This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.3.3! |
In an application where end users can log in, it is important to consider how to protect against Cross Site Request Forgery (CSRF).
Spring Security protects against CSRF attacks by default for unsafe HTTP methods, such as a POST request, so no additional code is necessary. You can specify the default configuration explicitly using the following:
Java
Kotlin
XML
@EnableWebSecurity
public class SecurityConfig {
public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
http
.csrf(Customizer.withDefaults());
return http.build();
import org.springframework.security.config.annotation.web.invoke
@EnableWebSecurity
open fun securityFilterChain(http: HttpSecurity): SecurityFilterChain {
http {
csrf { }
return http.build()
<http>
<csrf/>
</http>
To learn more about CSRF protection for your application, consider the following use cases:
I want to understand CSRF protection’s components
I need to migrate an application from Spring Security 5 to 6
I want to store the
CsrfToken
in a cookie instead of the session -
I want to store the
CsrfToken
in a custom location -
I want to opt-out of deferred tokens
I want to opt-out of BREACH protection
I need guidance integrating Thymeleaf, JSPs or another view technology with the backend
I need guidance integrating Angular or another JavaScript framework with the backend
I need guidance integrating a mobile application or another client with the backend
I need guidance on handling errors
I want to test CSRF protection
I need guidance on disabling CSRF protection
Understanding CSRF Protection’s Components
CSRF protection is provided by several components that are composed within the CsrfFilter
CsrfFilter
ComponentsCSRF protection is divided into two parts:
Make the
CsrfToken
available to the application by delegating to theCsrfTokenRequestHandler
Determine if the request requires CSRF protection, load and validate the token, and handle
AccessDeniedException
CsrfFilter
Processing-
First, the
DeferredCsrfToken
is loaded, which holds a reference to theCsrfTokenRepository
so that the persistedCsrfToken
can be loaded later (in).
Second, a
Supplier<CsrfToken>
(created fromDeferredCsrfToken
) is given to theCsrfTokenRequestHandler
, which is responsible for populating a request attribute to make theCsrfToken
available to the rest of the application. -
Next, the main CSRF protection processing begins and checks if the current request requires CSRF protection. If not required, the filter chain is continued and processing ends.
If CSRF protection is required, the persisted
CsrfToken
is finally loaded from theDeferredCsrfToken
Continuing, the actual CSRF token provided by the client (if any) is resolved using the
The actual CSRF token is compared against the persisted
CsrfToken
. If valid, the filter chain is continued and processing ends. -
If the actual CSRF token is invalid (or missing), an
is passed to theAccessDeniedHandler
Migrating to Spring Security 6
When migrating from Spring Security 5 to 6, there are a few changes that may impact your application. The following is an overview of the aspects of CSRF protection that have changed in Spring Security 6:
Loading of the
CsrfToken
is now deferred by default to improve performance by no longer requiring the session to be loaded on every request. -
The
CsrfToken
now includes randomness on every request by default to protect the CSRF token from a BREACH attack.
The changes in Spring Security 6 require additional configuration for single-page applications, and as such you may find the Single-Page Applications section particularly useful. |
See the Exploit Protection section of the Migration chapter for more information on migrating a Spring Security 5 application.
Persisting the CsrfToken
The CsrfToken
is persisted using a CsrfTokenRepository
By default, the HttpSessionCsrfTokenRepository
is used for storing tokens in a session.
Spring Security also provides the CookieCsrfTokenRepository
for storing tokens in a cookie.
You can also specify your own implementation to store tokens wherever you like.
Using the HttpSessionCsrfTokenRepository
By default, Spring Security stores the expected CSRF token in the HttpSession
by using HttpSessionCsrfTokenRepository
The HttpSessionCsrfTokenRepository
reads the token from a session (whether in-memory, cache, or database). If you need to access the session attribute directly, please first configure the session attribute name using HttpSessionCsrfTokenRepository#setSessionAttributeName
You can specify the default configuration explicitly using the following configuration:
Java
Kotlin
XML
@EnableWebSecurity
http
.csrf((csrf) -> csrf
.csrfTokenRepository(new HttpSessionCsrfTokenRepository())
@EnableWebSecurity
http {
csrf {
csrfTokenRepository = HttpSessionCsrfTokenRepository()
return http.build()
<http>
<csrf token-repository-ref="tokenRepository"/>
</http>
<b:bean id="tokenRepository"
class="org.springframework.security.web.csrf.HttpSessionCsrfTokenRepository"/>
Using the CookieCsrfTokenRepository
You can persist the CsrfToken
in a cookie to support a JavaScript-based application using the CookieCsrfTokenRepository
The CookieCsrfTokenRepository
writes to a cookie named XSRF-TOKEN
and reads it from an HTTP request header named X-XSRF-TOKEN
or the request parameter _csrf
by default.
