State Machine Examples
This part of the reference documentation explains the use of state machines together with sample code and UML state charts. We use a few shortcuts when representing the relationship between a state chart, Spring Statemachine configuration, and what an application does with a state machine. For complete examples, you should study the samples repository.
Samples are built directly from a main source distribution during a normal build cycle. This chapter includes the following samples:
The following listing shows how to build the samples:
./gradlew clean build -x test
Every sample is located in its own directory under
spring-statemachine-samples
. The samples are based on Spring Boot and
Spring Shell, and you can find the usual Boot fat jars under every sample
project’s build/libs
directory.
The filenames for the jars to which we refer in this section are populated during a
build of this document, meaning that, if you build samples from
main, you have files with a BUILD-SNAPSHOT postfix.
Turnstile
Turnstile is a simple device that gives you access if payment is
made. It is a concept that is simple to model using a state machine. In its
simplest, form there are only two states: LOCKED
and UNLOCKED
. Two
events, COIN
and PUSH
can happen, depending on whether someone
makes a payment or tries to go through the turnstile.
The following image shows the state machine:
The following listing shows the enumeration that defines the possible states:
public enum States {
LOCKED, UNLOCKED
The following listing shows the enumeration that defines the events:
public enum Events {
COIN, PUSH
The following listing shows the code that configures the state machine:
@EnableStateMachine
static class StateMachineConfig
extends EnumStateMachineConfigurerAdapter<States, Events> {
public void configure(StateMachineStateConfigurer<States, Events> states)
throws Exception {
states
.withStates()
.initial(States.LOCKED)
.states(EnumSet.allOf(States.class));
public void configure(StateMachineTransitionConfigurer<States, Events> transitions)
throws Exception {
transitions
.withExternal()
.source(States.LOCKED)
.target(States.UNLOCKED)
.event(Events.COIN)
.and()
.withExternal()
.source(States.UNLOCKED)
.target(States.LOCKED)
.event(Events.PUSH);
You can see how this sample state machine interacts with events by
running the turnstile
sample. The following listing shows how to do so
and shows the command’s output:
$ java -jar spring-statemachine-samples-turnstile-4.0.0.jar
sm>sm print
| SM |
| *-->| LOCKED | | UNLOCKED | |
| +---| entry/ | | entry/ |---+ |
| | | exit/ | | exit/ | | |
| PUSH| | |---COIN-->| | |COIN |
| | | |<--PUSH---| | | |
sm>sm start
State changed to LOCKED
State machine started
sm>sm event COIN
State changed to UNLOCKED
Event COIN send
sm>sm event PUSH
Event PUSH send
Turnstile Reactive
Turnstile reactive is an enhacement to Turnstile sample using same StateMachine concept and adding a reactive web layer communicating reactively with a StateMachine reactive interfaces.
StateMachineController
is a simple @RestController
where we autowire our StateMachine
@Autowired
private StateMachine<States, Events> stateMachine;
We create first mapping to return a machine state. As state doesn’t come out from
a machine reactively, we can defer it so that when a returned Mono
is subscribed,
actual state is requested.
@GetMapping("/state")
public Mono<States> state() {
return Mono.defer(() -> Mono.justOrEmpty(stateMachine.getState().getId()));
To send a single event or multiple events to a machine we can use a Flux
in both
incoming and outgoing layers. EventResult
here is just for this sample and simply
wraps ResultType
and event.
@PostMapping("/events")
public Flux<EventResult> events(@RequestBody Flux<EventData> eventData) {
return eventData
.filter(ed -> ed.getEvent() != null)
.map(ed -> MessageBuilder.withPayload(ed.getEvent()).build())
.flatMap(m -> stateMachine.sendEvent(Mono.just(m)))
.map(EventResult::new);
You can use the following command to run the sample:
$ java -jar spring-statemachine-samples-turnstilereactive-4.0.0.jar
Example of getting a state:
GET http://localhost:8080/state
Would then response:
"LOCKED"
Example of sending an event:
POST http://localhost:8080/events
content-type: application/json
"event": "COIN"
"event": "COIN",
"resultType": "ACCEPTED"
You can post multiple events:
"event": "COIN"
"event": "PUSH"
Response then contains results for both events:
"event": "COIN",
"event": "PUSH",
Showcase
Showcase is a complex state machine that shows all possible transition topologies up to four levels of state nesting. The following image shows the state machine:
S0, S1, S11, S12, S2, S21, S211, S212
A, B, C, D, E, F, G, H, I
throws Exception {
states
.withStates()
.initial(States.S0, fooAction())
.state(States.S0)
.and()
.withStates()
.parent(States.S0)
.initial(States.S1)
.state(States.S1)
.and()
.withStates()
.parent(States.S1)
.initial(States.S11)
.state(States.S11)
.state(States.S12)
.and()
.withStates()
.parent(States.S0)
.state(States.S2)
.and()
.withStates()
.parent(States.S2)
.initial(States.S21)
.state(States.S21)
.and()
.withStates()
.parent(States.S21)
.initial(States.S211)
.state(States.S211)
.state(States.S212);
The following listing shows the code that configures the state machine’s transitions:
throws Exception {
transitions
.withExternal()
.source(States.S1).target(States.S1).event(Events.A)
.guard(foo1Guard())
.and()
.withExternal()
.source(States.S1).target(States.S11).event(Events.B)
.and()
.withExternal()
.source(States.S21).target(States.S211).event(Events.B)
.and()
.withExternal()
.source(States.S1).target(States.S2).event(Events.C)
.and()
.withExternal()
.source(States.S2).target(States.S1).event(Events.C)
.and()
.withExternal()
.source(States.S1).target(States.S0).event(Events.D)
.and()
.withExternal()
.source(States.S211).target(States.S21).event(Events.D)
.and()
.withExternal()
.source(States.S0).target(States.S211).event(Events.E)
.and()
.withExternal()
.source(States.S1).target(States.S211).event(Events.F)
.and()
.withExternal()
.source(States.S2).target(States.S11).event(Events.F)
.and()
.withExternal()
.source(States.S11).target(States.S211).event(Events.G)
.and()
.withExternal()
.source(States.S211).target(States.S0).event(Events.G)
.and()
.withInternal()
.source(States.S0).event(Events.H)
.guard(foo0Guard())
.action(fooAction())
.and()
.withInternal()
.source(States.S2).event(Events.H)
.guard(foo1Guard())
.and()
.withInternal()
.source(States.S1).event(Events.H)
.and()
.withExternal()
.source(States.S11).target(States.S12).event(Events.I)
.and()
.withExternal()
.source(States.S211).target(States.S212).event(Events.I)
.and()
.withExternal()
.source(States.S12).target(States.S212).event(Events.I);
The following listing shows the code that configures the state machine’s actions and guards:
public FooGuard foo0Guard() {
return new FooGuard(0);
public FooGuard foo1Guard() {
return new FooGuard(1);
public FooAction fooAction() {
return new FooAction();
The following listing shows how the single action is defined:
private static class FooAction implements Action<States, Events> {
public void execute(StateContext<States, Events> context) {
Map<Object, Object> variables = context.getExtendedState().getVariables();
Integer foo = context.getExtendedState().get("foo", Integer.class);
if (foo == null) {
log.info("Init foo to 0");
variables.put("foo", 0);
} else if (foo == 0) {
log.info("Switch foo to 1");
variables.put("foo", 1);
} else if (foo == 1) {
log.info("Switch foo to 0");
The following listing shows how the single guard is defined:
private static class FooGuard implements Guard<States, Events> {
private final int match;
public FooGuard(int match) {
this.match = match;
public boolean evaluate(StateContext<States, Events> context) {
Object foo = context.getExtendedState().getVariables().get("foo");
return !(foo == null || !foo.equals(match));
The following listing shows the output that this state machine produces when it runs and various events are sent to it:
sm>sm start
Init foo to 0
Entry state S0
Entry state S1
Entry state S11
sm>sm event A
Event A send
sm>sm event C
Exit state S11
Exit state S1
Entry state S2
Entry state S21
Entry state S211
Event C send
sm>sm event H
Switch foo to 1
Internal transition source=S0
Event H send
sm>sm event C
Exit state S211
Exit state S21
Exit state S2
Entry state S1
Entry state S11
Event C send
sm>sm event A
Exit state S11
Exit state S1
Entry state S1
Entry state S11
Event A send
In the preceding output, we can see that:
The state machine is started, which takes it to its initial state (
S11
) through superstates (S1
) and (S0
). Also, the extended state variable,foo
, is initialized to0
We try to execute a self transition in state
S1
with eventA
, but nothing happens because the transition is guarded by variablefoo
to be1
We send event
C
, which takes us to the other state machine, where the initial state (S211
) and its superstates are entered. In there, we can use eventH
, which does a simple internal transition to flip thefoo
variable. Then we go back by using eventC
Event
A
is sent again, and nowS1
does a self transition because the guard evaluates totrue
The following example offers a closer look at how hierarchical states and their event handling works:
sm>sm variables
No variables
sm>sm start
Init foo to 0
Entry state S0
Entry state S1
Entry state S11
sm>sm variables
foo=0
sm>sm event H
Internal transition source=S1
Event H send
sm>sm variables
foo=0
sm>sm event C
Exit state S11
Exit state S1
Entry state S2
Entry state S21
Entry state S211
Event C send
sm>sm variables
foo=0
sm>sm event H
Switch foo to 1
Event H send
sm>sm variables
foo=1
sm>sm event H
Switch foo to 0
Internal transition source=S2
Event H send
sm>sm variables
foo=0
In the preceding sample:
We print extended state variables in various stages.
