This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.4.1!spring-doc.cn
Authorized Client Features
This section covers additional features provided by Spring Security for OAuth2 client.spring-doc.cn
Resolving an Authorized Client
The @RegisteredOAuth2AuthorizedClient annotation provides the ability to resolve a method parameter to an argument value of type OAuth2AuthorizedClient. This is a convenient alternative compared to accessing the OAuth2AuthorizedClient by using the OAuth2AuthorizedClientManager or OAuth2AuthorizedClientService. The following example shows how to use @RegisteredOAuth2AuthorizedClient:spring-doc.cn
@Controller
	@GetMapping("/")
	public String index(@RegisteredOAuth2AuthorizedClient("okta") OAuth2AuthorizedClient authorizedClient) {
		OAuth2AccessToken accessToken = authorizedClient.getAccessToken();
		return "index";
@Controller
    @GetMapping("/")
    fun index(@RegisteredOAuth2AuthorizedClient("okta") authorizedClient: OAuth2AuthorizedClient): String {
        val accessToken = authorizedClient.accessToken
        return "index"
The @RegisteredOAuth2AuthorizedClient annotation is handled by OAuth2AuthorizedClientArgumentResolver, which directly uses an OAuth2AuthorizedClientManager and, therefore, inherits its capabilities.spring-doc.cn
RestClient Integration
Support for RestClient is provided by OAuth2ClientHttpRequestInterceptor. This interceptor provides the ability to make protected resources requests by placing a Bearer token in the Authorization header of an outbound request. The interceptor directly uses an OAuth2AuthorizedClientManager and therefore inherits the following capabilities:spring-doc.cn
  • Performs an OAuth 2.0 Access Token request to obtain OAuth2AccessToken if the client has not yet been authorizedspring-doc.cn
  • If an existing OAuth2AccessToken is expired, it is refreshed (or renewed)spring-doc.cn
The following example uses the default OAuth2AuthorizedClientManager to configure a RestClient capable of accessing protected resources by placing Bearer tokens in the Authorization header of each request:spring-doc.cn
Configure RestClient with ClientHttpRequestInterceptor
public class RestClientConfig {
	public RestClient restClient(OAuth2AuthorizedClientManager authorizedClientManager) {
		OAuth2ClientHttpRequestInterceptor requestInterceptor =
				new OAuth2ClientHttpRequestInterceptor(authorizedClientManager);
		return RestClient.builder()
				.requestInterceptor(requestInterceptor)
	fun restClient(authorizedClientManager: OAuth2AuthorizedClientManager): RestClient {
		val requestInterceptor = OAuth2ClientHttpRequestInterceptor(authorizedClientManager)
			.build()
Providing the clientRegistrationId
OAuth2ClientHttpRequestInterceptor uses a ClientRegistrationIdResolver to determine which client is used to obtain an access token. By default, RequestAttributeClientRegistrationIdResolver is used to resolve the clientRegistrationId from HttpRequest#attributes().spring-doc.cn
The following example demonstrates providing a clientRegistrationId via attributes:spring-doc.cn
Provide clientRegistrationId via attributes
import static org.springframework.security.oauth2.client.web.client.RequestAttributeClientRegistrationIdResolver.clientRegistrationId;
@Controller
public class ResourceController {
	private final RestClient restClient;
	public ResourceController(RestClient restClient) {
		this.restClient = restClient;
	@GetMapping("/")
	public String index() {
		String resourceUri = "...";
		String body = this.restClient.get()
				.uri(resourceUri)
				.attributes(clientRegistrationId("okta"))   (1)
				.retrieve()
				.body(String.class);
		return "index";
import org.springframework.security.oauth2.client.web.client.RequestAttributeClientRegistrationIdResolver.clientRegistrationId
import org.springframework.web.client.body
@Controller
class ResourceController(private restClient: RestClient) {
	@GetMapping("/")
	fun index(): String {
		val resourceUri = "..."
		val body: String = restClient.get()
				.uri(resourceUri)
				.retrieve()
				.body<String>()
		return "index"
1 clientRegistrationId() is a static method in RequestAttributeClientRegistrationIdResolver.