These defaults come from Angular and its predecessor AngularJS.
See the Cross-Site Request Forgery (XSRF) protection guide and the HttpClientXsrfModule for more recent information on this topic. |
You can configure the CookieCsrfTokenRepository
The example explicitly sets |
Customizing the CsrfTokenRepository
There can be cases where you want to implement a custom CsrfTokenRepository
Once you’ve implemented the CsrfTokenRepository
interface, you can configure Spring Security to use it with the following configuration:
CsrfTokenRepository
Java
Kotlin
XML
@EnableWebSecurity
http
.csrfTokenRepository(new CustomCsrfTokenRepository())
@EnableWebSecurity
http {
csrf {
csrfTokenRepository = CustomCsrfTokenRepository()
return http.build()
<http>
</http>
class="example.CustomCsrfTokenRepository"/>
Handling the CsrfToken
The CsrfToken
is made available to an application using a CsrfTokenRequestHandler
This component is also responsible for resolving the CsrfToken
from HTTP headers or request parameters.
By default, the XorCsrfTokenRequestAttributeHandler
is used for providing BREACH protection of the CsrfToken
Spring Security also provides the CsrfTokenRequestAttributeHandler
for opting out of BREACH protection.
You can also specify your own implementation to customize the strategy for handling and resolving tokens.
Using the XorCsrfTokenRequestAttributeHandler
(BREACH)
The XorCsrfTokenRequestAttributeHandler
makes the CsrfToken
available as an HttpServletRequest
attribute called _csrf
, and additionally provides protection for BREACH.
The |
This implementation also resolves the token value from the request as either a request header (one of X-CSRF-TOKEN
or X-XSRF-TOKEN
by default) or a request parameter (_csrf
by default).
BREACH protection is provided by encoding randomness into the CSRF token value to ensure the returned |
Spring Security protects the CSRF token from a BREACH attack by default, so no additional code is necessary. You can specify the default configuration explicitly using the following configuration:
Java
Kotlin
XML
@EnableWebSecurity
http
.csrfTokenRequestHandler(new XorCsrfTokenRequestAttributeHandler())
@EnableWebSecurity
http {
csrf {
csrfTokenRequestHandler = XorCsrfTokenRequestAttributeHandler()
return http.build()
<http>
<csrf request-handler-ref="requestHandler"/>
</http>
<b:bean id="requestHandler"
class="org.springframework.security.web.csrf.XorCsrfTokenRequestAttributeHandler"/>
Using the CsrfTokenRequestAttributeHandler
The CsrfTokenRequestAttributeHandler
makes the CsrfToken
The |
or X-XSRF-TOKEN
by default).
The primary use of CsrfTokenRequestAttributeHandler
is to opt-out of BREACH protection of the CsrfToken
, which can be configured using the following configuration:
Java
Kotlin
XML
@EnableWebSecurity
http
.csrfTokenRequestHandler(new CsrfTokenRequestAttributeHandler())
@EnableWebSecurity
http {
csrf {
csrfTokenRequestHandler = CsrfTokenRequestAttributeHandler()
return http.build()
<http>
</http>
class="org.springframework.security.web.csrf.CsrfTokenRequestAttributeHandler"/>
Customizing the CsrfTokenRequestHandler
You can implement the CsrfTokenRequestHandler
interface to customize the strategy for handling and resolving tokens.