With event
H
, we end up running an internal transition, which is logged with its source state. -
Note how event
H
is handled in different states (S0
,S1
, andS2
). This is a good example of how hierarchical states and their event handling works. If stateS2
is unable to handle eventH
due to a guard condition, its parent is checked next. This guarantees that, while the machine is on stateS2
, thefoo
flag is always flipped around. However, in stateS1
, eventH
always matches to its dummy transition without guard or action, so it never happens.== CD Player
CD Player is a sample which resembles a use case that many people have
used in the real world. CD Player itself is a really simple entity that allows a
user to open a deck, insert or change a disk, and then drive the player’s
functionality by pressing various buttons (eject
, play
stop
, pause
, rewind
, and backward
How many of us have really given thought to what it will take to make code that interacts with hardware to drive a CD Player. Yes, the concept of a player is simple, but, if you look behind the scenes, things actually get a bit convoluted.
You have probably noticed that, if your deck is open and you press play, the deck closes and a song starts to play (if a CD was inserted). In a sense, when the deck is open, you first need to close it and then try to start playing (again, if a CD is actually inserted). Hopefully, you have now realized that a simple CD Player is so simple. Sure, you can wrap all this with a simple class that has a few boolean variables and probably a few nested if-else clauses. That will do the job, but what about if you need to make all this behavior much more complex? Do you really want to keep adding more flags and if-else clauses?
The following image shows the state machine for our simple CD player:
The rest of this section goes through how this sample and its state machine is designed and
how those two interacts with each other. The following three configuration sections
are used within an EnumStateMachineConfigurerAdapter
throws Exception {
states
.withStates()
.initial(States.IDLE)
.state(States.IDLE)
.and()
.withStates()
.parent(States.IDLE)
.initial(States.CLOSED)
.state(States.CLOSED, closedEntryAction(), null)
.state(States.OPEN)
.and()
.withStates()
.state(States.BUSY)
.and()
.withStates()
.parent(States.BUSY)
.initial(States.PLAYING)
.state(States.PLAYING)
.state(States.PAUSED);
throws Exception {
transitions
.withExternal()
.source(States.CLOSED).target(States.OPEN).event(Events.EJECT)
.and()
.withExternal()
.source(States.OPEN).target(States.CLOSED).event(Events.EJECT)
.and()
.withExternal()
.source(States.OPEN).target(States.CLOSED).event(Events.PLAY)
.and()
.withExternal()
.source(States.PLAYING).target(States.PAUSED).event(Events.PAUSE)
.and()
.withInternal()
.action(playingAction())
.timer(1000)
.and()
.withInternal()
.source(States.PLAYING).event(Events.BACK)
.action(trackAction())
.and()
.withInternal()
.source(States.PLAYING).event(Events.FORWARD)
.and()
.withExternal()
.source(States.PAUSED).target(States.PLAYING).event(Events.PAUSE)
.and()
.withExternal()
.source(States.BUSY).target(States.IDLE).event(Events.STOP)
.and()
.withExternal()
.source(States.IDLE).target(States.BUSY).event(Events.PLAY)
.action(playAction())
.guard(playGuard())
.and()
.withInternal()
.source(States.OPEN).event(Events.LOAD).action(loadAction());
public ClosedEntryAction closedEntryAction() {
return new ClosedEntryAction();
public LoadAction loadAction() {
return new LoadAction();
public TrackAction trackAction() {
return new TrackAction();
public PlayAction playAction() {
return new PlayAction();
public PlayingAction playingAction() {
return new PlayingAction();
public PlayGuard playGuard() {
return new PlayGuard();
In the preceding configuration:
We used
to configure states and transitions. -
The
CLOSED
andOPEN
states are defined as substates ofIDLE
, and thePLAYING
andPAUSED
states are defined as substates ofBUSY
With the
CLOSED
state, we added an entry action as a bean calledclosedEntryAction
In the transitions we mostly map events to expected state transitions, such as
EJECT
closing and opening a deck andPLAY
,STOP
, andPAUSE
doing their natural transitions. For other transitions, we did the following:-
For source state
PLAYING
, we added a timer trigger, which is needed to automatically track elapsed time within a playing track and to have a facility for making the decision about when to switch the to next track. -
For the
PLAY
event, if the source state isIDLE
and the target state isBUSY
, we defined an action calledplayAction
and a guard calledplayGuard
For the
LOAD
event and theOPEN
state, we defined an internal transition with an action calledloadAction
, which tracks inserting a disc with extended-state variables. -
The
PLAYING
state defines three internal transitions. One is triggered by a timer that runs an action calledplayingAction
, which updates the extended state variables. The other two transitions usetrackAction
with different events (BACK
andFORWARD
, respectively) to handle when the user wants to go back or forward in tracks.
This machine has only have six states, which are defined by the following enumeration:
// super state of PLAYING and PAUSED
BUSY,
PLAYING,
PAUSED,
// super state of CLOSED and OPEN
IDLE,
CLOSED,
OPEN
Events represent the buttons the user can press and whether the user loads a disc into the player. The following enumeration defines the events:
PLAY, STOP, PAUSE, EJECT, LOAD, FORWARD, BACK
The cdPlayer
and library
beans are used to drive the application.
The following listing shows the definition of these two beans:
public CdPlayer cdPlayer() {
return new CdPlayer();
public Library library() {
return Library.buildSampleLibrary();
We define extended state variable keys as simple enumerations, as the following listing shows:
public enum Variables {
CD, TRACK, ELAPSEDTIME
public enum Headers {
TRACKSHIFT
We wanted to make this sample type safe, so we define our own
annotation (@StatesOnTransition
), which has a mandatory meta
annotation (@OnTransition
The following listing defines the @StatesOnTransition
annotation:
@Target(ElementType.METHOD)
@OnTransition
public @interface StatesOnTransition {
States[] source() default {};
States[] target() default {};
ClosedEntryAction
is an entry action for the CLOSED
state, to
send a PLAY
event to the state machine if a disc is present.
