作方法:使用 Redis 实现核心服务
本指南介绍如何使用 Redis 实现 Spring Authorization Server 的核心服务。 本指南的目的是为自行实施这些服务提供一个起点,以便您可以进行修改以满足您的需要。spring-doc.cadn.net.cn
本指南中提供的代码示例位于 redis 子目录下的 documentation samples 目录中。
定义实体模型
下面定义了RegisteredClient,OAuth2AuthorizationOAuth2AuthorizationConsentdomain 类。spring-doc.cadn.net.cn
注册客户实体
下面的清单显示了OAuth2RegisteredClient实体,用于保存从RegisteredClientdomain 类。spring-doc.cadn.net.cn
OAuth2RegisteredClient 实体
import java.time.Duration;
import java.time.Instant;
import java.util.Set;
import org.springframework.data.annotation.Id;
import org.springframework.data.redis.core.RedisHash;
import org.springframework.data.redis.core.index.Indexed;
import org.springframework.security.oauth2.core.AuthorizationGrantType;
import org.springframework.security.oauth2.core.ClientAuthenticationMethod;
import org.springframework.security.oauth2.jose.jws.JwsAlgorithm;
import org.springframework.security.oauth2.jose.jws.SignatureAlgorithm;
import org.springframework.security.oauth2.server.authorization.settings.OAuth2TokenFormat;
@RedisHash("oauth2_registered_client")
public class OAuth2RegisteredClient {
	@Id
	private final String id;
	@Indexed
	private final String clientId;
	private final Instant clientIdIssuedAt;
	private final String clientSecret;
	private final Instant clientSecretExpiresAt;
	private final String clientName;
	private final Set<ClientAuthenticationMethod> clientAuthenticationMethods;
	private final Set<AuthorizationGrantType> authorizationGrantTypes;
	private final Set<String> redirectUris;
	private final Set<String> postLogoutRedirectUris;
	private final Set<String> scopes;
	private final ClientSettings clientSettings;
	private final TokenSettings tokenSettings;
	public OAuth2RegisteredClient(String id, String clientId, Instant clientIdIssuedAt, String clientSecret,
			Instant clientSecretExpiresAt, String clientName,
			Set<ClientAuthenticationMethod> clientAuthenticationMethods,
			Set<AuthorizationGrantType> authorizationGrantTypes, Set<String> redirectUris,
			Set<String> postLogoutRedirectUris, Set<String> scopes, ClientSettings clientSettings,
			TokenSettings tokenSettings) {
		this.id = id;
		this.clientId = clientId;
		this.clientIdIssuedAt = clientIdIssuedAt;
		this.clientSecret = clientSecret;
		this.clientSecretExpiresAt = clientSecretExpiresAt;
		this.clientName = clientName;
		this.clientAuthenticationMethods = clientAuthenticationMethods;
		this.authorizationGrantTypes = authorizationGrantTypes;
		this.redirectUris = redirectUris;
		this.postLogoutRedirectUris = postLogoutRedirectUris;
		this.scopes = scopes;
		this.clientSettings = clientSettings;
		this.tokenSettings = tokenSettings;
	public String getId() {
		return this.id;
	public String getClientId() {
		return this.clientId;
	public Instant getClientIdIssuedAt() {
		return this.clientIdIssuedAt;
	public String getClientSecret() {
		return this.clientSecret;
	public Instant getClientSecretExpiresAt() {
		return this.clientSecretExpiresAt;
	public String getClientName() {
		return this.clientName;
	public Set<ClientAuthenticationMethod> getClientAuthenticationMethods() {
		return this.clientAuthenticationMethods;
	public Set<AuthorizationGrantType> getAuthorizationGrantTypes() {
		return this.authorizationGrantTypes;
	public Set<String> getRedirectUris() {
		return this.redirectUris;
	public Set<String> getPostLogoutRedirectUris() {
		return this.postLogoutRedirectUris;
	public Set<String> getScopes() {
		return this.scopes;
	public ClientSettings getClientSettings() {
		return this.clientSettings;
	public TokenSettings getTokenSettings() {
		return this.tokenSettings;
	public static class ClientSettings {
		private final boolean requireProofKey;
		private final boolean requireAuthorizationConsent;
		private final String jwkSetUrl;
