作方法:自定义 OpenID Connect 1.0 UserInfo 响应
本指南介绍如何自定义 Spring Authorization ServerUserInfo 端点。 本指南的目的是演示如何启用终端节点并使用可用的自定义选项生成自定义响应。spring-doc.cadn.net.cn
启用 User Info 端点
OpenID Connect 1.0 UserInfo 终端节点是受 OAuth2 保护的资源,它要求UserInfo 请求中将访问Tokens作为持有者Tokens发送。spring-doc.cadn.net.cn
根据 OAuth 2.0 不记名Tokens用法 [RFC6750] 的第 2 节,从 OpenID Connect 身份验证请求获取的访问Tokens必须作为不记名Tokens发送。spring-doc.cadn.net.cn
在自定义响应之前,您需要启用 UserInfo Endpoint。 以下清单显示了如何启用 OAuth2 资源服务器配置spring-doc.cadn.net.cn
import java.security.KeyPair;
import java.security.KeyPairGenerator;
import java.security.interfaces.RSAPrivateKey;
import java.security.interfaces.RSAPublicKey;
import java.util.UUID;
import com.nimbusds.jose.jwk.JWKSet;
import com.nimbusds.jose.jwk.RSAKey;
import com.nimbusds.jose.jwk.source.ImmutableJWKSet;
import com.nimbusds.jose.jwk.source.JWKSource;
import com.nimbusds.jose.proc.SecurityContext;
import org.springframework.core.annotation.Order;
import org.springframework.http.MediaType;
import org.springframework.security.config.Customizer;
import org.springframework.security.config.annotation.web.builders.HttpSecurity;
import org.springframework.security.config.annotation.web.configuration.EnableWebSecurity;
import org.springframework.security.core.userdetails.User;
import org.springframework.security.core.userdetails.UserDetails;
import org.springframework.security.core.userdetails.UserDetailsService;
import org.springframework.security.oauth2.core.AuthorizationGrantType;
import org.springframework.security.oauth2.core.ClientAuthenticationMethod;
import org.springframework.security.oauth2.core.oidc.OidcScopes;
import org.springframework.security.oauth2.jwt.JwtDecoder;
import org.springframework.security.oauth2.server.authorization.client.InMemoryRegisteredClientRepository;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClient;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClientRepository;
import org.springframework.security.oauth2.server.authorization.config.annotation.web.configuration.OAuth2AuthorizationServerConfiguration;
import org.springframework.security.oauth2.server.authorization.config.annotation.web.configurers.OAuth2AuthorizationServerConfigurer;
import org.springframework.security.oauth2.server.authorization.settings.AuthorizationServerSettings;
import org.springframework.security.oauth2.server.authorization.settings.ClientSettings;
import org.springframework.security.provisioning.InMemoryUserDetailsManager;
import org.springframework.security.web.SecurityFilterChain;
import org.springframework.security.web.authentication.LoginUrlAuthenticationEntryPoint;
import org.springframework.security.web.util.matcher.MediaTypeRequestMatcher;
@EnableWebSecurity
public class EnableUserInfoSecurityConfig {
	@Bean (1)
	@Order(1)
	public SecurityFilterChain authorizationServerSecurityFilterChain(HttpSecurity http) throws Exception {
		OAuth2AuthorizationServerConfigurer authorizationServerConfigurer =
				OAuth2AuthorizationServerConfigurer.authorizationServer();
		http
			.securityMatcher(authorizationServerConfigurer.getEndpointsMatcher())
			.with(authorizationServerConfigurer, (authorizationServer) ->
				authorizationServer
					.oidc(Customizer.withDefaults())	(2)
			.authorizeHttpRequests((authorize) ->
				authorize
					.anyRequest().authenticated()
			.exceptionHandling((exceptions) -> exceptions
				.defaultAuthenticationEntryPointFor(
					new LoginUrlAuthenticationEntryPoint("/login"),
					new MediaTypeRequestMatcher(MediaType.TEXT_HTML)
		return http.build();
	@Order(2)
	public SecurityFilterChain defaultSecurityFilterChain(HttpSecurity http) throws Exception {
		http
			.authorizeHttpRequests((authorize) -> authorize
			.formLogin(Customizer.withDefaults());
	@Bean (3)