The following listing defines ClosedEntryAction
public static class ClosedEntryAction implements Action<States, Events> {
if (context.getTransition() != null
&& context.getEvent() == Events.PLAY
&& context.getTransition().getTarget().getId() == States.CLOSED
&& context.getExtendedState().getVariables().get(Variables.CD) != null) {
context.getStateMachine()
.sendEvent(Mono.just(MessageBuilder
.withPayload(Events.PLAY).build()))
.subscribe();
LoadAction
update an extended state variable if event
headers contain information about a disc to load.
The following listing defines LoadAction
public static class LoadAction implements Action<States, Events> {
Object cd = context.getMessageHeader(Variables.CD);
context.getExtendedState().getVariables().put(Variables.CD, cd);
PlayAction
resets the player’s elapsed time, which is kept as
an extended state variable.
The following listing defines PlayAction
public static class PlayAction implements Action<States, Events> {
context.getExtendedState().getVariables().put(Variables.ELAPSEDTIME, 0l);
context.getExtendedState().getVariables().put(Variables.TRACK, 0);
PlayGuard
guards the transition from IDLE
to BUSY
with the
PLAY
event if the CD
extended state variable does not indicate that a
disc has been loaded.
The following listing defines PlayGuard
public static class PlayGuard implements Guard<States, Events> {
ExtendedState extendedState = context.getExtendedState();
return extendedState.getVariables().get(Variables.CD) != null;
PlayingAction
updates an extended state variable called ELAPSEDTIME
, which
the player can use to read and update its LCD status display. PlayingAction
also handles
track shifting when the user goe back or forward in tracks.
The following example defines PlayingAction
public static class PlayingAction implements Action<States, Events> {
Object elapsed = variables.get(Variables.ELAPSEDTIME);
Object cd = variables.get(Variables.CD);
Object track = variables.get(Variables.TRACK);
if (elapsed instanceof Long) {
long e = ((Long)elapsed) + 1000l;
if (e > ((Cd) cd).getTracks()[((Integer) track)].getLength()*1000) {
.withPayload(Events.FORWARD)
.setHeader(Headers.TRACKSHIFT.toString(), 1).build()))
.subscribe();
} else {
variables.put(Variables.ELAPSEDTIME, e);
TrackAction
handles track shift actions when the user goes back or forward
in tracks. If a track is the last on a disc, playing is stopped and the STOP
event is sent to a state machine.
The following example defines TrackAction
public static class TrackAction implements Action<States, Events> {
Object trackshift = context.getMessageHeader(Headers.TRACKSHIFT.toString());
if (trackshift instanceof Integer && track instanceof Integer && cd instanceof Cd) {
int next = ((Integer)track) + ((Integer)trackshift);
if (next >= 0 && ((Cd)cd).getTracks().length > next) {
variables.put(Variables.ELAPSEDTIME, 0l);
variables.put(Variables.TRACK, next);
} else if (((Cd)cd).getTracks().length <= next) {
.withPayload(Events.STOP).build()))
.subscribe();
One other important aspect of state machines is that they have their
own responsibilities (mostly around handling states) and that all application
level logic should be kept outside. This means that applications need
to have a ways to interact with a state machine. Also, note
that we annotated CdPlayer
with @WithStateMachine
, which instructs a
state machine to find methods from your POJO, which are then called
with various transitions.
The following example shows how it updates its LCD status display:
@OnTransition(target = "BUSY")
public void busy(ExtendedState extendedState) {
Object cd = extendedState.getVariables().get(Variables.CD);
if (cd != null) {
cdStatus = ((Cd)cd).getName();
In the preceding example, we use the @OnTransition
annotation to hook a callback
when a transition happens with a target state of BUSY
The following listing shows how our state machine handles whether the player is closed:
@StatesOnTransition(target = {States.CLOSED, States.IDLE})
public void closed(ExtendedState extendedState) {
if (cd != null) {
} else {
cdStatus = "No CD";
trackStatus = "";
@OnTransition
(which we used in the preceding examples) can only be
used with strings that are matched from enumerations. @StatesOnTransition
lets you create your own type-safe annotations that use real enumerations.
The following example shows how this state machine actually works.
sm>sm start
Entry state IDLE
Entry state CLOSED
sm>cd lcd
No CD
sm>cd library
0: Greatest Hits
0: Bohemian Rhapsody 05:56
1: Another One Bites the Dust 03:36
1: Greatest Hits II
0: A Kind of Magic 04:22
1: Under Pressure 04:08
sm>cd eject
Exit state CLOSED
Entry state OPEN
sm>cd load 0
Loading cd Greatest Hits
sm>cd play
Exit state OPEN
Entry state CLOSED
Exit state CLOSED
Exit state IDLE
Entry state BUSY
Entry state PLAYING
sm>cd lcd
Greatest Hits Bohemian Rhapsody 00:03
sm>cd forward
sm>cd lcd
Greatest Hits Another One Bites the Dust 00:04
sm>cd stop
Exit state PLAYING
Exit state BUSY
Entry state IDLE
Entry state CLOSED
sm>cd lcd
Greatest Hits
In the preceding run:
The state machine is started, which causes the machine to be initialized.
The CD player’s LCD screen status is printed.
The CD library is printed.
The CD player’s deck is opened.
The CD with index 0 is loaded into a deck.
Play causes the deck to get closed and immediate play, because a disc was inserted.
We print the LCD status and request the next track.
We stop playing. == Tasks
The Tasks sample demonstrates parallel task handling within regions and adds error handling to either automatically or manually fix task problems before continuing back to a state where the tasks can be run again. The following image shows the Tasks state machine:
On a high level, in this state machine:
We always try to get into the
READY
state so that we can use the RUN event to execute tasks. -
Tkhe
TASKS
state, which is composed of three independent regions, has been put in the middle ofFORK
andJOIN
states, which will cause the regions to go into their initial states and to be joined by their end states. -
From the
JOIN
state, we automatically go into aCHOICE
state, which checks for the existence of error flags in extended state variables. Tasks can set these flags, and doing so gives theCHOICE
state the ability to go into theERROR
state, where errors can be handled either automatically or manually. -
The
AUTOMATIC
state inERROR
can try to automatically fix an error and goes back toREADY
if it succeeds. If the error is something what cannot be handled automatically, user intervention is needed and the machine is put into theMANUAL
state by theFALLBACK
event.
READY,
FORK, JOIN, CHOICE,
TASKS, T1, T1E, T2, T2E, T3, T3E,
ERROR, AUTOMATIC, MANUAL
RUN, FALLBACK, CONTINUE, FIX;
The following listing configures the possible states:
throws Exception {
states
.withStates()
.initial(States.READY)
.fork(States.FORK)
.state(States.TASKS)
.join(States.JOIN)
.choice(States.CHOICE)
.state(States.ERROR)
.and()
.withStates()
.parent(States.TASKS)
.initial(States.T1)
.end(States.T1E)
.and()
.withStates()
.initial(States.T2)
.end(States.T2E)
.and()
.withStates()
.initial(States.T3)
.end(States.T3E)
.and()
.withStates()
.parent(States.ERROR)
.initial(States.AUTOMATIC)
.state(States.AUTOMATIC, automaticAction(), null)
.state(States.MANUAL);
The following listing configures the possible transitions:
throws Exception {
transitions
.withExternal()
.source(States.READY).target(States.FORK)
.event(Events.RUN)
.and()
.withFork()
.source(States.FORK).target(States.TASKS)
.and()
.withExternal()
.source(States.T1).target(States.T1E)
.and()
.withExternal()
.source(States.T2).target(States.T2E)
.and()
.withExternal()
.source(States.T3).target(States.T3E)
.and()
.withJoin()
.source(States.TASKS).target(States.JOIN)
.and()
.withExternal()
.source(States.JOIN).target(States.CHOICE)
.and()
.withChoice()
.source(States.CHOICE)
.first(States.ERROR, tasksChoiceGuard())
.last(States.READY)
.and()
.withExternal()
.source(States.ERROR).target(States.READY)
.event(Events.CONTINUE)
.and()
.withExternal()
.source(States.AUTOMATIC).target(States.MANUAL)
.event(Events.FALLBACK)
.and()
.withInternal()
.source(States.MANUAL)
.action(fixAction())
.event(Events.FIX);
The following guard sends a choice entry into the ERROR
state and needs to
return TRUE
if an error has happened. This guard checks that
all extended state variables(T1
, T2
, and T3
) are TRUE
public Guard<States, Events> tasksChoiceGuard() {
return new Guard<States, Events>() {
return !(ObjectUtils.nullSafeEquals(variables.get("T1"), true)
&& ObjectUtils.nullSafeEquals(variables.get("T2"), true)
&& ObjectUtils.nullSafeEquals(variables.get("T3"), true));
The following actions below send events to the state machine to request the next step, which is either to fall back or to continue back to ready.
