase implements PostProcessingFunction<String, String> {
	public String apply(String input) {
		return input.toUpperCase();
	public void postProcess(Message<String> result) {
		System.out.println("Function Uppercase has been successfully invoked and its result successfully sent to target destination");
public Function<String, String> uppercase() {
	return new Uppercase();
Option 2: If you already have an existing function and don’t want to change its implementation or want to keep your function as POJO, you can simply implement only postProcess(Message>) method and compose this new post processing function with your other function.spring-doc.cn
private static class Logger implements PostProcessingFunction<?, String> {
		System.out.println("Function has been successfully invoked and its result successfully sent to target destination");
	return v -> v.toUpperCase();
public Function<String, String> logger() {
	return new Logger();
//  and then have your function definition as such `uppercase|logger`
NOTE: In case of function composition only the last instance of PostProcessingFunction (if present) will take effect. For example, let’s say you have the following function definition - foo|bar|baz and both foo and baz are instances of PostProcessingFunction. Only baz.postProcess(Message>) will be invoked. If baz is not an instance of PostProcessingFunction, then no post processing functionality will be performed.spring-doc.cn
One may argue that you can easily do that via function composition by simply composing a post-processor as just another Function. That is indeed a possibility however the post processing functionality in this case will be invoked right after invocation of the previous function and before the message is sent to a target destination which is before the function invocation cycle is complete.spring-doc.cn
