For the latest stable version, please use Spring Session 3.5.0! |
Redis Configurations
Now that you have your application configured, you might want to start customizing things:
I want to customize the Redis configuration using Spring Boot properties
I want help in choosing
RedisSessionRepository
orRedisIndexedSessionRepository
I want to serialize the session using JSON.
I want to specify a different namespace.
I want to know when a session is created, deleted, destroyed or expires.
I want to find all sessions of a specific user
Serializing the Session using JSON
By default, Spring Session uses Java Serialization to serialize the session attributes.
Sometimes it might be problematic, especially when you have multiple applications that use the same Redis instance but have different versions of the same class.
You can provide a RedisSerializer
bean to customize how the session is serialized into Redis.
Spring Data Redis provides the GenericJackson2JsonRedisSerializer
that serializes and deserializes objects using Jackson’s ObjectMapper
public class SessionConfig implements BeanClassLoaderAware {
private ClassLoader loader;
public RedisSerializer<Object> springSessionDefaultRedisSerializer() {
return new GenericJackson2JsonRedisSerializer(objectMapper());
* Customized {@link ObjectMapper} to add mix-in for class that doesn't have default
* constructors
* @return the {@link ObjectMapper} to use
private ObjectMapper objectMapper() {
ObjectMapper mapper = new ObjectMapper();
mapper.registerModules(SecurityJackson2Modules.getModules(this.loader));
return mapper;
* @see
* org.springframework.beans.factory.BeanClassLoaderAware#setBeanClassLoader(java.lang
* .ClassLoader)
public void setBeanClassLoader(ClassLoader classLoader) {
this.loader = classLoader;
The above code snippet is using Spring Security, therefore we are creating a custom ObjectMapper
that uses Spring Security’s Jackson modules.
If you do not need Spring Security Jackson modules, you can inject your application’s ObjectMapper
bean and use it like so:
public RedisSerializer<Object> springSessionDefaultRedisSerializer(ObjectMapper objectMapper) {
return new GenericJackson2JsonRedisSerializer(objectMapper);
Specifying a Different Namespace
It is not uncommon to have multiple applications that use the same Redis instance.
For that reason, Spring Session uses a namespace
(defaults to spring:session
) to keep the session data separated if needed.
Using Spring Boot Properties
You can specify it by setting the spring.session.redis.namespace
property.
spring.session.redis.namespace=spring:session:myapplication
spring:
session:
redis:
namespace: "spring:session:myapplication"
Using the Annotation’s Attributes
You can specify the namespace
by setting the redisNamespace
property in the @EnableRedisHttpSession
, @EnableRedisIndexedHttpSession
, or @EnableRedisWebSession
annotations:
@EnableRedisHttpSession(redisNamespace = "spring:session:myapplication")
public class SessionConfig {
@EnableRedisIndexedHttpSession(redisNamespace = "spring:session:myapplication")
@EnableRedisWebSession(redisNamespace = "spring:session:myapplication")
Choosing Between RedisSessionRepository
and RedisIndexedSessionRepository
When working with Spring Session Redis, you will likely have to choose between the RedisSessionRepository
and the RedisIndexedSessionRepository
Both are implementations of the SessionRepository
interface that store session data in Redis.
However, they differ in how they handle session indexing and querying.
:RedisSessionRepository
is a basic implementation that stores session data in Redis without any additional indexing. It uses a simple key-value structure to store session attributes. Each session is assigned a unique session ID, and the session data is stored under a Redis key associated with that ID. When a session needs to be retrieved, the repository queries Redis using the session ID to fetch the associated session data. Since there is no indexing, querying sessions based on attributes or criteria other than the session ID can be inefficient. -
:RedisIndexedSessionRepository
is an extended implementation that provides indexing capabilities for sessions stored in Redis. It introduces additional data structures in Redis to efficiently query sessions based on attributes or criteria. In addition to the key-value structure used byRedisSessionRepository
, it maintains additional indexes to enable fast lookups. For example, it may create indexes based on session attributes like user ID or last access time. These indexes allow for efficient querying of sessions based on specific criteria, enhancing performance and enabling advanced session management features. In addition to that,RedisIndexedSessionRepository
also supports session expiration and deletion.
When using RedisIndexedSessionRepository with Redis Cluster you must be aware that it only subscribe to events from one random redis node in the cluster, which can cause some session indexes not being cleaned up if the event happened in a different node.
Configuring the RedisSessionRepository
If you are using Spring Boot, the RedisSessionRepository
is the default implementation.
However, if you want to be explicit about it, you can set the following property in your application:
spring.session.redis.repository-type=default
spring:
session:
redis:
repository-type: default
Configuring the RedisIndexedSessionRepository
Listening to Session Events
Often times it is valuable to react to session events, for example, you might want to do some kind of processing depending on the session lifecycle. In order to be able to do that, you must be using the indexed repository. If you do not know the difference between the indexed and the default repository, you can go to this section.
With the indexed repository configured, you can now start to listen to SessionCreatedEvent
, SessionDeletedEvent
, SessionDestroyedEvent
and SessionExpiredEvent
events.
There are a few ways to listen to application events in Spring, we are going to use the @EventListener
annotation.
@Component
public class SessionEventListener {
@EventListener
public void processSessionCreatedEvent(SessionCreatedEvent event) {
// do the necessary work
@EventListener
public void processSessionDeletedEvent(SessionDeletedEvent event) {
@EventListener
public void processSessionDestroyedEvent(SessionDestroyedEvent event) {
@EventListener
public void processSessionExpiredEvent(SessionExpiredEvent event) {
Finding All Sessions of a Specific User
By retrieving all sessions of a specific user, you can track the user’s active sessions across devices or browsers. For example, you can use this information session management purposes, such as allowing the user to invalidate or logout from specific sessions or performing actions based on the user’s session activity.
To do that, first you must be using the indexed repository, and then you can inject the FindByIndexNameSessionRepository
interface, like so:
@Autowired
public FindByIndexNameSessionRepository<? extends Session> sessions;
public Collection<? extends Session> getSessions(Principal principal) {
Collection<? extends Session> usersSessions = this.sessions.findByPrincipalName(principal.getName()).values();
return usersSessions;
public void removeSession(Principal principal, String sessionIdToDelete) {
Set<String> usersSessionIds = this.sessions.findByPrincipalName(principal.getName()).keySet();
if (usersSessionIds.contains(sessionIdToDelete)) {
this.sessions.deleteById(sessionIdToDelete);
In the example above, you can use the getSessions
method to find all sessions of a specific user, and the removeSession
method to remove a specific session of a user.