public Action<States, Events> automaticAction() {
return new Action<States, Events>() {
if (ObjectUtils.nullSafeEquals(variables.get("T1"), true)
&& ObjectUtils.nullSafeEquals(variables.get("T3"), true)) {
.withPayload(Events.CONTINUE).build()))
.subscribe();
} else {
.withPayload(Events.FALLBACK).build()))
.subscribe();
public Action<States, Events> fixAction() {
variables.put("T1", true);
variables.put("T2", true);
variables.put("T3", true);
.subscribe();
Default region execution is synchronous meaning a regions would be processed
sequentially. In this sample we simply want all task regions to get processed
parallel. This can be accomplished by defining RegionExecutionPolicy
public void configure(StateMachineConfigurationConfigurer<States, Events> config)
throws Exception {
config
.withConfiguration()
.regionExecutionPolicy(RegionExecutionPolicy.PARALLEL);
The following example shows how this state machine actually works:
sm>sm start
Entry state READY
sm>tasks run
Exit state READY
Entry state TASKS
run task on T2
run task on T1
run task on T3
run task on T2 done
run task on T1 done
run task on T3 done
Entry state T2
Entry state T1
Entry state T3
Exit state T2
Exit state T1
Exit state T3
Entry state T3E
Entry state T1E
Entry state T2E
Exit state TASKS
Entry state READY
In the preceding listing, we can see that tasks run multiple times. In the next listing, we introduce errors:
sm>tasks list
Tasks {T1=true, T3=true, T2=true}
sm>tasks fail T1
sm>tasks list
Tasks {T1=false, T3=true, T2=true}
sm>tasks run
Entry state TASKS
run task on T1
run task on T3
run task on T2
run task on T1 done
run task on T3 done
run task on T2 done
Entry state T1
Entry state T3
Entry state T2
Entry state T1E
Entry state T2E
Entry state T3E
Exit state TASKS
Entry state JOIN
Exit state JOIN
Entry state ERROR
Entry state AUTOMATIC
Exit state AUTOMATIC
Exit state ERROR
Entry state READY
In the preceding listing, if we simulate a failure for task T1, it is fixed automatically. In the next listing, we introduce more errors:
sm>tasks list
sm>tasks fail T2
sm>tasks run
Entry state TASKS
run task on T2
run task on T1
run task on T3
run task on T2 done
run task on T1 done
run task on T3 done
Entry state T2
Entry state T1
Entry state T3
Entry state T1E
Entry state T2E
Entry state T3E
Exit state TASKS
Entry state JOIN
Exit state JOIN
Entry state ERROR
Entry state MANUAL
sm>tasks fix
Exit state MANUAL
Exit state ERROR
Entry state READY
In the precding example, if we simulate failure for either task T2
or T3
, the state
machine goes to the MANUAL
state, where problem needs to be fixed manually
before it can go back to the READY
state.
Washer
The washer sample demonstrates how to use a history state to recover a running state configuration with a simulated power-off situation.
Anyone who has ever used a washing machine knows that if you somehow pause the program, it continue from the same state when unpaused. You can implement this kind of behavior in a state machine by using a history pseudo state. The following image shows our state machine for a washer:
RUNNING, HISTORY, END,
WASHING, RINSING, DRYING,
POWEROFF
RINSE, DRY, STOP,
RESTOREPOWER, CUTPOWER
throws Exception {
states
.withStates()
.initial(States.RUNNING)
.state(States.POWEROFF)
.end(States.END)
.and()
.withStates()
.parent(States.RUNNING)
.initial(States.WASHING)
.state(States.RINSING)
.state(States.DRYING)
.history(States.HISTORY, History.SHALLOW);
throws Exception {
transitions
.withExternal()
.source(States.WASHING).target(States.RINSING)
.event(Events.RINSE)
.and()
.withExternal()
.source(States.RINSING).target(States.DRYING)
.event(Events.DRY)
.and()
.withExternal()
.source(States.RUNNING).target(States.POWEROFF)
.event(Events.CUTPOWER)
.and()
.withExternal()
.source(States.POWEROFF).target(States.HISTORY)
.event(Events.RESTOREPOWER)
.and()
.withExternal()
.source(States.RUNNING).target(States.END)
.event(Events.STOP);
sm>sm start
Entry state RUNNING
Entry state WASHING
sm>sm event RINSE
Exit state WASHING
Entry state RINSING
Event RINSE send
sm>sm event DRY
Exit state RINSING
Entry state DRYING
Event DRY send
sm>sm event CUTPOWER
Exit state DRYING
Exit state RUNNING
Entry state POWEROFF
Event CUTPOWER send
sm>sm event RESTOREPOWER
Exit state POWEROFF
Entry state RUNNING
Entry state WASHING
Entry state DRYING
Event RESTOREPOWER send
The state machine is started, which causes machine to get initialized.
The state machine goes to RINSING state.
The state machine goes to DRYING state.
The state machine cuts power and goes to POWEROFF state.
The state is restored from the HISTORY state, which takes state machine back to its previous known state.
== Persist
Persist is a sample that uses the Persist recipe to demonstrate how database entry update logic can be controlled by a state machine.
The following image shows the state machine logic and configuration:
The following listing shows the state machine configuration:
@EnableStateMachine
extends StateMachineConfigurerAdapter<String, String> {
public void configure(StateMachineStateConfigurer<String, String> states)
throws Exception {
states
.withStates()
.initial("PLACED")
.state("PROCESSING")
.state("SENT")
.state("DELIVERED");
public void configure(StateMachineTransitionConfigurer<String, String> transitions)
throws Exception {
transitions
.withExternal()
.source("PLACED").target("PROCESSING")
.event("PROCESS")
.and()
.withExternal()
.source("PROCESSING").target("SENT")
.event("SEND")
.and()
.withExternal()
.source("SENT").target("DELIVERED")
.event("DELIVER");
The following configuration creates PersistStateMachineHandler
static class PersistHandlerConfig {
@Autowired
private StateMachine<String, String> stateMachine;
public Persist persist() {
return new Persist(persistStateMachineHandler());
public PersistStateMachineHandler persistStateMachineHandler() {
return new PersistStateMachineHandler(stateMachine);
The following listing shows the Order
class used with this sample:
public static class Order {
int id;
String state;
public Order(int id, String state) {
this.id = id;
this.state = state;
public String toString() {
return "Order [id=" + id + ", state=" + state + "]";
The following example shows the state machine’s output:
sm>persist db
Order [id=1, state=PLACED]
Order [id=2, state=PROCESSING]
Order [id=3, state=SENT]
Order [id=4, state=DELIVERED]
sm>persist process 1
Exit state PLACED
Entry state PROCESSING
sm>persist db
Order [id=1, state=PROCESSING]
sm>persist deliver 3
Exit state SENT
Entry state DELIVERED
sm>persist db
Order [id=3, state=DELIVERED]
In the preceding run, the state machine:
Listed rows from an existing embedded database, which is already populated with sample data.
