11. 调用子流
一个流可以调用另一个流作为子流。 流将等待,直到子流返回并响应子流结果。
11.1. 该subflow-state
元素
这subflow-state
元素将另一个流作为子流调用,如下所示:
<subflow-state id="addGuest" subflow="createGuest">
<transition on="guestCreated" to="reviewBooking">
<evaluate expression="booking.guests.add(currentEvent.attributes.guest)" />
</transition>
<transition on="creationCancelled" to="reviewBooking" />
</subflow-state>
前面的示例调用createGuest
flow 并等待它返回。
当流返回guestCreated
结果,新房客将被添加到预订的房客名单中。
11.2. 检查点:调用子流
您应查看调用子流的示例预订流:
<flow xmlns="http://www.springframework.org/schema/webflow"
xsi:schemaLocation="http://www.springframework.org/schema/webflow
https://www.springframework.org/schema/webflow/spring-webflow.xsd">
<input name="hotelId" />
<on-start>
<evaluate expression="bookingService.createBooking(hotelId, currentUser.name)"
result="flowScope.booking" />
</on-start>
<view-state id="enterBookingDetails">
<transition on="submit" to="reviewBooking" />
</view-state>
<view-state id="reviewBooking">
<transition on="addGuest" to="addGuest" />
<transition on="confirm" to="bookingConfirmed" />
<transition on="revise" to="enterBookingDetails" />
<transition on="cancel" to="bookingCancelled" />
</view-state>
</transition>
</subflow-state>
<end-state id="bookingConfirmed" >
<output name="bookingId" value="booking.id" />
</end-state>
<end-state id="bookingCancelled" />
</flow>
该流现在调用createGuest
sub-flow 将新访客添加到访客列表中。
