This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.3.3! |
In addition to modeling authorization at the request level, Spring Security also supports modeling at the method level.
You can activate it in your application by annotating any @Configuration
class with @EnableMethodSecurity
or adding <method-security>
to any XML configuration file, like so:
Java
Kotlin
Xml
<sec:method-security/>
Then, you are immediately able to annotate any Spring-managed class or method with @PreAuthorize
, @PostAuthorize
, @PreFilter
, and @PostFilter
to authorize method invocations, including the input parameters and return values.
Spring Boot Starter Security does not activate method-level authorization by default. |
Method Security supports many other use cases as well including AspectJ support, custom annotations, and several configuration points. Consider learning about the following use cases:
Understanding how method security works and reasons to use it
Authorizing methods with
@PreAuthorize
and@PostAuthorize
Filtering methods with
@PreFilter
and@PostFilter
Authorizing methods with JSR-250 annotations
Authorizing methods with AspectJ expressions
Integrating with AspectJ byte-code weaving
Coordinating with @Transactional and other AOP-based annotations
Customizing SpEL expression handling
Integrating with custom authorization systems
How Method Security Works
Spring Security’s method authorization support is handy for:
Extracting fine-grained authorization logic; for example, when the method parameters and return values contribute to the authorization decision.
Enforcing security at the service layer
Stylistically favoring annotation-based over
HttpSecurity
-based configuration
And since Method Security is built using Spring AOP, you have access to all its expressive power to override Spring Security’s defaults as needed.
As already mentioned, you begin by adding @EnableMethodSecurity
to a @Configuration
class or <sec:method-security/>
in a Spring XML configuration file.
This annotation and XML element supercede
If you are using |
Method authorization is a combination of before- and after-method authorization. Consider a service bean that is annotated in the following way:
Java
Kotlin
@Service
public class MyCustomerService {
@PreAuthorize("hasAuthority('permission:read')")
@PostAuthorize("returnObject.owner == authentication.name")
public Customer readCustomer(String id) { ... }
@Service
open class MyCustomerService {
fun readCustomer(val id: String): Customer { ... }
A given invocation to MyCustomerService#readCustomer
may look something like this when Method Security is activated:
Spring AOP invokes its proxy method for
readCustomer
. Among the proxy’s other advisors, it invokes anAuthorizationManagerBeforeMethodInterceptor
that matches the@PreAuthorize
pointcut -
The interceptor invokes
PreAuthorizeAuthorizationManager#check
The authorization manager uses a
MethodSecurityExpressionHandler
to parse the annotation’s SpEL expression and constructs a correspondingEvaluationContext
from aMethodSecurityExpressionRoot
containing aSupplier<Authentication>
andMethodInvocation
The interceptor uses this context to evaluate the expression; specifically, it reads the
Authentication
from theSupplier
and checks whether it haspermission:read
in its collection of authorities -
If the evaluation passes, then Spring AOP proceeds to invoke the method.
If not, the interceptor publishes an
AuthorizationDeniedEvent
and throws anAccessDeniedException
which theExceptionTranslationFilter
catches and returns a 403 status code to the response -
After the method returns, Spring AOP invokes an
AuthorizationManagerAfterMethodInterceptor
that matches the@PostAuthorize
pointcut, operating the same as above, but withPostAuthorizeAuthorizationManager
If the evaluation passes (in this case, the return value belongs to the logged-in user), processing continues normally
, which theExceptionTranslationFilter
If the method is not being called in the context of an HTTP request, you will likely need to handle the AccessDeniedException yourself
Multiple Annotations Are Computed In Series
As demonstrated above, if a method invocation involves multiple Method Security annotations, each of those is processed one at a time. This means that they can collectively be thought of as being "anded" together. In other words, for an invocation to be authorized, all annotation inspections need to pass authorization.
Repeated Annotations Are Not Supported
That said, it is not supported to repeat the same annotation on the same method.
For example, you cannot place @PreAuthorize
twice on the same method.
Instead, use SpEL’s boolean support or its support for delegating to a separate bean.
Each Annotation Has Its Own Pointcut
Each annotation has its own pointcut instance that looks for that annotation or its meta-annotation counterparts across the entire object hierarchy, starting at the method and its enclosing class.
Each Annotation Has Its Own Method Interceptor
Each annotation has its own dedicated method interceptor.
The reason for this is to make things more composable.
For example, if needed, you can disable the Spring Security defaults and publish only the @PostAuthorize
method interceptor.