Requested to update order
1
into thePROCESSING
state. -
List database entries again and see that the state has been changed from
PLACED
toPROCESSING
Update order
3
to update its state fromSENT
toDELIVERED
You may wonder where the database is, because there are literally no
signs of it in the sample code. The sample is based on Spring Boot and,
because the necessary classes are in a classpath, an embedded Spring Boot even creates an instance of
Next, we need to handle state changes. The following listing shows how we do so:
public void change(int order, String event) {
Order o = jdbcTemplate.queryForObject("select id, state from orders where id = ?",
new RowMapper<Order>() {
public Order mapRow(ResultSet rs, int rowNum) throws SQLException {
return new Order(rs.getInt("id"), rs.getString("state"));
}, new Object[] { order });
handler.handleEventWithStateReactively(MessageBuilder
.withPayload(event).setHeader("order", order).build(), o.state)
.subscribe();
Finally, we use a PersistStateChangeListener
to update the database, as the
private class LocalPersistStateChangeListener implements PersistStateChangeListener {
public void onPersist(State<String, String> state, Message<String> message,
Transition<String, String> transition, StateMachine<String, String> stateMachine) {
if (message != null && message.getHeaders().containsKey("order")) {
Integer order = message.getHeaders().get("order", Integer.class);
jdbcTemplate.update("update orders set state = ? where id = ?", state.getId(), order);
Zookeeper
Zookeeper is a distributed version from the Turnstile sample.
This sample needs an external Zookeeper instance that is accessible from
localhost and has the default port and settings.
Configuration of this sample is almost the same as the turnstile
sample. We
add only the configuration for the distributed state machine where we
configure StateMachineEnsemble
public void configure(StateMachineConfigurationConfigurer<String, String> config) throws Exception {
config
.withDistributed()
.ensemble(stateMachineEnsemble());
The actual StateMachineEnsemble
needs to be created as a bean, together
with the CuratorFramework
client, as the following example shows:
public StateMachineEnsemble<String, String> stateMachineEnsemble() throws Exception {
return new ZookeeperStateMachineEnsemble<String, String>(curatorClient(), "/foo");
public CuratorFramework curatorClient() throws Exception {
CuratorFramework client = CuratorFrameworkFactory.builder().defaultData(new byte[0])
.retryPolicy(new ExponentialBackoffRetry(1000, 3))
.connectString("localhost:2181").build();
client.start();
return client;
For the next example, we need to create two different shell instances. We need to create one instance, see what happens, and then create the second instance. The following command starts the shell instances (remember to start only one instance for now):
@n1:~# java -jar spring-statemachine-samples-zookeeper-4.0.0.jar
When state machine is started, its initial state is
LOCKED
. Then it sends a COIN
event to transition into UNLOCKED
state.
The following example shows what happens:
sm>sm start
Entry state LOCKED
sm>sm event COIN
Exit state LOCKED
Entry state UNLOCKED
Event COIN send
sm>sm state
UNLOCKED
Now you can open a second shell instance and start a state machine,
by using the same command that you used to start the first state machine. You should see
that the distributed state (UNLOCKED
) is entered instead of the default
initial state (LOCKED
The following example shows the state machine and its output:
sm>sm start
sm>sm state
UNLOCKED
Then from either shell (we use second instance in the next example), send a
PUSH
event to transit from the UNLOCKED
into the LOCKED
state.
The following example shows the state machine command and its output:
sm>sm event PUSH
Exit state UNLOCKED
Entry state LOCKED
Event PUSH send
In the other shell (the first shell if you ran the preceding command in the second shell), you should see the state be changed automatically, based on distributed state kept in Zookeeper. The following example shows the state machine command and its output:
sm>Exit state UNLOCKED
Entry state LOCKED
Web
Web is a distributed state machine example that uses a zookeeper state machine to handle distributed state. See Zookeeper.
This example is meant to be run on multiple browser sessions against multiple different hosts. |
This sample uses a modified state machine structure from Showcase to work with a distributed state machine. The following image shows the state machine logic:
Due to the nature of this sample, an instance of a Zookeeper state machine is expected to
be available from a localhost for every individual sample instance.
This demonstration uses an example that starts three different sample instances.
If you run different instances on the same host, you need to
distinguish the port each one uses by adding --server.port=<myport>
to the command.
Otherwise the default port for each host is 8080
In this sample run, we have three hosts: n1
, n2
, and n3
. Each one
has a local zookeeper instance running and a state machine sample running
on a port 8080
In there different terminals, start the three different state machines by running the following command:
# java -jar spring-statemachine-samples-web-4.0.0.jar
When all instances are running, you should see that all show similar
information when you access them with a browser. The states should be S0
, S1
, and S11
The extended state variable named foo
should have a value of 0
. The main state is S11
When you press the Event C
button in any of the browser windows, the
distributed state is changed to S211,
which is the target state
denoted by the transition associated with an event of type C
The following image shows the change:
Now we can press the Event H
button and see that the
internal transition runs on all state machines to change the
the value of the extended state variable named foo
from 0
to 1
. This change is
first done on the state machine that receives the event and is then propagated
to the other state machines. You should see only the variable named foo
change
from 0
to 1
Finally, we can send Event K
, which takes the state
machine state back to state S11
. You should see this happen in
all of the browsers. The following image shows the result in one browser:
Scope
Scope is a state machine example that uses session scope to provide an individual instance for every user. The following image shows the states and events within the Scope state machine:
This simple state machine has three states: S0
, S1
, and S2
Transitions between those are controlled by three events: A
, B
, and C
To start the state machine, run the following command in a terminal:
# java -jar spring-statemachine-samples-scope-4.0.0.jar
When the instance is running, you can open a browser and play with the state machine. If you open the same page in a different browser, (for example, one in Chrome and one in Firefox), you should get a new state machine instance for each user session. The following image shows the state machine in a browser:
Security
Security is a state machine example that uses most of the possible combinations of securing a state machine. It secures sending events, transitions, and actions. The following image shows the state machine’s states and events:
To start the state machine, run the following command:
# java -jar spring-statemachine-samples-secure-4.0.0.jar
We secure event sending by requiring that users have a role of USER
Spring Security ensures that no other users can send events to this
state machine.
The following listing secures event sending:
throws Exception {
config
.autoStartup(true)
.and()
.withSecurity()
.enabled(true)
.event("hasRole('USER')");
In this sample we define two users:
A user named
user
who has a role ofUSER
A user named
admin
who has two roles:USER
andADMIN
The password for both users is password
The following listing configures the two users:
static class SecurityConfig {
public InMemoryUserDetailsManager userDetailsService() {
UserDetails user = User.withDefaultPasswordEncoder()
.username("user")
.password("password")
.roles("USER")
UserDetails admin = User.withDefaultPasswordEncoder()
.username("admin")
.roles("USER", "ADMIN")
return new InMemoryUserDetailsManager(user, admin);
We define various transitions between states according to the state chart
shown at the beginning of the example. Only a user with an active ADMIN
role can run
the external transitions between S2
and S3
. Similarly only an ADMIN
can
run the internal transition the S1
state.
The following listing defines the transitions, including their security:
throws Exception {
transitions
.withExternal()
.source(States.S0).target(States.S1).event(Events.A)
.and()
.withExternal()
.source(States.S1).target(States.S2).event(Events.B)
.and()
.withExternal()
.source(States.S2).target(States.S0).event(Events.C)
.and()
.withExternal()
.source(States.S2).target(States.S3).event(Events.E)
.secured("ROLE_ADMIN", ComparisonType.ANY)
.and()
.withExternal()
.source(States.S3).target(States.S0).event(Events.C)
.and()
.withInternal()
.source(States.S0).event(Events.D)
.action(adminAction())
.and()
.withInternal()
.source(States.S1).event(Events.F)
.action(transitionAction())
.secured("ROLE_ADMIN", ComparisonType.ANY);
The following listing uses a method called adminAction
whose return type is Action
to
specify that the action is secured with a role of ADMIN
@Scope(proxyMode = ScopedProxyMode.TARGET_CLASS)
public Action<States, Events> adminAction() {
@Secured("ROLE_ADMIN")
log.info("Executed only for admin role");
The following Action
runs an internal transition in state S
when event F
is sent.
public Action<States, Events> transitionAction() {
The transition itself is secured with a
role of ADMIN
, so this transition does not run if the current user
does not hate that role.
