This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-stream 4.2.0! |
User-defined Message Converters
Spring Cloud Stream exposes a mechanism to define and register additional MessageConverter
s.
To use it, implement org.springframework.messaging.converter.MessageConverter
, configure it as a @Bean
It is then appended to the existing stack of MessageConverter
s.
It is important to understand that custom MessageConverter implementations are added to the head of the existing stack.
Consequently, custom MessageConverter implementations take precedence over the existing ones, which lets you override as well as add to the existing converters.
The following example shows how to create a message converter bean to support a new content type called application/bar
@SpringBootApplication
public static class SinkApplication {
public MessageConverter customMessageConverter() {
return new MyCustomMessageConverter();
public class MyCustomMessageConverter extends AbstractMessageConverter {
public MyCustomMessageConverter() {
super(new MimeType("application", "bar"));
protected boolean supports(Class<?> clazz) {
return (Bar.class.equals(clazz));
protected Object convertFromInternal(Message<?> message, Class<?> targetClass, Object conversionHint) {
Object payload = message.getPayload();
return (payload instanceof Bar ? payload : new Bar((byte[]) payload));
