This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Vault 3.2.0!spring-doc.cn
Getting Started
Spring Vault support requires Vault 0.6 or higher and Java SE 6 or higher. An easy way to bootstrap setting up a working environment is to create a Spring based project in STS.spring-doc.cn
First you need to set up a running Vault server. Refer to the Vault for an explanation on how to startup a Vault instance.spring-doc.cn
To create a Spring project in STS go to File → New → Spring Template Project → Simple Spring Utility Project → press Yes when prompted. Then enter a project and a package name such as org.spring.vault.example.spring-doc.cn
Then add the following to pom.xml dependencies section.spring-doc.cn
Example 1. Adding Spring Vault dependency
<dependencies>
  <!-- other dependency elements omitted -->
  <dependency>
    <groupId>org.springframework.vault</groupId>
    <artifactId>spring-vault-core</artifactId>
    <version>4.0.0-SNAPSHOT</version>
  </dependency>
</dependencies>
If you are using a milestone or release candidate, you will also need to add the location of the Spring Milestone repository to your maven pom.xml which is at the same level of your <dependencies/> element.spring-doc.cn
<repositories>
  <repository>
    <id>spring-milestone</id>
    <name>Spring Maven MILESTONE Repository</name>
    <url>https://repo.spring.io/milestone</url>
  </repository>
</repositories>
The repository is also browseable here.spring-doc.cn
If you are using a SNAPSHOT, you will also need to add the location of the Spring Snapshot repository to your maven pom.xml which is at the same level of your <dependencies/> element.spring-doc.cn
<repositories>
  <repository>
    <id>spring-snapshot</id>
    <name>Spring Maven SNAPSHOT Repository</name>
    <url>https://repo.spring.io/snapshot</url>
  </repository>
</repositories>
Create a simple Secrets class to persist:spring-doc.cn
Example 2. Mapped data object
package org.spring.vault.example;
public class Secrets {
    String username;
    String password;
    public String getUsername() {
        return username;
    public String getPassword() {
        return password;
And a main application to runspring-doc.cn
Example 3. Example application using Spring Vault
package org.springframework.vault.example;
import org.springframework.vault.authentication.TokenAuthentication;
import org.springframework.vault.client.VaultEndpoint;
import org.springframework.vault.core.VaultTemplate;
import org.springframework.vault.support.VaultResponseSupport;
public class VaultApp {
        VaultTemplate vaultTemplate = new VaultTemplate(new VaultEndpoint(),
                new TokenAuthentication("00000000-0000-0000-0000-000000000000"));
        Secrets secrets = new Secrets();
        secrets.username = "hello";
        secrets.password = "world";
        vaultTemplate.write("secret/myapp", secrets);
        VaultResponseSupport<Secrets> response = vaultTemplate.read("secret/myapp", Secrets.class);
        System.out.println(response.getData().getUsername());
        vaultTemplate.delete("secret/myapp");
Even in this simple example, there are few things to take notice ofspring-doc.cn
  • You can instantiate the central class of Spring Vault, VaultTemplate, using the org.springframework.vault.client.VaultEndpoint object and the ClientAuthentication. You are not required to spin up a Spring Context to use Spring Vault.spring-doc.cn
  • Vault is expected to be configured with a root token of 00000000-0000-0000-0000-000000000000 to run this application.spring-doc.cn
  • The mapper works against standard POJO objects without the need for any additional metadata (though you can optionally provide that information).spring-doc.cn
  • Mapping conventions can use field access. Notice the Secrets class has only getters.spring-doc.cn
  • If the constructor argument names match the field names of the stored document, they will be used to instantiate the object.spring-doc.cn
