This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud Config 4.1.4!spring-doc.cn
Creating a Key Store for Testing
To create a keystore for testing, you can use a command resembling the following:spring-doc.cn
$ keytool -genkeypair -alias mytestkey -keyalg RSA \
  -dname "CN=Web Server,OU=Unit,O=Organization,L=City,S=State,C=US" \
  -keypass changeme -keystore server.jks -storepass letmein
When using JDK 11 or above you may get the following warning when using the command above. In this case you probably want to make sure the keypass and storepass values match.
Warning:  Different store and key passwords not supported for PKCS12 KeyStores. Ignoring user-specified -keypass value.
Put the server.jks file in the classpath (for instance) and then, in your bootstrap.yml, for the Config Server, create the following settings:spring-doc.cn
encrypt:
  keyStore:
    password: letmein
    alias: mytestkey
    secret: changeme
