V2.3 在单个应用程序与多个代理或代理集群之间通信时增加了更多便利性。 在消费者方面,主要好处是基础设施可以自动将自动声明的队列与相应的代理相关联。
最好用一个例子来说明这一点:
@SpringBootApplication(exclude = RabbitAutoConfiguration.class)
public class Application {
SpringApplication.run(Application.class, args);
CachingConnectionFactory cf1() {
return new CachingConnectionFactory("localhost");
CachingConnectionFactory cf2() {
return new CachingConnectionFactory("otherHost");
CachingConnectionFactory cf3() {
return new CachingConnectionFactory("thirdHost");
SimpleRoutingConnectionFactory rcf(CachingConnectionFactory cf1,
CachingConnectionFactory cf2, CachingConnectionFactory cf3) {
SimpleRoutingConnectionFactory rcf = new SimpleRoutingConnectionFactory();
rcf.setDefaultTargetConnectionFactory(cf1);
rcf.setTargetConnectionFactories(Map.of("one", cf1, "two", cf2, "three", cf3));
return rcf;
@Bean("factory1-admin")
RabbitAdmin admin1(CachingConnectionFactory cf1) {
return new RabbitAdmin(cf1);
@Bean("factory2-admin")
RabbitAdmin admin2(CachingConnectionFactory cf2) {
return new RabbitAdmin(cf2);
@Bean("factory3-admin")
RabbitAdmin admin3(CachingConnectionFactory cf3) {
return new RabbitAdmin(cf3);
public RabbitListenerEndpointRegistry rabbitListenerEndpointRegistry() {
return new RabbitListenerEndpointRegistry();
public RabbitListenerAnnotationBeanPostProcessor postProcessor(RabbitListenerEndpointRegistry registry) {
MultiRabbitListenerAnnotationBeanPostProcessor postProcessor
= new MultiRabbitListenerAnnotationBeanPostProcessor();
postProcessor.setEndpointRegistry(registry);
postProcessor.setContainerFactoryBeanName("defaultContainerFactory");
return postProcessor;
public SimpleRabbitListenerContainerFactory factory1(CachingConnectionFactory cf1) {
SimpleRabbitListenerContainerFactory factory = new SimpleRabbitListenerContainerFactory();
factory.setConnectionFactory(cf1);
return factory;
public SimpleRabbitListenerContainerFactory factory2(CachingConnectionFactory cf2) {
factory.setConnectionFactory(cf2);
return factory;
public SimpleRabbitListenerContainerFactory factory3(CachingConnectionFactory cf3) {
factory.setConnectionFactory(cf3);
return factory;
RabbitTemplate template(SimpleRoutingConnectionFactory rcf) {
return new RabbitTemplate(rcf);
ConnectionFactoryContextWrapper wrapper(SimpleRoutingConnectionFactory rcf) {
return new ConnectionFactoryContextWrapper(rcf);
@Component
class Listeners {
@RabbitListener(queuesToDeclare = @Queue("q1"), containerFactory = "factory1")
public void listen1(String in) {
@RabbitListener(queuesToDeclare = @Queue("q2"), containerFactory = "factory2")
public void listen2(String in) {
@RabbitListener(queuesToDeclare = @Queue("q3"), containerFactory = "factory3")
public void listen3(String in) {
正如你所看到的,我们已经声明了 3 组基础设施(连接工厂、管理员、容器工厂)。
如前所述,可以定义使用哪个容器工厂;在这种情况下,他们还使用 which 导致在代理上声明队列(如果它不存在)。
通过使用约定命名 bean,基础结构能够确定哪个管理员应该声明队列。
这也将与交换和约束声明一起使用。
它不适用于 ,因为这需要队列已经存在。@RabbitListener
queuesToDeclare
RabbitAdmin
<container-factory-name>-admin
bindings = @QueueBinding(…)
queues
在生产者端,提供了一个方便的类,使使用(请参阅路由连接工厂)更简单。ConnectionFactoryContextWrapper
如上图所示,添加了一个带有路由键的 Bean 和 。
还有一个使用该工厂。
下面是将该模板与包装器一起路由到其中一个代理集群的示例。SimpleRoutingConnectionFactory
one
two
three
RabbitTemplate
public ApplicationRunner runner(RabbitTemplate template, ConnectionFactoryContextWrapper wrapper) {
return args -> {
wrapper.run("one", () -> template.convertAndSend("q1", "toCluster1"));
wrapper.run("two", () -> template.convertAndSend("q2", "toCluster2"));
wrapper.run("three", () -> template.convertAndSend("q3", "toCluster3"));