		private final JwsAlgorithm tokenEndpointAuthenticationSigningAlgorithm;
		private final String x509CertificateSubjectDN;
		public ClientSettings(boolean requireProofKey, boolean requireAuthorizationConsent, String jwkSetUrl,
				JwsAlgorithm tokenEndpointAuthenticationSigningAlgorithm, String x509CertificateSubjectDN) {
			this.requireProofKey = requireProofKey;
			this.requireAuthorizationConsent = requireAuthorizationConsent;
			this.jwkSetUrl = jwkSetUrl;
			this.tokenEndpointAuthenticationSigningAlgorithm = tokenEndpointAuthenticationSigningAlgorithm;
			this.x509CertificateSubjectDN = x509CertificateSubjectDN;
		public boolean isRequireProofKey() {
			return this.requireProofKey;
		public boolean isRequireAuthorizationConsent() {
			return this.requireAuthorizationConsent;
		public String getJwkSetUrl() {
			return this.jwkSetUrl;
		public JwsAlgorithm getTokenEndpointAuthenticationSigningAlgorithm() {
			return this.tokenEndpointAuthenticationSigningAlgorithm;
		public String getX509CertificateSubjectDN() {
			return this.x509CertificateSubjectDN;
	public static class TokenSettings {
		private final Duration authorizationCodeTimeToLive;
		private final Duration accessTokenTimeToLive;
		private final OAuth2TokenFormat accessTokenFormat;
		private final Duration deviceCodeTimeToLive;
		private final boolean reuseRefreshTokens;
		private final Duration refreshTokenTimeToLive;
		private final SignatureAlgorithm idTokenSignatureAlgorithm;
		private final boolean x509CertificateBoundAccessTokens;
		public TokenSettings(Duration authorizationCodeTimeToLive, Duration accessTokenTimeToLive,
				OAuth2TokenFormat accessTokenFormat, Duration deviceCodeTimeToLive, boolean reuseRefreshTokens,
				Duration refreshTokenTimeToLive, SignatureAlgorithm idTokenSignatureAlgorithm,
				boolean x509CertificateBoundAccessTokens) {
			this.authorizationCodeTimeToLive = authorizationCodeTimeToLive;
			this.accessTokenTimeToLive = accessTokenTimeToLive;
			this.accessTokenFormat = accessTokenFormat;
			this.deviceCodeTimeToLive = deviceCodeTimeToLive;
			this.reuseRefreshTokens = reuseRefreshTokens;
			this.refreshTokenTimeToLive = refreshTokenTimeToLive;
			this.idTokenSignatureAlgorithm = idTokenSignatureAlgorithm;
			this.x509CertificateBoundAccessTokens = x509CertificateBoundAccessTokens;
		public Duration getAuthorizationCodeTimeToLive() {
			return this.authorizationCodeTimeToLive;
		public Duration getAccessTokenTimeToLive() {
			return this.accessTokenTimeToLive;
		public OAuth2TokenFormat getAccessTokenFormat() {
			return this.accessTokenFormat;
		public Duration getDeviceCodeTimeToLive() {
			return this.deviceCodeTimeToLive;
		public boolean isReuseRefreshTokens() {
			return this.reuseRefreshTokens;
		public Duration getRefreshTokenTimeToLive() {
			return this.refreshTokenTimeToLive;
		public SignatureAlgorithm getIdTokenSignatureAlgorithm() {
			return this.idTokenSignatureAlgorithm;
		public boolean isX509CertificateBoundAccessTokens() {
			return this.x509CertificateBoundAccessTokens;
单击上面代码示例中的“Expand folded text”图标以显示完整示例。
授权授予基本实体
的实体模型OAuth2Authorizationdomain 类使用基于授权授权类型的类层次结构进行设计。spring-doc.cadn.net.cn
下面的清单显示了OAuth2AuthorizationGrantAuthorization base 实体,它定义每个授权授权类型的通用属性。spring-doc.cadn.net.cn
OAuth2AuthorizationGrantAuthorization 基本实体
import java.util.Map;
import org.springframework.security.oauth2.core.OAuth2AccessToken;
@RedisHash("oauth2_authorization")
public abstract class OAuth2AuthorizationGrantAuthorization {
	@Id
	private final String registeredClientId;
	private final String principalName;
	private final Set<String> authorizedScopes;
	private final AccessToken accessToken;
	private final RefreshToken refreshToken;
	protected OAuth2AuthorizationGrantAuthorization(String id, String registeredClientId, String principalName,