Alternatively, a custom ClientRegistrationIdResolver can be provided. The following example configures a custom implementation that resolves the clientRegistrationId from the current user.spring-doc.cn
Configure ClientHttpRequestInterceptor with custom ClientRegistrationIdResolver
		requestInterceptor.setClientRegistrationIdResolver(clientRegistrationIdResolver());
	private static ClientRegistrationIdResolver clientRegistrationIdResolver() {
		return (request) -> {
			Authentication authentication = SecurityContextHolder.getContext().getAuthentication();
			return (authentication instanceof OAuth2AuthenticationToken principal)
					? principal.getAuthorizedClientRegistrationId() : null;
			.build()
	fun clientRegistrationIdResolver(): ClientRegistrationIdResolver {
		return ClientRegistrationIdResolver { request ->
			val authentication = SecurityContextHolder.getContext().getAuthentication()
			return if (authentication instanceof OAuth2AuthenticationToken) {
				authentication.getAuthorizedClientRegistrationId()
			} else {
                null
Providing the principal
OAuth2ClientHttpRequestInterceptor uses a PrincipalResolver to determine which principal name is associated with the access token, which allows an application to choose how to scope the OAuth2AuthorizedClient that is stored. By default, SecurityContextHolderPrincipalResolver is used to resolve the current principal from the SecurityContextHolder.spring-doc.cn
Alternatively, the principal can be resolved from HttpRequest#attributes() by configuring RequestAttributePrincipalResolver, as the following example shows:spring-doc.cn
Configure ClientHttpRequestInterceptor with RequestAttributePrincipalResolver
		requestInterceptor.setPrincipalResolver(new RequestAttributePrincipalResolver());
		requestInterceptor.setPrincipalResolver(RequestAttributePrincipalResolver())
			.build()
The following example demonstrates providing a principal name via attributes that scopes the OAuth2AuthorizedClient to the application instead of the current user:spring-doc.cn
Provide principal name via attributes
import static org.springframework.security.oauth2.client.web.client.RequestAttributePrincipalResolver.principal;
@Controller
	@GetMapping("/")
				.uri(resourceUri)
				.attributes(principal("my-application"))   (1)
				.retrieve()
		return "index";
import org.springframework.security.oauth2.client.web.client.RequestAttributePrincipalResolver.principal
@Controller
    @GetMapping("/")
				.uri(resourceUri)
				.retrieve()
				.body<String>()
		return "index"
1 principal() is a static method in RequestAttributePrincipalResolver.
Handling Failure
If an access token is invalid for any reason (e.g. expired token), it can be beneficial to handle the failure by removing the access token so that it cannot be used again. You can set up the interceptor to do this automatically by providing an OAuth2AuthorizationFailureHandler to remove the access token.spring-doc.cn
The following example uses an OAuth2AuthorizedClientRepository to set up an OAuth2AuthorizationFailureHandler that removes an invalid OAuth2AuthorizedClient within the context of an HttpServletRequest:spring-doc.cn
Configure OAuth2AuthorizationFailureHandler using OAuth2AuthorizedClientRepository
	public RestClient restClient(OAuth2AuthorizedClientManager authorizedClientManager,
			OAuth2AuthorizedClientRepository authorizedClientRepository) {
		OAuth2AuthorizationFailureHandler authorizationFailureHandler =
			OAuth2ClientHttpRequestInterceptor.authorizationFailureHandler(authorizedClientRepository);
		requestInterceptor.setAuthorizationFailureHandler(authorizationFailureHandler);
	fun restClient(authorizedClientManager: OAuth2AuthorizedClientManager,
			authorizedClientRepository: OAuth2AuthorizedClientRepository): RestClient {
		val authorizationFailureHandler = OAuth2ClientHttpRequestInterceptor
			.build()
Alternatively, an OAuth2AuthorizedClientService can be used to remove an invalid OAuth2AuthorizedClient outside the context of an HttpServletRequest, as the following example shows:spring-doc.cn
Configure OAuth2AuthorizationFailureHandler using OAuth2AuthorizedClientService
			OAuth2AuthorizedClientService authorizedClientService) {
			OAuth2ClientHttpRequestInterceptor.authorizationFailureHandler(authorizedClientService);
			authorizedClientService: OAuth2AuthorizedClientService): RestClient {
			.build()
WebClient Integration for Servlet Environments
The OAuth 2.0 Client support integrates with WebClient by using an ExchangeFilterFunction.spring-doc.cn
