This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud Config 4.1.4! |
Redis Backend
Spring Cloud Config Server supports Redis as a backend for configuration properties. You can enable this feature by adding a dependency to Spring Data Redis.
pom.xml
<dependencies>
<dependency>
<artifactId>spring-boot-starter-data-redis</artifactId>
</dependency>
</dependencies>
The following configuration uses Spring Data RedisTemplate
to access a Redis. We can use spring.redis.*
properties to override default connection settings.
spring:
profiles:
active: redis
redis:
host: redis
port: 16379
The properties should be stored as fields in a hash. The name of hash should be the same as spring.application.name
property or conjunction of spring.application.name
and spring.profiles.active[n]
HMSET sample-app server.port "8100" sample.topic.name "test" test.property1 "property1"
After running the command visible above a hash should contain the following keys with values:
HGETALL sample-app { "server.port": "8100", "sample.topic.name": "test", "test.property1": "property1" }
When no profile is specified default will be used.
