This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Vault 3.2.0!spring-doc.cn
Dependencies
If you want to use Spring Vault in your project, declare a dependency to the spring-vault-core artifact.spring-doc.cn
Example 1. Declaring a dependency to Spring Vault
<dependencies>
    <dependency>
        <groupId>org.springframework.vault</groupId>
        <artifactId>spring-vault-core</artifactId>
        <version>4.0.0-SNAPSHOT</version>
    </dependency>
</dependencies>
The easiest way to find compatible versions of Spring Vault dependencies is by inspecting the properties section of spring-vault-parent. We generally recommend upgrading to the latest dependency of Jackson, your HTTP clients and your Cloud provider SDK.spring-doc.cn
Spring Framework
The current version of Spring Vault requires Spring Framework in version 7.0.0-M2 or newer. The modules might also work with an older bugfix version of that minor version. However, using the most recent version within that generation is highly recommended.spring-doc.cn