			Set<String> authorizedScopes, AccessToken accessToken, RefreshToken refreshToken) {
		this.id = id;
		this.registeredClientId = registeredClientId;
		this.principalName = principalName;
		this.authorizedScopes = authorizedScopes;
		this.accessToken = accessToken;
		this.refreshToken = refreshToken;
		return this.id;
	public String getRegisteredClientId() {
		return this.registeredClientId;
	public String getPrincipalName() {
		return this.principalName;
	public Set<String> getAuthorizedScopes() {
		return this.authorizedScopes;
	public AccessToken getAccessToken() {
		return this.accessToken;
	public RefreshToken getRefreshToken() {
		return this.refreshToken;
	protected abstract static class AbstractToken {
		@Indexed
		private final String tokenValue;
		private final Instant issuedAt;
		private final Instant expiresAt;
		private final boolean invalidated;
		protected AbstractToken(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated) {
			this.tokenValue = tokenValue;
			this.issuedAt = issuedAt;
			this.expiresAt = expiresAt;
			this.invalidated = invalidated;
		public String getTokenValue() {
			return this.tokenValue;
		public Instant getIssuedAt() {
			return this.issuedAt;
		public Instant getExpiresAt() {
			return this.expiresAt;
		public boolean isInvalidated() {
			return this.invalidated;
	public static class ClaimsHolder {
		private final Map<String, Object> claims;
		public ClaimsHolder(Map<String, Object> claims) {
			this.claims = claims;
		public Map<String, Object> getClaims() {
			return this.claims;
	public static class AccessToken extends AbstractToken {
		private final OAuth2AccessToken.TokenType tokenType;
		private final OAuth2TokenFormat tokenFormat;
		private final ClaimsHolder claims;
		public AccessToken(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated,
				OAuth2AccessToken.TokenType tokenType, Set<String> scopes, OAuth2TokenFormat tokenFormat,
				ClaimsHolder claims) {
			super(tokenValue, issuedAt, expiresAt, invalidated);
			this.tokenType = tokenType;
			this.tokenFormat = tokenFormat;
		public OAuth2AccessToken.TokenType getTokenType() {
			return this.tokenType;
			return this.scopes;
		public OAuth2TokenFormat getTokenFormat() {
			return this.tokenFormat;
		public ClaimsHolder getClaims() {
			return this.claims;
	public static class RefreshToken extends AbstractToken {
		public RefreshToken(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated) {
授权代码授予实体 (OAuth 2.0)
下面的清单显示了OAuth2AuthorizationCodeGrantAuthorizationentity,它扩展了OAuth2AuthorizationGrantAuthorization,并为 OAuth 2.0 定义其他属性authorization_code授权类型。spring-doc.cadn.net.cn
OAuth2AuthorizationCodeGrantAuthorization 实体
import java.security.Principal;
import org.springframework.security.oauth2.core.endpoint.OAuth2AuthorizationRequest;
public class OAuth2AuthorizationCodeGrantAuthorization extends OAuth2AuthorizationGrantAuthorization {
	private final Principal principal;
	private final OAuth2AuthorizationRequest authorizationRequest;
	private final AuthorizationCode authorizationCode;
	@Indexed
	private final String state; // Used to correlate the request during the authorization
								// consent flow
	public OAuth2AuthorizationCodeGrantAuthorization(String id, String registeredClientId, String principalName,
			Set<String> authorizedScopes, AccessToken accessToken, RefreshToken refreshToken, Principal principal,
			OAuth2AuthorizationRequest authorizationRequest, AuthorizationCode authorizationCode, String state) {
		super(id, registeredClientId, principalName, authorizedScopes, accessToken, refreshToken);
		this.principal = principal;
		this.authorizationRequest = authorizationRequest;
		this.authorizationCode = authorizationCode;
		this.state = state;
	public Principal getPrincipal() {