The |
Once you’ve implemented the CsrfTokenRequestHandler
Java
Kotlin
XML
@EnableWebSecurity
http
.csrfTokenRequestHandler(new CustomCsrfTokenRequestHandler())
@EnableWebSecurity
http {
csrf {
csrfTokenRequestHandler = CustomCsrfTokenRequestHandler()
return http.build()
<http>
</http>
class="example.CustomCsrfTokenRequestHandler"/>
The |
The |
The |
Deferred Loading of the CsrfToken
By default, Spring Security defers loading of the CsrfToken
until it is needed.
The |
Because Spring Security also stores the CsrfToken
in the HttpSession
by default, deferred CSRF tokens can improve performance by not requiring the session to be loaded on every request.
In the event that you want to opt-out of deferred tokens and cause the CsrfToken
to be loaded on every request, you can do so with the following configuration:
Java
Kotlin
XML
@EnableWebSecurity
XorCsrfTokenRequestAttributeHandler requestHandler = new XorCsrfTokenRequestAttributeHandler();
// set the name of the attribute the CsrfToken will be populated on
requestHandler.setCsrfRequestAttributeName(null);
http
.csrfTokenRequestHandler(requestHandler)
@EnableWebSecurity
val requestHandler = XorCsrfTokenRequestAttributeHandler()
http {
csrf {
csrfTokenRequestHandler = requestHandler
return http.build()
<http>
</http>
class="org.springframework.security.web.csrf.CsrfTokenRequestAttributeHandler">
<b:property name="csrfRequestAttributeName">
<b:null/>
</b:property>
</b:bean>
By setting the |
The |
By setting the |
Integrating with CSRF Protection
For the synchronizer token pattern to protect against CSRF attacks, we must include the actual CSRF token in the HTTP request. This must be included in a part of the request (a form parameter, an HTTP header, or other part) that is not automatically included in the HTTP request by the browser.
The following sections describe the various ways a frontend or client application can integrate with a CSRF-protected backend application:
HTML Forms
To submit an HTML form, the CSRF token must be included in the form as a hidden input. For example, the rendered HTML might look like:
<input type="hidden"
name="_csrf"
value="4bfd1575-3ad1-4d21-96c7-4ef2d9f86721"/>
The following view technologies automatically include the actual CSRF token in a form that has an unsafe HTTP method, such as a POST:
Any other view technology that integrates with
RequestDataValueProcessor
(viaCsrfRequestDataValueProcessor
You can also include the token yourself via the csrfInput tag
If these options are not available, you can take advantage of the fact that the CsrfToken
is exposed as an HttpServletRequest
attribute named _csrf
The following example does this with a JSP:
<c:url var="logoutUrl" value="/logout"/>
<form action="${logoutUrl}"
method="post">
<input type="submit"
value="Log out" />
name="${_csrf.parameterName}"
value="${_csrf.token}"/>
</form>
JavaScript Applications
JavaScript applications typically use JSON instead of HTML. If you use JSON, you can submit the CSRF token within an HTTP request header instead of a request parameter.
In order to obtain the CSRF token, you can configure Spring Security to store the expected CSRF token in a cookie. By storing the expected token in a cookie, JavaScript frameworks such as Angular can automatically include the actual CSRF token as an HTTP request header.
There are special considerations for BREACH protection and deferred tokens when integrating a single-page application (SPA) with Spring Security’s CSRF protection. A full configuration example is provided in the next section. |
You can read about different types of JavaScript applications in the following sections:
There are special considerations for integrating a single-page application (SPA) with Spring Security’s CSRF protection.
Recall that Spring Security provides BREACH protection of the CsrfToken
by default.
When storing the expected CSRF token in a cookie, JavaScript applications will only have access to the plain token value and will not have access to the encoded value.
A customized request handler for resolving the actual token value will need to be provided.
In addition, the cookie storing the CSRF token will be cleared upon authentication success and logout success. Spring Security defers loading a new CSRF token by default, and additional work is required to return a fresh cookie.