	public JwtDecoder jwtDecoder(JWKSource<SecurityContext> jwkSource) {
		return OAuth2AuthorizationServerConfiguration.jwtDecoder(jwkSource);
	public UserDetailsService userDetailsService() {
		UserDetails userDetails = User.withDefaultPasswordEncoder()
				.username("user")
				.password("password")
				.roles("USER")
		return new InMemoryUserDetailsManager(userDetails);
	public RegisteredClientRepository registeredClientRepository() {
		RegisteredClient registeredClient = RegisteredClient.withId(UUID.randomUUID().toString())
				.clientId("messaging-client")
				.clientSecret("{noop}secret")
				.clientAuthenticationMethod(ClientAuthenticationMethod.CLIENT_SECRET_BASIC)
				.authorizationGrantType(AuthorizationGrantType.AUTHORIZATION_CODE)
				.authorizationGrantType(AuthorizationGrantType.REFRESH_TOKEN)
				.authorizationGrantType(AuthorizationGrantType.CLIENT_CREDENTIALS)
				.redirectUri("http://127.0.0.1:8080/login/oauth2/code/messaging-client-oidc")
				.redirectUri("http://127.0.0.1:8080/authorized")
				.scope(OidcScopes.OPENID)
				.scope(OidcScopes.ADDRESS)
				.scope(OidcScopes.EMAIL)
				.scope(OidcScopes.PHONE)
				.scope(OidcScopes.PROFILE)
				.scope("message.read")
				.scope("message.write")
				.clientSettings(ClientSettings.builder().requireAuthorizationConsent(true).build())
		return new InMemoryRegisteredClientRepository(registeredClient);
	public JWKSource<SecurityContext> jwkSource() {
		KeyPair keyPair = generateRsaKey();
		RSAPublicKey publicKey = (RSAPublicKey) keyPair.getPublic();
		RSAPrivateKey privateKey = (RSAPrivateKey) keyPair.getPrivate();
		RSAKey rsaKey = new RSAKey.Builder(publicKey)
				.privateKey(privateKey)
				.keyID(UUID.randomUUID().toString())
		JWKSet jwkSet = new JWKSet(rsaKey);
		return new ImmutableJWKSet<>(jwkSet);
	private static KeyPair generateRsaKey() {
		KeyPair keyPair;
		try {
			KeyPairGenerator keyPairGenerator = KeyPairGenerator.getInstance("RSA");
			keyPairGenerator.initialize(2048);
			keyPair = keyPairGenerator.generateKeyPair();
		catch (Exception ex) {
			throw new IllegalStateException(ex);
		return keyPair;
	public AuthorizationServerSettings authorizationServerSettings() {
		return AuthorizationServerSettings.builder().build();
单击上面代码示例中的“Expand folded text”图标以显示完整示例。
此配置提供以下内容:spring-doc.cadn.net.cn
1 协议端点的 Spring Security 过滤器链。
2 启用 OpenID Connect 1.0 将自动配置资源服务器支持,允许使用访问Tokens对用户信息请求进行身份验证。
3 一个JwtDecoder用于验证访问Tokens。
自定义用户信息响应
以下部分介绍了用于自定义用户信息响应的一些选项。spring-doc.cadn.net.cn
自定义 ID Tokens
默认情况下,用户信息响应是使用id_tokenToken 响应一起返回。 使用默认策略时,根据授权期间请求的范围,仅返回标准声明和用户信息响应。spring-doc.cadn.net.cn
自定义用户信息响应的首选方法是将标准声明添加到id_token. 下面的清单显示了如何将声明添加到id_token.spring-doc.cadn.net.cn
import org.springframework.security.oauth2.core.oidc.OidcUserInfo;
import org.springframework.security.oauth2.core.oidc.endpoint.OidcParameterNames;
import org.springframework.security.oauth2.server.authorization.token.JwtEncodingContext;
import org.springframework.security.oauth2.server.authorization.token.OAuth2TokenCustomizer;
public class IdTokenCustomizerConfig {
	@Bean (1)
	public OAuth2TokenCustomizer<JwtEncodingContext> tokenCustomizer(
			OidcUserInfoService userInfoService) {
		return (context) -> {
			if (OidcParameterNames.ID_TOKEN.equals(context.getTokenType().getValue())) {
				OidcUserInfo userInfo = userInfoService.loadUser( (2)
						context.getPrincipal().getName());
				context.getClaims().claims(claims ->
						claims.putAll(userInfo.getClaims()));
1 一个OAuth2TokenCustomizer用于自定义id_token.
2 用于以特定于域的方式获取用户信息的自定义服务。
下面的清单显示了一个自定义服务,用于以特定于域的方式查找用户信息:spring-doc.cadn.net.cn
import java.util.Collections;
import java.util.HashMap;
import java.util.Map;
import org.springframework.stereotype.Service;
 * Example service to perform lookup of user info for customizing an {@code id_token}.