		return this.principal;
	public OAuth2AuthorizationRequest getAuthorizationRequest() {
		return this.authorizationRequest;
	public AuthorizationCode getAuthorizationCode() {
		return this.authorizationCode;
	public String getState() {
		return this.state;
	public static class AuthorizationCode extends AbstractToken {
		public AuthorizationCode(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated) {
授权码授予实体 (OpenID Connect 1.0)
下面的清单显示了OidcAuthorizationCodeGrantAuthorizationentity,它扩展了OAuth2AuthorizationCodeGrantAuthorization,并定义 OpenID Connect 1.0 的其他属性authorization_code授权类型。spring-doc.cadn.net.cn
OidcAuthorizationCodeGrantAuthorization 实体
public class OidcAuthorizationCodeGrantAuthorization extends OAuth2AuthorizationCodeGrantAuthorization {
	private final IdToken idToken;
	public OidcAuthorizationCodeGrantAuthorization(String id, String registeredClientId, String principalName,
			OAuth2AuthorizationRequest authorizationRequest, AuthorizationCode authorizationCode, String state,
			IdToken idToken) {
		super(id, registeredClientId, principalName, authorizedScopes, accessToken, refreshToken, principal,
				authorizationRequest, authorizationCode, state);
		this.idToken = idToken;
	public IdToken getIdToken() {
		return this.idToken;
	public static class IdToken extends AbstractToken {
		public IdToken(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated,
			return this.claims;
客户端凭据授予实体
下面的清单显示了OAuth2ClientCredentialsGrantAuthorizationentity,它扩展了OAuth2AuthorizationGrantAuthorization,对于client_credentials授权类型。spring-doc.cadn.net.cn
OAuth2ClientCredentialsGrantAuthorization 实体
public class OAuth2ClientCredentialsGrantAuthorization extends OAuth2AuthorizationGrantAuthorization {
	public OAuth2ClientCredentialsGrantAuthorization(String id, String registeredClientId, String principalName,
			Set<String> authorizedScopes, AccessToken accessToken) {
		super(id, registeredClientId, principalName, authorizedScopes, accessToken, null);
设备代码授予实体
下面的清单显示了OAuth2DeviceCodeGrantAuthorizationentity,它扩展了OAuth2AuthorizationGrantAuthorization,并定义urn:ietf:params:oauth:grant-type:device_code授权类型。spring-doc.cadn.net.cn
OAuth2DeviceCodeGrantAuthorization 实体
public class OAuth2DeviceCodeGrantAuthorization extends OAuth2AuthorizationGrantAuthorization {
	private final DeviceCode deviceCode;
	private final UserCode userCode;
	private final Set<String> requestedScopes;
	@Indexed
	private final String deviceState; // Used to correlate the request during the
										// authorization consent flow
	public OAuth2DeviceCodeGrantAuthorization(String id, String registeredClientId, String principalName,
			DeviceCode deviceCode, UserCode userCode, Set<String> requestedScopes, String deviceState) {
		this.deviceCode = deviceCode;
		this.userCode = userCode;
		this.requestedScopes = requestedScopes;
		this.deviceState = deviceState;
	public DeviceCode getDeviceCode() {
		return this.deviceCode;
	public UserCode getUserCode() {
		return this.userCode;
	public Set<String> getRequestedScopes() {
		return this.requestedScopes;
	public String getDeviceState() {
		return this.deviceState;
	public static class DeviceCode extends AbstractToken {
		public DeviceCode(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated) {
	public static class UserCode extends AbstractToken {
		public UserCode(String tokenValue, Instant issuedAt, Instant expiresAt, boolean invalidated) {
Tokens交换赠款实体
下面的清单显示了OAuth2TokenExchangeGrantAuthorizationentity,它扩展了OAuth2AuthorizationGrantAuthorization,对于urn:ietf:params:oauth:grant-type:token-exchange授权类型。spring-doc.cadn.net.cn
OAuth2TokenExchangeGrantAuthorization 实体
public class OAuth2TokenExchangeGrantAuthorization extends OAuth2AuthorizationGrantAuthorization {
	public OAuth2TokenExchangeGrantAuthorization(String id, String registeredClientId, String principalName,