Refreshing the token after authentication success and logout success is required because the |
In order to easily integrate a single-page application with Spring Security, the following configuration can be used:
Java
Kotlin
XML
@EnableWebSecurity
http
.csrfTokenRepository(CookieCsrfTokenRepository.withHttpOnlyFalse()) (1)
.csrfTokenRequestHandler(new SpaCsrfTokenRequestHandler()) (2)
final class SpaCsrfTokenRequestHandler implements CsrfTokenRequestHandler {
private final CsrfTokenRequestHandler plain = new CsrfTokenRequestAttributeHandler();
private final CsrfTokenRequestHandler xor = new XorCsrfTokenRequestAttributeHandler();
public void handle(HttpServletRequest request, HttpServletResponse response, Supplier<CsrfToken> csrfToken) {
* Always use XorCsrfTokenRequestAttributeHandler to provide BREACH protection of
* the CsrfToken when it is rendered in the response body.
this.xor.handle(request, response, csrfToken);
* Render the token value to a cookie by causing the deferred token to be loaded.
csrfToken.get();
public String resolveCsrfTokenValue(HttpServletRequest request, CsrfToken csrfToken) {
String headerValue = request.getHeader(csrfToken.getHeaderName());
* If the request contains a request header, use CsrfTokenRequestAttributeHandler
* to resolve the CsrfToken. This applies when a single-page application includes
* the header value automatically, which was obtained via a cookie containing the
* raw CsrfToken.
* In all other cases (e.g. if the request contains a request parameter), use
* XorCsrfTokenRequestAttributeHandler to resolve the CsrfToken. This applies
* when a server-side rendered form includes the _csrf request parameter as a
* hidden input.
return (StringUtils.hasText(headerValue) ? this.plain : this.xor).resolveCsrfTokenValue(request, csrfToken);
@EnableWebSecurity
http {
csrf {
csrfTokenRepository = CookieCsrfTokenRepository.withHttpOnlyFalse() (1)
csrfTokenRequestHandler = SpaCsrfTokenRequestHandler() (2)
return http.build()
class SpaCsrfTokenRequestHandler : CsrfTokenRequestHandler {
private val plain: CsrfTokenRequestHandler = CsrfTokenRequestAttributeHandler()
private val xor: CsrfTokenRequestHandler = XorCsrfTokenRequestAttributeHandler()
override fun handle(request: HttpServletRequest, response: HttpServletResponse, csrfToken: Supplier<CsrfToken>) {
csrfToken.get()
override fun resolveCsrfTokenValue(request: HttpServletRequest, csrfToken: CsrfToken): String? {
val headerValue = request.getHeader(csrfToken.headerName)
* raw CsrfToken.
return if (StringUtils.hasText(headerValue)) {
plain
} else {
* hidden input.
xor
}.resolveCsrfTokenValue(request, csrfToken)
<http>
<csrf
token-repository-ref="tokenRepository" (1)
request-handler-ref="requestHandler"/> (2)
</http>
class="org.springframework.security.web.csrf.CookieCsrfTokenRepository"
p:cookieHttpOnly="false"/>
class="example.SpaCsrfTokenRequestHandler"/>
1 | Configure CookieCsrfTokenRepository with HttpOnly set to false so the cookie can be read by the JavaScript application. |
2 | Configure a custom CsrfTokenRequestHandler that resolves the CSRF token based on whether it is an HTTP request header (X-XSRF-TOKEN ) or request parameter (_csrf ).
This implementation also causes the deferred CsrfToken to be loaded on every request, which will return a new cookie if needed. |
Multi-Page Applications
For multi-page applications where JavaScript is loaded on each page, an alternative to exposing the CSRF token in a cookie is to include the CSRF token within your meta
tags.
The HTML might look something like this:
<html>
<head>
<meta name="_csrf" content="4bfd1575-3ad1-4d21-96c7-4ef2d9f86721"/>
<meta name="_csrf_header" content="X-CSRF-TOKEN"/>
</head>
</html>
In order to include the CSRF token in the request, you can take advantage of the fact that the CsrfToken
<html>
<head>
<meta name="_csrf" content="${_csrf.token}"/>
<!-- default header name is X-CSRF-TOKEN -->
<meta name="_csrf_header" content="${_csrf.headerName}"/>
</head>
</html>
Once the meta tags contain the CSRF token, the JavaScript code can read the meta tags and include the CSRF token as a header. If you use jQuery, you can do this with the following code:
$(function () {
var token = $("meta[name='_csrf']").attr("content");
var header = $("meta[name='_csrf_header']").attr("content");
$(document).ajaxSend(function(e, xhr, options) {
xhr.setRequestHeader(header, token);
Other JavaScript Applications
Another option for JavaScript applications is to include the CSRF token in an HTTP response header.
