For the latest stable version, please use Spring Vault 3.2.0! |
New & Noteworthy
What’s new in Spring Vault 3.0
Upgrade to Spring Framework 6 and Java 17 baseline
Upgrade to AWS SDK 2.
What’s new in Spring Vault 2.4
Support for Username/Password authentication for Username/Password, LDAP, Okta, and RADIUS authentication.
Support of versioned Key/Value secrets engines for Vault repositories.
Optimistic locking support through Vault repositories using versioned Key/Value secrets engines.
What’s new in Spring Vault 2.3
Support for PEM-encoded certificates for keystore and truststore usage.
ReactiveVaultEndpointProvider
for non-blocking lookup ofVaultEndpoint
VaultKeyValueMetadataOperations
for Key-Value metadata interaction. -
Support for
transform
secrets engine (Enterprise Feature). -
Documentation of how to use Vault secret backends.
Login credentials for Kubernetes and PCF authentication are reloaded for each login attempt.
SecretLeaseContainer
publishesSecretLeaseRotatedEvent
instead ofSecretLeaseExpiredEvent
andSecretLeaseCreatedEvent
on successful secret rotation. -
AbstractVaultConfiguration.threadPoolTaskScheduler()
bean type changed toTaskSchedulerWrapper
instead ofThreadPoolTaskScheduler
Since 2.3.2:
GcpIamCredentialsAuthentication
What’s new in Spring Vault 2.2
Support for Key-Value v2 (versioned secrets engine) secrets through
@VaultPropertySource
SpEL support in
@Secret
Add support for Jetty as reactive HttpClient.
LifecycleAwareSessionManager
andReactiveLifecycleAwareSessionManager
emit nowAuthenticationEvent
s. -
Deprecation of
AppIdAuthentication
. UseAppRoleAuthentication
instead as recommended by HashiCorp Vault. -
CubbyholeAuthentication
and wrappedAppRoleAuthentication
now usesys/wrapping/unwrap
endpoints by default. -
Kotlin Coroutines support for
ReactiveVaultOperations
What’s new in Spring Vault 2.1
GCP Compute, GCP IAM, and Azure authentication.
Template API support for versioned and unversioned Key/Value secrets engines and for Vault wrapping operations.
Support full pull mode in reactive AppRole authentication.
Improved Exception hierarchy for Vault login failures.
What’s new in Spring Vault 2.0
Authentication steps DSL to compose authentication flows.
Reactive Vault client via
Vault repository support based on Spring Data KeyValue.
Transit batch encrypt and decrypt support.
Policy management for policies stored as JSON.
Support CSR signing, certificate revocation and CRL retrieval.
RoleId/SecretId unwrapping for AppRole authentication.
Spring Security integration with transit secrets engine-based
BytesKeyGenerator
andBytesEncryptor
What’s new in Spring Vault 1.1.0
AWS IAM authentication.
Configuration of encryption/decryption versions for transit keys.
Pull mode for AppRole authentication.
TTL-based generic secret rotation.