下面的清单显示了OAuth2UserConsent实体,用于保存从OAuth2AuthorizationConsentdomain 类。spring-doc.cadn.net.cn
OAuth2UserConsent 实体
import org.springframework.security.core.GrantedAuthority;
@RedisHash("oauth2_authorization_consent")
public class OAuth2UserConsent {
	@Id
	@Indexed
	@Indexed
	private final Set<GrantedAuthority> authorities;
	public OAuth2UserConsent(String id, String registeredClientId, String principalName,
			Set<GrantedAuthority> authorities) {
		this.id = id;
		this.authorities = authorities;
		return this.id;
	public Set<GrantedAuthority> getAuthorities() {
		return this.authorities;
创建 Spring Data 存储库
通过仔细检查每个核心服务的接口并审查Jdbc实现中,我们可以派生出支持每个接口的 Redis 版本所需的最小查询集。spring-doc.cadn.net.cn
已注册的客户端存储库
下面的清单显示了OAuth2RegisteredClientRepository,它能够找到OAuth2RegisteredClientidclientId领域。spring-doc.cadn.net.cn
OAuth2RegisteredClient存储库
import sample.redis.entity.OAuth2RegisteredClient;
import org.springframework.data.repository.CrudRepository;
import org.springframework.stereotype.Repository;
@Repository
public interface OAuth2RegisteredClientRepository extends CrudRepository<OAuth2RegisteredClient, String> {
	OAuth2RegisteredClient findByClientId(String clientId);
授权授权存储库
下面的清单显示了OAuth2AuthorizationGrantAuthorizationRepository,它能够找到OAuth2AuthorizationGrantAuthorizationidfield 以及 bystate,authorizationCode,accessToken,refreshToken,idToken,deviceState,userCodedeviceCode值。spring-doc.cadn.net.cn
import sample.redis.entity.OAuth2AuthorizationCodeGrantAuthorization;
import sample.redis.entity.OAuth2AuthorizationGrantAuthorization;
import sample.redis.entity.OAuth2DeviceCodeGrantAuthorization;
import sample.redis.entity.OidcAuthorizationCodeGrantAuthorization;
@Repository
public interface OAuth2AuthorizationGrantAuthorizationRepository
		extends CrudRepository<OAuth2AuthorizationGrantAuthorization, String> {
	<T extends OAuth2AuthorizationCodeGrantAuthorization> T findByState(String state);
	<T extends OAuth2AuthorizationCodeGrantAuthorization> T findByAuthorizationCode_TokenValue(String authorizationCode);
	<T extends OAuth2AuthorizationCodeGrantAuthorization> T findByStateOrAuthorizationCode_TokenValue(String state, String authorizationCode);
	<T extends OAuth2AuthorizationGrantAuthorization> T findByAccessToken_TokenValue(String accessToken);
	<T extends OAuth2AuthorizationGrantAuthorization> T findByRefreshToken_TokenValue(String refreshToken);
	<T extends OAuth2AuthorizationGrantAuthorization> T findByAccessToken_TokenValueOrRefreshToken_TokenValue(String accessToken, String refreshToken);
	<T extends OidcAuthorizationCodeGrantAuthorization> T findByIdToken_TokenValue(String idToken);
	<T extends OAuth2DeviceCodeGrantAuthorization> T findByDeviceState(String deviceState);
	<T extends OAuth2DeviceCodeGrantAuthorization> T findByDeviceCode_TokenValue(String deviceCode);
	<T extends OAuth2DeviceCodeGrantAuthorization> T findByUserCode_TokenValue(String userCode);
	<T extends OAuth2DeviceCodeGrantAuthorization> T findByDeviceStateOrDeviceCode_TokenValueOrUserCode_TokenValue(String deviceState, String deviceCode, String userCode);
下面的清单显示了OAuth2UserConsentRepository,它能够查找和删除OAuth2UserConsentregisteredClientIdprincipalName构成复合主键的字段。spring-doc.cadn.net.cn
OAuth2UserConsentRepository (OAuth2用户同意存储库)
import sample.redis.entity.OAuth2UserConsent;
@Repository
public interface OAuth2UserConsentRepository extends CrudRepository<OAuth2UserConsent, String> {
	OAuth2UserConsent findByRegisteredClientIdAndPrincipalName(String registeredClientId, String principalName);
	void deleteByRegisteredClientIdAndPrincipalName(String registeredClientId, String principalName);
实施核心服务
有了上述实体存储库,我们可以开始实施核心服务。spring-doc.cadn.net.cn
核心服务使用ModelMapper用于与 Domain 对象之间进行转换的实用程序类(例如RegisteredClient) 转换为实体模型表示形式(例如OAuth2RegisteredClient).