@Service
public class OidcUserInfoService {
	private final UserInfoRepository userInfoRepository = new UserInfoRepository();
	public OidcUserInfo loadUser(String username) {
		return new OidcUserInfo(this.userInfoRepository.findByUsername(username));
	static class UserInfoRepository {
		private final Map<String, Map<String, Object>> userInfo = new HashMap<>();
		public UserInfoRepository() {
			this.userInfo.put("user1", createUser("user1"));
			this.userInfo.put("user2", createUser("user2"));
		public Map<String, Object> findByUsername(String username) {
			return this.userInfo.get(username);
		private static Map<String, Object> createUser(String username) {
			return OidcUserInfo.builder()
					.subject(username)
					.name("First Last")
					.givenName("First")
					.familyName("Last")
					.middleName("Middle")
					.nickname("User")
					.preferredUsername(username)
					.profile("https://example.com/" + username)
					.picture("https://example.com/" + username + ".jpg")
					.website("https://example.com")
					.email(username + "@example.com")
					.emailVerified(true)
					.gender("female")
					.birthdate("1970-01-01")
					.zoneinfo("Europe/Paris")
					.locale("en-US")
					.phoneNumber("+1 (604) 555-1234;ext=5678")
					.phoneNumberVerified(false)
					.claim("address", Collections.singletonMap("formatted", "Champ de Mars\n5 Av. Anatole France\n75007 Paris\nFrance"))
					.updatedAt("1970-01-01T00:00:00Z")
					.build()
					.getClaims();
自定义 User Info Mapper
要完全自定义用户信息响应,您可以提供一个自定义用户信息映射器,该映射器能够生成用于呈现响应的对象,该对象是OidcUserInfo类。 映射器实现接收OidcUserInfoAuthenticationContext包含有关当前请求的信息,包括OAuth2Authorization.spring-doc.cadn.net.cn
以下清单显示了如何使用在直接使用OAuth2AuthorizationServerConfigurer.spring-doc.cadn.net.cn
import java.util.function.Function;
import org.springframework.security.oauth2.server.authorization.oidc.authentication.OidcUserInfoAuthenticationContext;
import org.springframework.security.oauth2.server.authorization.oidc.authentication.OidcUserInfoAuthenticationToken;
import org.springframework.security.oauth2.server.resource.authentication.JwtAuthenticationToken;
@EnableWebSecurity
public class JwtUserInfoMapperSecurityConfig {
	@Bean	(1)
	@Order(1)
		Function<OidcUserInfoAuthenticationContext, OidcUserInfo> userInfoMapper = (context) -> {	(2)
			OidcUserInfoAuthenticationToken authentication = context.getAuthentication();
			JwtAuthenticationToken principal = (JwtAuthenticationToken) authentication.getPrincipal();
			return new OidcUserInfo(principal.getToken().getClaims());
		http
				authorizationServer
					.oidc((oidc) -> oidc	(3)
						.userInfoEndpoint((userInfo) -> userInfo
							.userInfoMapper(userInfoMapper)	(4)
	@Order(2)
		http
				.username("user")
				.roles("USER")
		KeyPair keyPair;
		try {
		return keyPair;
此配置映射来自访问Tokens(使用入门配置时为 JWT)的声明以填充用户信息响应,并提供以下内容:spring-doc.cadn.net.cn
2 一个用户信息映射器,它以特定于域的方式映射声明。
3 启用 OpenID Connect 1.0 将自动配置资源服务器支持,允许使用访问Tokens对用户信息请求进行身份验证。
4 显示用于自定义用户信息映射器的配置选项的示例。
用户信息映射器不仅限于映射来自 JWT 的声明,但这是一个演示自定义选项的简单示例。 与前面显示的示例类似,我们自定义 ID Tokens的声明,您可以提前自定义访问Tokens本身的声明,如以下示例所示:spring-doc.cadn.net.cn
import org.springframework.security.oauth2.server.authorization.OAuth2TokenType;
public class JwtTokenCustomizerConfig {
	public OAuth2TokenCustomizer<JwtEncodingContext> tokenCustomizer() {
			if (OAuth2TokenType.ACCESS_TOKEN.equals(context.getTokenType())) {
				context.getClaims().claims((claims) -> {
					claims.put("claim-1", "value-1");
					claims.put("claim-2", "value-2");
无论您是直接自定义用户信息响应,还是使用此示例并自定义访问Tokens,您都可以在数据库中查找信息、执行 LDAP 查询、向其他服务发出请求,或者使用任何其他方式获取您希望在用户信息响应中显示的信息。spring-doc.cadn.net.cn