One way to achieve this is through the use of a @ControllerAdvice
with the CsrfTokenArgumentResolver
The following is an example of @ControllerAdvice
that applies to all controller endpoints in the application:
Java
Kotlin
@ControllerAdvice
public class CsrfControllerAdvice {
@ModelAttribute
public void getCsrfToken(HttpServletResponse response, CsrfToken csrfToken) {
response.setHeader(csrfToken.getHeaderName(), csrfToken.getToken());
@ControllerAdvice
@ModelAttribute
fun getCsrfToken(response: HttpServletResponse, csrfToken: CsrfToken) {
response.setHeader(csrfToken.headerName, csrfToken.token)
Because this |
It is important to remember that controller endpoints and controller advice are called after the Spring Security filter chain.
This means that this |
The CSRF token will now be available in a response header (X-CSRF-TOKEN
or X-XSRF-TOKEN
by default) for any custom endpoints the controller advice applies to.
Any request to the backend can be used to obtain the token from the response, and a subsequent request can include the token in a request header with the same name.
Mobile Applications
Like JavaScript applications, mobile applications typically use JSON instead of HTML. A backend application that does not serve browser traffic may choose to disable CSRF. In that case, no additional work is required.
However, a backend application that also serves browser traffic and therefore still requires CSRF protection may continue to store the CsrfToken
in the session instead of in a cookie.
In this case, a typical pattern for integrating with the backend is to expose a /csrf
endpoint to allow the frontend (mobile or browser client) to request a CSRF token on demand.
The benefit of using this pattern is that the CSRF token can continue to be deferred and only needs to be loaded from the session when a request requires CSRF protection.
The use of a custom endpoint also means the client application can request that a new token be generated on demand (if necessary) by issuing an explicit request.
This pattern can be used for any type of application that requires CSRF protection, not just mobile applications. While this approach isn’t typically required in those cases, it is another option for integrating with a CSRF-protected backend. |
The following is an example of the /csrf
endpoint that makes use of the CsrfTokenArgumentResolver
/csrf
endpoint-
Java
Kotlin
@RestController
public class CsrfController {
@GetMapping("/csrf")
public CsrfToken csrf(CsrfToken csrfToken) {
return csrfToken;
@RestController
fun csrf(csrfToken: CsrfToken): CsrfToken {
return csrfToken
You may consider adding |
This endpoint should be called to obtain a CSRF token when the application is launched or initialized (e.g. at load time), and also after authentication success and logout success.
Once you’ve obtained the CSRF token, you will need to include it as an HTTP request header (one of X-CSRF-TOKEN
or X-XSRF-TOKEN
by default) yourself.
Because this |
Handle AccessDeniedException
To handle an AccessDeniedException
such as InvalidCsrfTokenException
, you can configure Spring Security to handle these exceptions in any way you like.
