OAuth 2.0 Resource Server Bearer Tokens
Bearer Token Resolution
By default, Resource Server looks for a bearer token in the Authorization header. However, you can verify this token.spring-doc.cn
For example, you may have a need to read the bearer token from a custom header. To do so, you can wire an instance of ServerBearerTokenAuthenticationConverter into the DSL:spring-doc.cn
Custom Bearer Token Header
ServerBearerTokenAuthenticationConverter converter = new ServerBearerTokenAuthenticationConverter();
converter.setBearerTokenHeaderName(HttpHeaders.PROXY_AUTHORIZATION);
http
    .oauth2ResourceServer(oauth2 -> oauth2
        .bearerTokenConverter(converter)
val converter = ServerBearerTokenAuthenticationConverter()
return http {
    oauth2ResourceServer {
        bearerTokenConverter = converter
Bearer Token Propagation
Now that you have a bearer token, you can pass that to downstream services. This is possible with ServerBearerExchangeFilterFunction:spring-doc.cn
public WebClient rest() {
    return WebClient.builder()
            .filter(new ServerBearerExchangeFilterFunction())
fun rest(): WebClient {
            .filter(ServerBearerExchangeFilterFunction())
            .build()
When the WebClient shown in the preceding example performs requests, Spring Security looks up the current Authentication and extract any AbstractOAuth2Token credential. Then, it propagates that token in the Authorization header — for example:spring-doc.cn
this.rest.get()
        .uri("https://other-service.example.com/endpoint")
        .retrieve()
        .bodyToMono(String.class)
this.rest.get()
        .retrieve()
        .bodyToMono<String>()
The prececing example invokes the other-service.example.com/endpoint, adding the bearer token Authorization header for you.spring-doc.cn
In places where you need to override this behavior, you can supply the header yourself:spring-doc.cn
this.rest.get()
        .headers(headers -> headers.setBearerAuth(overridingToken))
        .retrieve()
rest.get()
        .headers { it.setBearerAuth(overridingToken) }
        .retrieve()
In this case, the filter falls back and forwards the request onto the rest of the web filter chain.spring-doc.cn
Unlike the OAuth 2.0 Client filter function, this filter function makes no attempt to renew the token, should it be expired.spring-doc.cn