已注册的客户端存储库
下面的清单显示了RedisRegisteredClientRepository,它使用OAuth2RegisteredClientRepository用于持久化OAuth2RegisteredClient以及RegisteredClientdomain 对象,使用ModelMapperUtility 类。spring-doc.cadn.net.cn
RedisRegisteredClientRepository 存储库
import sample.redis.repository.OAuth2RegisteredClientRepository;
import org.springframework.lang.Nullable;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClient;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClientRepository;
import org.springframework.util.Assert;
public class RedisRegisteredClientRepository implements RegisteredClientRepository {
	private final OAuth2RegisteredClientRepository registeredClientRepository;
	public RedisRegisteredClientRepository(OAuth2RegisteredClientRepository registeredClientRepository) {
		Assert.notNull(registeredClientRepository, "registeredClientRepository cannot be null");
		this.registeredClientRepository = registeredClientRepository;
	public void save(RegisteredClient registeredClient) {
		Assert.notNull(registeredClient, "registeredClient cannot be null");
		OAuth2RegisteredClient oauth2RegisteredClient = ModelMapper.convertOAuth2RegisteredClient(registeredClient);
		this.registeredClientRepository.save(oauth2RegisteredClient);
	@Nullable
	public RegisteredClient findById(String id) {
		Assert.hasText(id, "id cannot be empty");
		return this.registeredClientRepository.findById(id).map(ModelMapper::convertRegisteredClient).orElse(null);
	@Nullable
	public RegisteredClient findByClientId(String clientId) {
		Assert.hasText(clientId, "clientId cannot be empty");
		OAuth2RegisteredClient oauth2RegisteredClient = this.registeredClientRepository.findByClientId(clientId);
		return oauth2RegisteredClient != null ? ModelMapper.convertRegisteredClient(oauth2RegisteredClient) : null;
授权服务
下面的清单显示了RedisOAuth2AuthorizationService,它使用OAuth2AuthorizationGrantAuthorizationRepository用于持久化OAuth2AuthorizationGrantAuthorization以及OAuth2Authorizationdomain 对象,使用ModelMapperUtility 类。spring-doc.cadn.net.cn
import sample.redis.repository.OAuth2AuthorizationGrantAuthorizationRepository;
import org.springframework.security.oauth2.core.endpoint.OAuth2ParameterNames;
import org.springframework.security.oauth2.core.oidc.endpoint.OidcParameterNames;
import org.springframework.security.oauth2.server.authorization.OAuth2Authorization;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationService;
import org.springframework.security.oauth2.server.authorization.OAuth2TokenType;
public class RedisOAuth2AuthorizationService implements OAuth2AuthorizationService {
	private final RegisteredClientRepository registeredClientRepository;
	private final OAuth2AuthorizationGrantAuthorizationRepository authorizationGrantAuthorizationRepository;
	public RedisOAuth2AuthorizationService(RegisteredClientRepository registeredClientRepository,
			OAuth2AuthorizationGrantAuthorizationRepository authorizationGrantAuthorizationRepository) {
		Assert.notNull(authorizationGrantAuthorizationRepository,
				"authorizationGrantAuthorizationRepository cannot be null");
		this.authorizationGrantAuthorizationRepository = authorizationGrantAuthorizationRepository;
	public void save(OAuth2Authorization authorization) {
		Assert.notNull(authorization, "authorization cannot be null");
		OAuth2AuthorizationGrantAuthorization authorizationGrantAuthorization = ModelMapper
			.convertOAuth2AuthorizationGrantAuthorization(authorization);
		this.authorizationGrantAuthorizationRepository.save(authorizationGrantAuthorization);
