CredentialsContainer
The CredentialsContainer interface indicates that the implementing object contains sensitive data, and is used internally by Spring Security to erase the authentication credentials after a successful authentication. This interface is implemented by most of Spring Security internal domain classes, like User and UsernamePasswordAuthenticationToken.spring-doc.cn
The ProviderManager manager checks whether the returned Authentication implements this interface. If so, it calls the eraseCredentials method to remove the credentials from the object.spring-doc.cn
If you want your custom authentication objects to have their credentials erased after authentication, you should ensure that the classes implement the CredentialsContainer interface.spring-doc.cn
Users who are writing their own AuthenticationProvider implementations should create and return an appropriate Authentication object there, minus any sensitive data, rather than using this interface.spring-doc.cn
