Form Login
Spring Security provides support for username and password being provided through an HTML form. This section provides details on how form based authentication works within Spring Security.
This section examines how form-based login works within Spring Security. First, we see how the user is redirected to the login form:
The preceding figure builds off our SecurityFilterChain
diagram.
First, a user makes an unauthenticated request to the resource (
/private
) for which it is not authorized.
Spring Security’s
AuthorizationFilter
indicates that the unauthenticated request is Denied by throwing an AccessDeniedException
Since the user is not authenticated,
ExceptionTranslationFilter
initiates Start Authentication and sends a redirect to the login page with the configured AuthenticationEntryPoint
In most cases, the AuthenticationEntryPoint
is an instance of LoginUrlAuthenticationEntryPoint
The browser requests the login page to which it was redirected.
Something within the application, must render the login page.
When the username and password are submitted, the UsernamePasswordAuthenticationFilter
creates a UsernamePasswordAuthenticationToken
which is a type of Authentication, by extracting the username and password from the HttpServletRequest
instance.
The UsernamePasswordAuthenticationFilter
extends AbstractAuthenticationProcessingFilter, so the following diagram should look pretty similar:
The figure builds off our SecurityFilterChain
diagram.
When the user submits their username and password, the
, which is a type of Authentication
instance.
Next, the
is passed into the AuthenticationManager
instance to be authenticated.
The details of what AuthenticationManager
looks like depend on how the user information is stored.
If authentication fails, then Failure.
The SecurityContextHolder is cleared out.
RememberMeServices.loginFail
is invoked. If remember me is not configured, this is a no-op. See theRememberMeServices
interface in the Javadoc. -
AuthenticationFailureHandler
is invoked. See theAuthenticationFailureHandler
class in the Javadoc
If authentication is successful, then Success.
SessionAuthenticationStrategy
is notified of a new login. See theSessionAuthenticationStrategy
The Authentication is set on the SecurityContextHolder. See the
SecurityContextPersistenceFilter
class in the Javadoc. -
RememberMeServices.loginSuccess
ApplicationEventPublisher
publishes anInteractiveAuthenticationSuccessEvent
The
AuthenticationSuccessHandler
is invoked. Typically, this is aSimpleUrlAuthenticationSuccessHandler
, which redirects to a request saved byExceptionTranslationFilter
when we redirect to the login page.
By default, Spring Security form login is enabled. However, as soon as any servlet-based configuration is provided, form based login must be explicitly provided. The following example shows a minimal, explicit Java configuration:
Java
XML
Kotlin
public SecurityFilterChain filterChain(HttpSecurity http) {
http
.formLogin(withDefaults());
<http>
<form-login />
</http>
http {
formLogin { }
In the preceding configuration, Spring Security renders a default login page. Most production applications require a custom login form.
The following configuration demonstrates how to provide a custom login form.
Java
XML
Kotlin
http
.formLogin(form -> form
.loginPage("/login")
.permitAll()
<http>
<intercept-url pattern="/login" access="permitAll" />
<form-login login-page="/login" />
</http>
http {
formLogin {
loginPage = "/login"
permitAll()
When the login page is specified in the Spring Security configuration, you are responsible for rendering the page.
The following Thymeleaf template produces an HTML login form that complies with a login page of /login
<!DOCTYPE html>
<html xmlns="http://www.w3.org/1999/xhtml" xmlns:th="https://www.thymeleaf.org">
<head>
<title>Please Log In</title>
</head>
<body>
<h1>Please Log In</h1>
<div th:if="${param.error}">
Invalid username and password.</div>
<div th:if="${param.logout}">
You have been logged out.</div>
<form th:action="@{/login}" method="post">
<div>
<input type="text" name="username" placeholder="Username"/>
</div>
<div>
<input type="password" name="password" placeholder="Password"/>
</div>
<input type="submit" value="Log in" />
</form>
</body>
</html>
There are a few key points about the default HTML form:
The form should perform a
post
to/login
The form needs to include a CSRF Token, which is automatically included by Thymeleaf.
The form should specify the username in a parameter named
username
The form should specify the password in a parameter named
password
If the HTTP parameter named
error
is found, it indicates the user failed to provide a valid username or password. -
logout
is found, it indicates the user has logged out successfully.
Many users do not need much more than to customize the login page. However, if needed, you can customize everything shown earlier with additional configuration.
If you use Spring MVC, you need a controller that maps GET /login
to the login template we created.
The following example shows a minimal LoginController
Java
Kotlin
@Controller
class LoginController {
@GetMapping("/login")
String login() {
return "login";
@Controller
fun login(): String {
return "login"