	public void remove(OAuth2Authorization authorization) {
		this.authorizationGrantAuthorizationRepository.deleteById(authorization.getId());
	@Nullable
	public OAuth2Authorization findById(String id) {
		return this.authorizationGrantAuthorizationRepository.findById(id)
			.map(this::toOAuth2Authorization)
			.orElse(null);
	@Nullable
	public OAuth2Authorization findByToken(String token, OAuth2TokenType tokenType) {
		Assert.hasText(token, "token cannot be empty");
		OAuth2AuthorizationGrantAuthorization authorizationGrantAuthorization = null;
		if (tokenType == null) {
			authorizationGrantAuthorization = this.authorizationGrantAuthorizationRepository
				.findByStateOrAuthorizationCode_TokenValue(token, token);
			if (authorizationGrantAuthorization == null) {
						.findByAccessToken_TokenValueOrRefreshToken_TokenValue(token, token);
						.findByIdToken_TokenValue(token);
						.findByDeviceStateOrDeviceCode_TokenValueOrUserCode_TokenValue(token, token, token);
		else if (OAuth2ParameterNames.STATE.equals(tokenType.getValue())) {
			authorizationGrantAuthorization = this.authorizationGrantAuthorizationRepository.findByState(token);
					.findByDeviceState(token);
		else if (OAuth2ParameterNames.CODE.equals(tokenType.getValue())) {
				.findByAuthorizationCode_TokenValue(token);
		else if (OAuth2TokenType.ACCESS_TOKEN.equals(tokenType)) {
				.findByAccessToken_TokenValue(token);
		else if (OidcParameterNames.ID_TOKEN.equals(tokenType.getValue())) {
		else if (OAuth2TokenType.REFRESH_TOKEN.equals(tokenType)) {
				.findByRefreshToken_TokenValue(token);
		else if (OAuth2ParameterNames.USER_CODE.equals(tokenType.getValue())) {
				.findByUserCode_TokenValue(token);
		else if (OAuth2ParameterNames.DEVICE_CODE.equals(tokenType.getValue())) {
				.findByDeviceCode_TokenValue(token);
		return authorizationGrantAuthorization != null ? toOAuth2Authorization(authorizationGrantAuthorization) : null;
	private OAuth2Authorization toOAuth2Authorization(
			OAuth2AuthorizationGrantAuthorization authorizationGrantAuthorization) {
		RegisteredClient registeredClient = this.registeredClientRepository
			.findById(authorizationGrantAuthorization.getRegisteredClientId());
		OAuth2Authorization.Builder builder = OAuth2Authorization.withRegisteredClient(registeredClient);
		ModelMapper.mapOAuth2AuthorizationGrantAuthorization(authorizationGrantAuthorization, builder);
		return builder.build();
下面的清单显示了RedisOAuth2AuthorizationConsentService,它使用OAuth2UserConsentRepository用于持久化OAuth2UserConsent以及OAuth2AuthorizationConsentdomain 对象,使用ModelMapperUtility 类。spring-doc.cadn.net.cn
import sample.redis.repository.OAuth2UserConsentRepository;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationConsent;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationConsentService;
public class RedisOAuth2AuthorizationConsentService implements OAuth2AuthorizationConsentService {
	private final OAuth2UserConsentRepository userConsentRepository;
	public RedisOAuth2AuthorizationConsentService(OAuth2UserConsentRepository userConsentRepository) {
		Assert.notNull(userConsentRepository, "userConsentRepository cannot be null");
		this.userConsentRepository = userConsentRepository;
	public void save(OAuth2AuthorizationConsent authorizationConsent) {
		Assert.notNull(authorizationConsent, "authorizationConsent cannot be null");
		OAuth2UserConsent oauth2UserConsent = ModelMapper.convertOAuth2UserConsent(authorizationConsent);
		this.userConsentRepository.save(oauth2UserConsent);