Event Service
The event service example shows how you can use state machine concepts as a processing engine for events. This sample evolved from a question:
Can I use Spring Statemachine as a microservice to feed events to different state machine instances? In fact, Spring Statemachine can feed events to potentially millions of different state machine instances.
This example uses a Redis
instance to persist state machine
instances.
Obviously, a million state machine instances in a JVM would be
a bad idea, due to memory constraints. This leads to
other features of Spring Statemachine that let you persist a
StateMachineContext
and re-use existing instances.
For this example, we assume that a shopping application
sends different types of PageView
events to a separate
microservice which then tracks user behavior by using a state
machine. The following image shows the state model, which has a few states
that represent a user navigating a product items list, adding and removing
items from a cart, going to a payment page, and initiating a payment
operation:
An actual shopping application would send these events into this service by (for example) using a rest call. More about this later.
Remember that the focus here is to have an application that exposes a
REST API that the user can use to send events that can be processed by a
state machine for each request.
The following state machine configuration models what we have in a
state chart. Various actions update the state machine’s Extended
State
to track the number of entries into various states and also how
many times the internal transitions for ADD
and DEL
are called and whether
PAY
has been executed:
@Bean(name = "stateMachineTarget")
@Scope(scopeName="prototype")
public StateMachine<States, Events> stateMachineTarget() throws Exception {
Builder<States, Events> builder = StateMachineBuilder.<States, Events>builder();
builder.configureConfiguration()
.autoStartup(true);
builder.configureStates()
.withStates()
.initial(States.HOME)
builder.configureTransitions()
.withInternal()
.source(States.ITEMS).event(Events.ADD)
.action(addAction())
.and()
.withInternal()
.source(States.CART).event(Events.DEL)
.action(delAction())
.and()
.withInternal()
.source(States.PAYMENT).event(Events.PAY)
.action(payAction())
.and()
.withExternal()
.source(States.HOME).target(States.ITEMS)
.action(pageviewAction())
.event(Events.VIEW_I)
.and()
.withExternal()
.source(States.CART).target(States.ITEMS)
.and()
.withExternal()
.source(States.ITEMS).target(States.CART)
.event(Events.VIEW_C)
.and()
.withExternal()
.source(States.PAYMENT).target(States.CART)
.and()
.withExternal()
.source(States.CART).target(States.PAYMENT)
.event(Events.VIEW_P)
.and()
.withExternal()
.source(States.ITEMS).target(States.HOME)
.action(resetAction())
.event(Events.RESET)
.and()
.withExternal()
.source(States.CART).target(States.HOME)
.and()
.withExternal()
.source(States.PAYMENT).target(States.HOME)
.event(Events.RESET);
return builder.build();
Do not focus on stateMachineTarget
or
@Scope
for now, as we explain those later in this section.
We set up a RedisConnectionFactory
that defaults to
localhost and default port. We use StateMachinePersist
with a
RepositoryStateMachinePersist
implementation. Finally, we create a
RedisStateMachinePersister
that uses a previously
created StateMachinePersist
bean.
These are then used in a Controller
that handles REST
calls,
public RedisConnectionFactory redisConnectionFactory() {
return new JedisConnectionFactory();
public StateMachinePersist<States, Events, String> stateMachinePersist(RedisConnectionFactory connectionFactory) {
RedisStateMachineContextRepository<States, Events> repository =
new RedisStateMachineContextRepository<States, Events>(connectionFactory);
return new RepositoryStateMachinePersist<States, Events>(repository);
public RedisStateMachinePersister<States, Events> redisStateMachinePersister(
StateMachinePersist<States, Events, String> stateMachinePersist) {
return new RedisStateMachinePersister<States, Events>(stateMachinePersist);
We create a bean named stateMachineTarget
State machine instantiation is a relatively
expensive operation, so it is better to try to pool instances instead
of instantiating a new instance for every request. To do so, we first
create a poolTargetSource
that wraps stateMachineTarget
and pools
it with a max size of three. When then proxy this poolTargetSource
with
ProxyFactoryBean
by using a request
scope. Effectively, this means
that every REST
request gets a pooled state machine instance from
a bean factory. Later, we show how these instances are used.
The following listing shows how we create the ProxyFactoryBean
and set the target source:
@Scope(value = "request", proxyMode = ScopedProxyMode.TARGET_CLASS)
public ProxyFactoryBean stateMachine() {
ProxyFactoryBean pfb = new ProxyFactoryBean();
pfb.setTargetSource(poolTargetSource());
return pfb;
The following listing shows we set the maximum size and set the target bean name:
public CommonsPool2TargetSource poolTargetSource() {
CommonsPool2TargetSource pool = new CommonsPool2TargetSource();
pool.setMaxSize(3);
pool.setTargetBeanName("stateMachineTarget");
return pool;
Now we can get into actual demo. You need to have a Redis server running on localhost with default settings. Then you need to run the Boot-based sample application by running the following command:
# java -jar spring-statemachine-samples-eventservice-4.0.0.jar
In a browser, you see something like the following:
In this UI, you can use three users: joe
, bob
, and dave
Clicking a button shows the current state and the extended state. Enabling a
radio button before clicking a button sends a particular event for that
user. This arrangement lets you play with the UI.
In our StateMachineController
, we autowire StateMachine
and
. StateMachine
is request
scoped, so you
get a new instance for each request, while StateMachinePersist
is a normal
singleton bean.
The following listing autowires StateMachine
and
StateMachinePersist
@Autowired
@Autowired
private StateMachinePersister<States, Events, String> stateMachinePersister;
In the following listing, feedAndGetState
is used with a UI to do same things that an
actual REST
api might do:
@RequestMapping("/state")
public String feedAndGetState(@RequestParam(value = "user", required = false) String user,
@RequestParam(value = "id", required = false) Events id, Model model) throws Exception {
model.addAttribute("user", user);
model.addAttribute("allTypes", Events.values());
model.addAttribute("stateChartModel", stateChartModel);
// we may get into this page without a user so
// do nothing with a state machine
if (StringUtils.hasText(user)) {
resetStateMachineFromStore(user);
if (id != null) {
feedMachine(user, id);
model.addAttribute("states", stateMachine.getState().getIds());
model.addAttribute("extendedState", stateMachine.getExtendedState().getVariables());
return "states";
In the following listing, feedPageview
is a REST
method that accepts a post with
JSON content.
@RequestMapping(value = "/feed",method= RequestMethod.POST)
@ResponseStatus(HttpStatus.OK)
public void feedPageview(@RequestBody(required = true) Pageview event) throws Exception {
Assert.notNull(event.getUser(), "User must be set");
Assert.notNull(event.getId(), "Id must be set");
resetStateMachineFromStore(event.getUser());
feedMachine(event.getUser(), event.getId());
In the following listing, feedMachine
sends an event into a StateMachine
and persists
its state by using a StateMachinePersister
private void feedMachine(String user, Events id) throws Exception {
stateMachine
.withPayload(id).build()))
.blockLast();
stateMachinePersister.persist(stateMachine, "testprefix:" + user);
The following listing shows a resetStateMachineFromStore
that is used to restore a state machine
for a particular user:
private StateMachine<States, Events> resetStateMachineFromStore(String user) throws Exception {
return stateMachinePersister.restore(stateMachine, "testprefix:" + user);
As you would usually send an event by using a UI, you can do the same by using REST
calls,
as the following curl command shows:
# curl http://localhost:8080/feed -H "Content-Type: application/json" --data '{"user":"joe","id":"VIEW_I"}'
At this point, you should have content in Redis with a key of
testprefix:joe
$ ./redis-cli
127.0.0.1:6379> KEYS *
1) "testprefix:joe"
The next three images show when state for joe
HOME
to ITEMS
and when the ADD
action has been executed.