For example, you can configure a custom access denied page using the following configuration:
AccessDeniedHandler
Java
Kotlin
XML
@EnableWebSecurity
http
.exceptionHandling((exceptionHandling) -> exceptionHandling
.accessDeniedPage("/access-denied")
@EnableWebSecurity
http {
exceptionHandling {
accessDeniedPage = "/access-denied"
return http.build()
<http>
<access-denied-handler error-page="/access-denied"/>
</http>
CSRF Testing
You can use Spring Security’s testing support and CsrfRequestPostProcessor
to test CSRF protection, like this:
Java
Kotlin
import static org.springframework.security.test.web.servlet.request.SecurityMockMvcRequestPostProcessors.*;
import static org.springframework.security.test.web.servlet.setup.SecurityMockMvcConfigurers.*;
import static org.springframework.test.web.servlet.request.MockMvcRequestBuilders.*;
import static org.springframework.test.web.servlet.result.MockMvcResultMatchers.*;
@ExtendWith(SpringExtension.class)
@ContextConfiguration(classes = SecurityConfig.class)
@WebAppConfiguration
public class CsrfTests {
private MockMvc mockMvc;
@BeforeEach
public void setUp(WebApplicationContext applicationContext) {
this.mockMvc = MockMvcBuilders.webAppContextSetup(applicationContext)
.apply(springSecurity())
@Test
public void loginWhenValidCsrfTokenThenSuccess() throws Exception {
this.mockMvc.perform(post("/login").with(csrf())
.accept(MediaType.TEXT_HTML)
.param("username", "user")
.param("password", "password"))
.andExpect(status().is3xxRedirection())
.andExpect(header().string(HttpHeaders.LOCATION, "/"));
@Test
public void loginWhenInvalidCsrfTokenThenForbidden() throws Exception {
this.mockMvc.perform(post("/login").with(csrf().useInvalidToken())
.andExpect(status().isForbidden());
@Test
public void loginWhenMissingCsrfTokenThenForbidden() throws Exception {
@Test
@WithMockUser
public void logoutWhenValidCsrfTokenThenSuccess() throws Exception {
this.mockMvc.perform(post("/logout").with(csrf())
.accept(MediaType.TEXT_HTML))
.andExpect(header().string(HttpHeaders.LOCATION, "/login?logout"));
import org.springframework.security.test.web.servlet.request.SecurityMockMvcRequestPostProcessors.*
import org.springframework.security.test.web.servlet.setup.SecurityMockMvcConfigurers.*
import org.springframework.test.web.servlet.request.MockMvcRequestBuilders.*
import org.springframework.test.web.servlet.result.MockMvcResultMatchers.*
@ExtendWith(SpringExtension::class)
@ContextConfiguration(classes = [SecurityConfig::class])
class CsrfTests {
private lateinit var mockMvc: MockMvc
@BeforeEach
fun setUp(applicationContext: WebApplicationContext) {
.apply<DefaultMockMvcBuilder>(springSecurity())
.build()
@Test
fun loginWhenValidCsrfTokenThenSuccess() {
.andExpect(status().is3xxRedirection)
@Test
fun loginWhenInvalidCsrfTokenThenForbidden() {
.andExpect(status().isForbidden)
@Test
fun loginWhenMissingCsrfTokenThenForbidden() {
@Test
@WithMockUser
@Throws(Exception::class)
fun logoutWhenValidCsrfTokenThenSuccess() {
Disable CSRF Protection
By default, CSRF protection is enabled, which affects integrating with the backend and testing your application. Before disabling CSRF protection, consider whether it makes sense for your application.
You can also consider whether only certain endpoints do not require CSRF protection and configure an ignoring rule, as in the following example:
Java
Kotlin
XML
@EnableWebSecurity
http
.ignoringRequestMatchers("/api/*")
@EnableWebSecurity
http {
csrf {
return http.build()
<http>
<csrf request-matcher-ref="csrfMatcher"/>
</http>
<b:bean id="csrfMatcher"
class="org.springframework.security.web.util.matcher.AndRequestMatcher">
<b:constructor-arg value="#{T(org.springframework.security.web.csrf.CsrfFilter).DEFAULT_CSRF_MATCHER}"/>
<b:constructor-arg>
<b:bean class="org.springframework.security.web.util.matcher.NegatedRequestMatcher">
<b:bean class="org.springframework.security.web.util.matcher.AntPathRequestMatcher">
<b:constructor-arg value="/api/*"/>
</b:bean>
</b:bean>
</b:constructor-arg>
</b:bean>
If you need to disable CSRF protection, you can do so using the following configuration:
Java
Kotlin
XML
@EnableWebSecurity
http
.csrf((csrf) -> csrf.disable());
@EnableWebSecurity
http {
csrf {
disable()
return http.build()
<http>
<csrf disabled="true"/>
</http>
CSRF Considerations
There are a few special considerations when implementing protection against CSRF attacks. This section discusses those considerations as they pertain to servlet environments. See CSRF Considerations for a more general discussion.
Logging In
It is important to require CSRF for log in requests to protect against forging log in attempts. Spring Security’s servlet support does this out of the box.
Logging Out
It is important to require CSRF for log out requests to protect against forging logout attempts.
If CSRF protection is enabled (the default), Spring Security’s LogoutFilter
will only process HTTP POST requests.
This ensures that logging out requires a CSRF token and that a malicious user cannot forcibly log your users out.