	public void remove(OAuth2AuthorizationConsent authorizationConsent) {
		this.userConsentRepository.deleteByRegisteredClientIdAndPrincipalName(
				authorizationConsent.getRegisteredClientId(), authorizationConsent.getPrincipalName());
	@Nullable
	public OAuth2AuthorizationConsent findById(String registeredClientId, String principalName) {
		Assert.hasText(registeredClientId, "registeredClientId cannot be empty");
		Assert.hasText(principalName, "principalName cannot be empty");
		OAuth2UserConsent oauth2UserConsent = this.userConsentRepository
			.findByRegisteredClientIdAndPrincipalName(registeredClientId, principalName);
		return oauth2UserConsent != null ? ModelMapper.convertOAuth2AuthorizationConsent(oauth2UserConsent) : null;
配置核心服务
以下示例显示如何配置核心服务:spring-doc.cadn.net.cn
RedisConfig 协议
import java.util.Arrays;
import sample.redis.convert.BytesToClaimsHolderConverter;
import sample.redis.convert.BytesToOAuth2AuthorizationRequestConverter;
import sample.redis.convert.BytesToUsernamePasswordAuthenticationTokenConverter;
import sample.redis.convert.ClaimsHolderToBytesConverter;
import sample.redis.convert.OAuth2AuthorizationRequestToBytesConverter;
import sample.redis.convert.UsernamePasswordAuthenticationTokenToBytesConverter;
import sample.redis.service.RedisOAuth2AuthorizationConsentService;
import sample.redis.service.RedisOAuth2AuthorizationService;
import sample.redis.service.RedisRegisteredClientRepository;
import org.springframework.data.redis.connection.RedisConnectionFactory;
import org.springframework.data.redis.connection.jedis.JedisConnectionFactory;
import org.springframework.data.redis.core.RedisTemplate;
import org.springframework.data.redis.core.convert.RedisCustomConversions;
import org.springframework.data.redis.repository.configuration.EnableRedisRepositories;
@EnableRedisRepositories("sample.redis.repository")	(1)
public class RedisConfig {
	public RedisConnectionFactory redisConnectionFactory() {
		return new JedisConnectionFactory();	(2)
	public RedisTemplate<?, ?> redisTemplate(RedisConnectionFactory redisConnectionFactory) {
		RedisTemplate<byte[], byte[]> redisTemplate = new RedisTemplate<>();
		redisTemplate.setConnectionFactory(redisConnectionFactory);
		return redisTemplate;
	public RedisCustomConversions redisCustomConversions() {	(3)
		return new RedisCustomConversions(Arrays.asList(new UsernamePasswordAuthenticationTokenToBytesConverter(),
				new BytesToUsernamePasswordAuthenticationTokenConverter(),
				new OAuth2AuthorizationRequestToBytesConverter(), new BytesToOAuth2AuthorizationRequestConverter(),
				new ClaimsHolderToBytesConverter(), new BytesToClaimsHolderConverter()));
	public RedisRegisteredClientRepository registeredClientRepository(
		return new RedisRegisteredClientRepository(registeredClientRepository);	(4)
	public RedisOAuth2AuthorizationService authorizationService(RegisteredClientRepository registeredClientRepository,
		return new RedisOAuth2AuthorizationService(registeredClientRepository,
				authorizationGrantAuthorizationRepository);	(5)
	public RedisOAuth2AuthorizationConsentService authorizationConsentService(
		return new RedisOAuth2AuthorizationConsentService(userConsentRepository);	(6)
1 sample.redis.repositorybase 软件包。
2 使用 Jedis 连接器。
3 注册自定义Converter在持久保存到 Redis 之前执行 Object-to-Hash 转换。
4 注册RedisRegisteredClientRepository激活OAuth2RegisteredClientRepository.
5 注册RedisOAuth2AuthorizationService激活OAuth2AuthorizationGrantAuthorizationRepository.
6 注册RedisOAuth2AuthorizationConsentService激活OAuth2UserConsentRepository.