The following image the ADD
event being sent:
Now your are still on the ITEMS
state, and the internal transition caused
the COUNT
extended state variable to increase to 1
, as the following image shows:
Now you can run the following curl
rest call a few times (or do it through the UI) and
see the COUNT
variable increase with every call:
# curl http://localhost:8080/feed -H "Content-Type: application/json" # --data '{"user":"joe","id":"ADD"}'
The following image shows the result of these operations:
Deploy
The deploy example shows how you can use state machine concepts with UML modeling to provide a generic error handling state. This state machine is a relatively complex example of how you can use various features to provide a centralized error handling concept. The following image shows the deploy state machine:
The preceding state chart was designed by using the Eclipse Papyrus Plugin (seeEclipse Modeling Support) and imported into Spring StateMachine through the resulting UML model file. Actions and guards defined in a model are resolved from a Spring Application Context. |
In this state machine scenario, we have two different behaviors
(DEPLOY
and UNDEPLOY
) that user tries to execute.
In the preceding state chart:
In the
DEPLOY
state, theINSTALL
andSTART
states are entered conditionally. We enterSTART
directly if a product is already installed and have no need to try toSTART
if install fails. -
In the
UNDEPLOY
state, we enterSTOP
conditionally if the application is already running. -
Conditional choices for
DEPLOY
andUNDEPLOY
are done through a choice pseudostate within those states, and the choices are selected by guards. -
We use exit point pseudostates to have a more controlled exit from the
DEPLOY
andUNDEPLOY
states. -
After exiting from
DEPLOY
andUNDEPLOY
, we go through a junction pseudostate to choose whether to go through anERROR
state (if an error was added into an extended state). -
Finally, we go back to the
READY
state to process new requests.
Now we can get to the actual demo. Run the boot based sample application by running the following command:
# java -jar spring-statemachine-samples-deploy-4.0.0.jar
In a browser, you can see something like the following image:
As we do not have real install, start, or stop functionality, we simulate failures by checking the existence of particular message headers. |
Now you can start to send events to a machine and choose various message headers to drive functionality.
Order Shipping
The order shipping example shows how you can use state machine concepts to build a simple order processing system.
The following image shows a state chart that drives this order shipping sample.
The state machine enters the
WAIT_NEW_ORDER
(default) state. -
The event
PLACE_ORDER
transitions into theRECEIVE_ORDER
state and the entry action (entryReceiveOrder
) is executed. -
If the order is
OK
, the state machine goes into two regions, one handling order production and one handling user-level payment. Otherwise, the state machine goes intoCUSTOMER_ERROR
, which is a final state. -
The state machine loops in a lower region to remind the user to pay until
RECEIVE_PAYMENT
is sent successfully to indicate correct payment. -
Both regions go into waiting states (
WAIT_PRODUCT
andWAIT_ORDER
), where they are joined before the parent orthogonal state (HANDLE_ORDER
) is exited. -
Finally, the state machine goes through
SHIP_ORDER
to its final state (ORDER_SHIPPED
The following command runs the sample:
# java -jar spring-statemachine-samples-ordershipping-4.0.0.jar
In a browser, you can see something similar to the following image. You can start by choosing a customer and an order to create a state machine.
The state machine for a particular order is now created and you can start to play
with placing an order and sending a payment. Other settings (such as
makeProdPlan
, produce
, and payment
) let you control how the state
machine works.
The following image shows the state machine waiting for an order:
Finally, you can see what machine does by refreshing a page, as the following image shows:
JPA Configuration
The JPA configuration example shows how you can use state machine concepts with a machine configuration kept in a database. This sample uses an embedded H2 database with an H2 Console (to ease playing with the database).
This sample uses spring-statemachine-autoconfigure
(which, by default,
auto-configures the repositories and entity classes needed for JPA).
Thus, you need only @SpringBootApplication
The following example shows the Application
class with the @SpringBootApplication
annotation:
public class Application {
SpringApplication.run(Application.class, args);
The following example shows how to create a RepositoryStateMachineModelFactory
@EnableStateMachineFactory
public static class Config extends StateMachineConfigurerAdapter<String, String> {
@Autowired
private StateRepository<? extends RepositoryState> stateRepository;
@Autowired
private TransitionRepository<? extends RepositoryTransition> transitionRepository;
public void configure(StateMachineModelConfigurer<String, String> model) throws Exception {
model
.withModel()
.factory(modelFactory());
public StateMachineModelFactory<String, String> modelFactory() {
return new RepositoryStateMachineModelFactory(stateRepository, transitionRepository);
# java -jar spring-statemachine-samples-datajpa-4.0.0.jar
Accessing the application at http://localhost:8080
brings up a newly
constructed machine for each request. You can then choose to send
events to a machine. The possible events and machine configuration are
updated from a database with every request.
The following image shows the UI and the initial events that are created when
this state machine starts:
To access the embedded console, you can use the JDBC URL (which is jdbc:h2:mem:testdb
, if it is
not already set).
The following image shows the H2 console:
From the console, you can see the database tables and modify them as you wish. The following image shows the result of a simple query in the UI:
Now that you have gotten this far, you have probably wondered how those default
states and transitions got populated into the database. Spring Data
has a nice trick to auto-populate repositories, and we
used this feature through Jackson2RepositoryPopulatorFactoryBean
The following example shows how we create such a bean:
public StateMachineJackson2RepositoryPopulatorFactoryBean jackson2RepositoryPopulatorFactoryBean() {
StateMachineJackson2RepositoryPopulatorFactoryBean factoryBean = new StateMachineJackson2RepositoryPopulatorFactoryBean();
factoryBean.setResources(new Resource[]{new ClassPathResource("data.json")});
return factoryBean;
The following listing shows the source of the data with which we populate the database:
"@id": "10",
"_class": "org.springframework.statemachine.data.jpa.JpaRepositoryAction",
"spel": "T(System).out.println('hello exit S1')"
"@id": "11",
"spel": "T(System).out.println('hello entry S2')"
"@id": "12",
"spel": "T(System).out.println('hello state S3')"
"@id": "13",
"spel": "T(System).out.println('hello')"
"@id": "1",
"_class": "org.springframework.statemachine.data.jpa.JpaRepositoryState",
"initial": true,
"state": "S1",
"exitActions": ["10"]
"@id": "2",
"initial": false,
"state": "S2",
"entryActions": ["11"]
"@id": "3",
"initial": false,
"state": "S3",
"stateActions": ["12"]
"_class": "org.springframework.statemachine.data.jpa.JpaRepositoryTransition",
"source": "1",
"target": "2",
"event": "E1",
"kind": "EXTERNAL"
"source": "2",
"target": "3",
"event": "E2",
"actions": ["13"]
Data Persist
The data persist sample shows how you can state machine concepts with a persisting machine in an external repository. This sample uses an embedded H2 database with an H2 Console (to ease playing with the database). Optionally, you can also enable Redis or MongoDB.
(which, by default,
annotation:
The StateMachineRuntimePersister
interface works on the runtime
level of a StateMachine
. Its implementation,
JpaPersistingStateMachineInterceptor
, is meant to be used with a
JPA.
