This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.2.0! |
Customizing binders in multi binder applications
When an application has multiple binders in it and wants to customize the binders, then that can be achieved by providing a BinderCustomizer
implementation.
In the case of applications with a single binder, this special customizer is not necessary since the binder context can access the customization beans directly.
However, this is not the case in a multi-binder scenario, since various binders live in different application contexts.
By providing an implementation of BinderCustomizer
interface, the binders, although reside in different application contexts, will receive the customization.
Spring Cloud Stream ensures that the customizations take place before the applications start using the binders.
The user must check for the binder type and then apply the necessary customizations.
Here is an example of providing a BinderCustomizer
bean.
public BinderCustomizer binderCustomizer() {
return (binder, binderName) -> {
if (binder instanceof KafkaMessageChannelBinder kafkaMessageChannelBinder) {
kafkaMessageChannelBinder.setRebalanceListener(...);
else if (binder instanceof KStreamBinder) {
else if (binder instanceof RabbitMessageChannelBinder) {
Note that, when there are more than one instance of the same type of the binder, the binder name can be used to filter customization.