The easiest approach is to use a form to log the user out. If you really want a link, you can use JavaScript to have the link perform a POST (maybe on a hidden form). For browsers with JavaScript that is disabled, you can optionally have the link take the user to a log out confirmation page that performs the POST.
If you really want to use HTTP GET with logout, you can do so.
However, remember that this is generally not recommended.
For example, the following logs out when the /logout
URL is requested with any HTTP method:
Java
Kotlin
@EnableWebSecurity
http
.logout((logout) -> logout
.logoutRequestMatcher(new AntPathRequestMatcher("/logout"))
@EnableWebSecurity
http {
logout {
logoutRequestMatcher = AntPathRequestMatcher("/logout")
return http.build()
See the Logout chapter for more information.
CSRF and Session Timeouts
By default, Spring Security stores the CSRF token in the HttpSession
using the HttpSessionCsrfTokenRepository
This can lead to a situation where the session expires, leaving no CSRF token to validate against.
We have already discussed general solutions to session timeouts. This section discusses the specifics of CSRF timeouts as it pertains to the servlet support.
You can change the storage of the CSRF token to be in a cookie.
For details, see the Using the CookieCsrfTokenRepository
section.
If a token does expire, you might want to customize how it is handled by specifying a custom AccessDeniedHandler
The custom AccessDeniedHandler
can process the InvalidCsrfTokenException
any way you like.
Multipart (file upload)
We have already discussed how protecting multipart requests (file uploads) from CSRF attacks causes a chicken and the egg problem. When JavaScript is available, we recommend including the CSRF token in an HTTP request header to side-step the issue.
If JavaScript is not available, the following sections discuss options for placing the CSRF token in the body and url within a servlet application.
You can find more information about using multipart forms with Spring in the Multipart Resolver section of the Spring reference and the |
Place CSRF Token in the Body
We have already discussed the tradeoffs of placing the CSRF token in the body. In this section, we discuss how to configure Spring Security to read the CSRF from the body.
To read the CSRF token from the body, the MultipartFilter
is specified before the Spring Security filter.
Specifying the MultipartFilter
before the Spring Security filter means that there is no authorization for invoking the MultipartFilter
, which means anyone can place temporary files on your server.
However, only authorized users can submit a file that is processed by your application.
In general, this is the recommended approach because the temporary file upload should have a negligible impact on most servers.
MultipartFilter
Java
Kotlin
XML
public class SecurityApplicationInitializer extends AbstractSecurityWebApplicationInitializer {
protected void beforeSpringSecurityFilterChain(ServletContext servletContext) {
insertFilters(servletContext, new MultipartFilter());
class SecurityApplicationInitializer : AbstractSecurityWebApplicationInitializer() {
override fun beforeSpringSecurityFilterChain(servletContext: ServletContext?) {
insertFilters(servletContext, MultipartFilter())
<filter>
<filter-name>MultipartFilter</filter-name>
<filter-class>org.springframework.web.multipart.support.MultipartFilter</filter-class>
</filter>
<filter>
<filter-name>springSecurityFilterChain</filter-name>
<filter-class>org.springframework.web.filter.DelegatingFilterProxy</filter-class>
</filter>
<filter-mapping>
<url-pattern>/*</url-pattern>
</filter-mapping>
<filter-mapping>
</filter-mapping>
To ensure that |
Include a CSRF Token in a URL
If letting unauthorized users upload temporary files is not acceptable, an alternative is to place the MultipartFilter
after the Spring Security filter and include the CSRF as a query parameter in the action attribute of the form.
Since the CsrfToken
, we can use that to create an action
with the CSRF token in it.
<form method="post"
action="./upload?${_csrf.parameterName}=${_csrf.token}"
enctype="multipart/form-data">
HiddenHttpMethodFilter
We have already discussed the trade-offs of placing the CSRF token in the body.
In Spring’s Servlet support, overriding the HTTP method is done by using HiddenHttpMethodFilter
You can find more information in the HTTP Method Conversion section of the reference documentation.
To ensure that |
Further Reading
Now that you have reviewed CSRF protection, consider learning more about exploit protection including secure headers and the HTTP firewall or move on to learning how to test your application.