The following listing creates a StateMachineRuntimePersister
bean:
@Profile("jpa")
public static class JpaPersisterConfig {
public StateMachineRuntimePersister<States, Events, String> stateMachineRuntimePersister(
JpaStateMachineRepository jpaStateMachineRepository) {
return new JpaPersistingStateMachineInterceptor<>(jpaStateMachineRepository);
The following example shows how you can use a very similar configuration to create a bean for MongoDB:
@Profile("mongo")
public static class MongoPersisterConfig {
MongoDbStateMachineRepository jpaStateMachineRepository) {
return new MongoDbPersistingStateMachineInterceptor<>(jpaStateMachineRepository);
The following example shows how you can use a very similar configuration to create a bean for Redis:
@Profile("redis")
public static class RedisPersisterConfig {
RedisStateMachineRepository jpaStateMachineRepository) {
return new RedisPersistingStateMachineInterceptor<>(jpaStateMachineRepository);
You can configure StateMachine
to use runtime persistence by using the
withPersistence
configuration method.
The following listing shows how to do so:
@Autowired
private StateMachineRuntimePersister<States, Events, String> stateMachineRuntimePersister;
throws Exception {
config
.withPersistence()
.runtimePersister(stateMachineRuntimePersister);
This sample also uses DefaultStateMachineService
, which makes it
easier to work with multiple machines.
The following listing shows how to create an instance of DefaultStateMachineService
public StateMachineService<States, Events> stateMachineService(
StateMachineFactory<States, Events> stateMachineFactory,
StateMachineRuntimePersister<States, Events, String> stateMachineRuntimePersister) {
return new DefaultStateMachineService<States, Events>(stateMachineFactory, stateMachineRuntimePersister);
The following listing shows the logic that drives the StateMachineService
in this sample:
private synchronized StateMachine<States, Events> getStateMachine(String machineId) throws Exception {
listener.resetMessages();
if (currentStateMachine == null) {
currentStateMachine = stateMachineService.acquireStateMachine(machineId);
currentStateMachine.addStateListener(listener);
currentStateMachine.startReactively().block();
} else if (!ObjectUtils.nullSafeEquals(currentStateMachine.getId(), machineId)) {
stateMachineService.releaseStateMachine(currentStateMachine.getId());
currentStateMachine.stopReactively().block();
return currentStateMachine;
# java -jar spring-statemachine-samples-datapersist-4.0.0.jar
By default, the
Accessing the application at http://localhost:8080 brings up a newly constructed state machine for each request, and you can choose to send events to a machine. The possible events and machine configuration are updated from a database with every request.
The state machines in this sample have a simple configuration with states 'S1'
to 'S6' and events 'E1' to 'E6' to transition the state machine between those
states. You can use two state machine identifiers (datajpapersist1
and
datajpapersist2
) to request a particular state machine.
The following image shows the UI that lets you pick a machine and an event and that shows
what happens when you do:
The sample defaults to using machine 'datajpapersist1' and goes to its initial state 'S1'. The following image shows the result of using those defaults:
If you send events E1
and E2
to the datajpapersist1
state machine, its
state is persisted as 'S3'.
The following image shows the result of doing so:
If you then request state machine datajpapersist1
but send no events,
the state machine is restored back to its persisted state, S3
Data Multi Persist
The data multi ersist sample is an extension of two other samples: JPA Configuration and Data Persist. We still keep machine configuration in a database and persist into a database. However, this time, we also have a machine that contains two orthogonal regions, to show how those are persisted independently. This sample also uses an embedded H2 database with an H2 Console (to ease playing with the database).
(which, by default,
annotation:
As in the other data-driven samples, we again create a StateMachineRuntimePersister
public StateMachineRuntimePersister<String, String, String> stateMachineRuntimePersister(
A StateMachineService
bean makes it easier to work with a machines.
The following listing shows how to create such a bean:
public StateMachineService<String, String> stateMachineService(
StateMachineFactory<String, String> stateMachineFactory,
StateMachineRuntimePersister<String, String, String> stateMachineRuntimePersister) {
return new DefaultStateMachineService<String, String>(stateMachineFactory, stateMachineRuntimePersister);
We use JSON data to import the configuration. The following example creates a bean to do so:
factoryBean.setResources(new Resource[] { new ClassPathResource("datajpamultipersist.json") });
return factoryBean;
The following listing shows how we get a RepositoryStateMachineModelFactory
@Autowired
@Autowired
@Autowired
private StateMachineRuntimePersister<String, String, String> stateMachineRuntimePersister;
throws Exception {
config
.withPersistence()
throws Exception {
model
.withModel()
You can run the sample by using the following command:
# java -jar spring-statemachine-samples-datajpamultipersist-4.0.0.jar
brings up a newly
constructed machine for each request and lets you send
events to a machine. The possible events and the state machine configuration are
updated from a database for each request. We also print out
all state machine contexts and the current root machine,
The state machine named datajpamultipersist1
is a simple “flat” machine where states S1
S2
and S3
are transitioned by events E1
, E2
, and E3
(respectively).
However, the state machine named datajpamultipersist2
contains two
regions (R1
and R2
) directly under the root level. That is why this
root level machine really does not have a state. We need
that root level machine to host those regions.
Regions R1
and R2
in the datajpamultipersist2
state machine contains states
S10
, S11
, and S12
and S20
, S21
, and S22
(respectively). Events
E10
, E11
, and E12
are used for region R1
and events E20
, E21
and event E22
is used for region R2
. The following images shows what happens when we
send events E10
and E20
to the
state machine:
Regions have their own contexts with their own IDs, and the actual
ID is postfixed with #
and the region ID. As the following image shows,
different regions in a database have different contexts:
Data JPA Persist
(which, by default,
annotation:
JPA.
bean:
@Profile("jpa")
@Profile("mongo")
@Profile("redis")
withPersistence
@Autowired
throws Exception {
config
.withPersistence()
, which makes it
in this sample:
You can use the following command to run the sample:
By default, the
and
datajpapersist2
and E2
state machine, its
but send no events,
Monitoring
The monitoring sample shows how you can use state machine concepts to monitor state machine transitions and actions. The following listing configures the state machine that we use for this sample:
@EnableStateMachine
throws Exception {
states
.withStates()
.initial("S1")
.state("S2", null, (c) -> {System.out.println("hello");})
.state("S3", (c) -> {System.out.println("hello");}, null);
throws Exception {
transitions
.withExternal()
.source("S1").target("S2").event("E1")
.action((c) -> {System.out.println("hello");})
.and()
.withExternal()
.source("S2").target("S3").event("E2");
# java -jar spring-statemachine-samples-monitoring-4.0.0.jar
The following image shows the state machine’s initial state:
The following image shows the state of the state machine after we have performed some actions:
You can view metrics from Spring Boot by running the following two curl
commands (shown with their output):
# curl http://localhost:8080/actuator/metrics/ssm.transition.duration
"name":"ssm.transition.duration",
"measurements":[
"statistic":"COUNT",
"value":3.0
"statistic":"TOTAL_TIME",
"value":0.007
"statistic":"MAX",
"value":0.004
"availableTags":[
"tag":"transitionName",
"values":[
"INITIAL_S1",
"EXTERNAL_S1_S2"
# curl http://localhost:8080/actuator/metrics/ssm.transition.transit
"name":"ssm.transition.transit",
"measurements":[
"value":3.0
"availableTags":[
"values":[
"EXTERNAL_S1_S2",
"INITIAL_S1"
You can also view tracing from Spring Boot by running the following curl
command (shown with its output):
# curl http://localhost:8080/actuator/statemachinetrace
"timestamp":"2018-02-11T06:44:12.723+0000",
"info":{
"duration":2,
"machine":null,
"transition":"EXTERNAL_S1_S2"
"timestamp":"2018-02-11T06:44:12.720+0000",
"info":{
"duration":0,
"machine":null,
"action":"demo.monitoring.StateMachineConfig$Config$$Lambda$576/1499688007@22b47b2f"
"timestamp":"2018-02-11T06:44:12.714+0000",
"info":{
"duration":1,
"machine":null,
"transition":"INITIAL_S1"
"timestamp":"2018-02-11T06:44:09.689+0000",
"info":{
"duration":4,
"machine":null,