The ServletOAuth2AuthorizedClientExchangeFilterFunction provides a mechanism for requesting protected resources by using an OAuth2AuthorizedClient and including the associated OAuth2AccessToken as a Bearer Token. It directly uses an OAuth2AuthorizedClientManager and, therefore, inherits the following capabilities:spring-doc.cn
  • An OAuth2AccessToken is requested if the client has not yet been authorized.spring-doc.cn
    • authorization_code: Triggers the Authorization Request redirect to initiate the flow.spring-doc.cn
    • client_credentials: The access token is obtained directly from the Token Endpoint.spring-doc.cn
    • password: The access token is obtained directly from the Token Endpoint.spring-doc.cn
  • If the OAuth2AccessToken is expired, it is refreshed (or renewed) if an OAuth2AuthorizedClientProvider is available to perform the authorizationspring-doc.cn
The following code shows an example of how to configure WebClient with OAuth 2.0 Client support:spring-doc.cn
WebClient webClient(OAuth2AuthorizedClientManager authorizedClientManager) {
	ServletOAuth2AuthorizedClientExchangeFilterFunction oauth2Client =
			new ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager);
	return WebClient.builder()
			.apply(oauth2Client.oauth2Configuration())
fun webClient(authorizedClientManager: OAuth2AuthorizedClientManager?): WebClient {
    val oauth2Client = ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager)
            .build()
Providing the Authorized Client
The ServletOAuth2AuthorizedClientExchangeFilterFunction determines the client to use (for a request) by resolving the OAuth2AuthorizedClient from the ClientRequest.attributes() (request attributes).spring-doc.cn
The following code shows how to set an OAuth2AuthorizedClient as a request attribute:spring-doc.cn
@GetMapping("/")
	String resourceUri = ...
	String body = webClient
			.get()
			.uri(resourceUri)
			.attributes(oauth2AuthorizedClient(authorizedClient))   (1)
			.retrieve()
			.bodyToMono(String.class)
			.block();
	return "index";
@GetMapping("/")
    val resourceUri: String = ...
    val body: String = webClient
            .get()
            .uri(resourceUri)
            .retrieve()
            .bodyToMono()
            .block()
    return "index"
1 oauth2AuthorizedClient() is a static method in ServletOAuth2AuthorizedClientExchangeFilterFunction.
The following code shows how to set the ClientRegistration.getRegistrationId() as a request attribute:spring-doc.cn
@GetMapping("/")
			.get()
			.uri(resourceUri)
			.retrieve()
			.block();
	return "index";
@GetMapping("/")
            .get()
            .uri(resourceUri)
            .retrieve()
            .bodyToMono()
            .block()
    return "index"
1 clientRegistrationId() is a static method in ServletOAuth2AuthorizedClientExchangeFilterFunction.
The following code shows how to set an Authentication as a request attribute:spring-doc.cn
@GetMapping("/")
	Authentication anonymousAuthentication = new AnonymousAuthenticationToken(
			"anonymous", "anonymousUser", AuthorityUtils.createAuthorityList("ROLE_ANONYMOUS"));
			.get()
			.uri(resourceUri)
			.attributes(authentication(anonymousAuthentication))   (1)
			.retrieve()
			.block();
	return "index";
@GetMapping("/")
    val anonymousAuthentication: Authentication = AnonymousAuthenticationToken(
            .get()
            .uri(resourceUri)
            .retrieve()
            .bodyToMono()
            .block()
    return "index"
1 authentication() is a static method in ServletOAuth2AuthorizedClientExchangeFilterFunction.
It is recommended to be cautious with this feature since all HTTP requests will receive an access token bound to the provided principal.spring-doc.cn
Defaulting the Authorized Client
If neither OAuth2AuthorizedClient or ClientRegistration.getRegistrationId() is provided as a request attribute, the ServletOAuth2AuthorizedClientExchangeFilterFunction can determine the default client to use, depending on its configuration.spring-doc.cn
If setDefaultOAuth2AuthorizedClient(true) is configured and the user has authenticated by using HttpSecurity.oauth2Login(), the OAuth2AccessToken associated with the current OAuth2AuthenticationToken is used.spring-doc.cn
The following code shows the specific configuration:spring-doc.cn
	oauth2Client.setDefaultOAuth2AuthorizedClient(true);
            .build()
Be cautious with this feature, since all HTTP requests receive the access token.spring-doc.cn
Alternatively, if setDefaultClientRegistrationId("okta") is configured with a valid ClientRegistration, the OAuth2AccessToken associated with the OAuth2AuthorizedClient is used.spring-doc.cn
	oauth2Client.setDefaultClientRegistrationId("okta");
            .build()