The method interceptors are as follows:
For
@PreAuthorize
, Spring Security usesAuthorizationManagerBeforeMethodInterceptor#preAuthorize
, which in turn usesPreAuthorizeAuthorizationManager
For
@PostAuthorize
, Spring Security usesAuthorizationManagerAfterMethodInterceptor#postAuthorize
, which in turn usesPostAuthorizeAuthorizationManager
For
@PreFilter
, Spring Security usesPreFilterAuthorizationMethodInterceptor
For
@PostFilter
, Spring Security usesPostFilterAuthorizationMethodInterceptor
For
@Secured
, Spring Security usesAuthorizationManagerBeforeMethodInterceptor#secured
, which in turn usesSecuredAuthorizationManager
For JSR-250 annotations, Spring Security uses
AuthorizationManagerBeforeMethodInterceptor#jsr250
, which in turn usesJsr250AuthorizationManager
Generally speaking, you can consider the following listing as representative of what interceptors Spring Security publishes when you add @EnableMethodSecurity
Java
@Role(BeanDefinition.ROLE_INFRASTRUCTURE)
static Advisor preAuthorizeMethodInterceptor() {
return AuthorizationManagerBeforeMethodInterceptor.preAuthorize();
static Advisor postAuthorizeMethodInterceptor() {
return AuthorizationManagerAfterMethodInterceptor.postAuthorize();
static Advisor preFilterMethodInterceptor() {
return AuthorizationManagerBeforeMethodInterceptor.preFilter();
static Advisor postFilterMethodInterceptor() {
return AuthorizationManagerAfterMethodInterceptor.postFilter();
Favor Granting Authorities Over Complicated SpEL Expressions
Quite often it can be tempting to introduce a complicated SpEL expression like the following:
Java
@PreAuthorize("hasAuthority('permission:read') || hasRole('ADMIN')")
However, you could instead grant permission:read
to those with ROLE_ADMIN
One way to do this is with a RoleHierarchy
like so:
Java
Kotlin
Xml
static RoleHierarchy roleHierarchy() {
return RoleHierarchyImpl.fromHierarchy("ROLE_ADMIN > permission:read");
companion object {
fun roleHierarchy(): RoleHierarchy {
<bean id="roleHierarchy"
class="org.springframework.security.access.hierarchicalroles.RoleHierarchyImpl" factory-method="fromHierarchy">
<constructor-arg value="ROLE_ADMIN > permission:read"/>
</bean>
and then set that in a MethodSecurityExpressionHandler
instance.
This then allows you to have a simpler @PreAuthorize
expression like this one:
Java
Kotlin
Or, where possible, adapt application-specific authorization logic into granted authorities at login time.
If you are using |
Comparing Request-level vs Method-level Authorization
When should you favor method-level authorization over request-level authorization? Some of it comes down to taste; however, consider the following strengths list of each to help you decide.
request-level |
method-level |
authorization type |
coarse-grained |
fine-grained |
configuration location |
declared in a config class |
local to method declaration |
configuration style |
DSL |
Annotations |
authorization definitions |
programmatic |
SpEL |
The main tradeoff seems to be where you want your authorization rules to live.
It’s important to remember that when you use annotation-based Method Security, then unannotated methods are not secured.
To protect against this, declare a catch-all authorization rule in your HttpSecurity instance.
request-level |
method-level |
coarse-grained |
fine-grained |
DSL |
Annotations |
programmatic |
SpEL |
Authorizing with Annotations
The primary way Spring Security enables method-level authorization support is through annotations that you can add to methods, classes, and interfaces.
Authorizing Method Invocation with @PreAuthorize
When Method Security is active, you can annotate a method with the @PreAuthorize
annotation like so:
Java
Kotlin
@Component
public class BankService {
@PreAuthorize("hasRole('ADMIN')")
public Account readAccount(Long id) {
// ... is only invoked if the `Authentication` has the `ROLE_ADMIN` authority
@Component
open class BankService {
fun readAccount(val id: Long): Account {
This is meant to indicate that the method can only be invoked if the provided expression hasRole('ADMIN')
passes.
You can then test the class to confirm it is enforcing the authorization rule like so:
Java
Kotlin
@Autowired
BankService bankService;
@WithMockUser(roles="ADMIN")
@Test
void readAccountWithAdminRoleThenInvokes() {
Account account = this.bankService.readAccount("12345678");
// ... assertions
@WithMockUser(roles="WRONG")
@Test
void readAccountWithWrongRoleThenAccessDenied() {
assertThatExceptionOfType(AccessDeniedException.class).isThrownBy(
() -> this.bankService.readAccount("12345678"));
@Test
fun readAccountWithAdminRoleThenInvokes() {
val account: Account = this.bankService.readAccount("12345678")
// ... assertions
@Test
fun readAccountWithWrongRoleThenAccessDenied() {
assertThatExceptionOfType(AccessDeniedException::class.java).isThrownBy {
@PreAuthorize also can be a meta-annotation, be defined at the class or interface level, and use SpEL Authorization Expressions.
While @PreAuthorize
is quite helpful for declaring needed authorities, it can also be used to evaluate more complex expressions that involve the method parameters.
Authorization Method Results with @PostAuthorize
When Method Security is active, you can annotate a method with the @PostAuthorize
annotation like so:
Java
Kotlin
@Component
// ... is only returned if the `Account` belongs to the logged in user
@Component
This is meant to indicate that the method can only return the value if the provided expression returnObject.owner == authentication.name
passes.
returnObject
represents the Account
object to be returned.
You can then test the class to confirm it is enforcing the authorization rule:
Java
Kotlin
@Autowired
@WithMockUser(username="owner")
@Test
void readAccountWhenOwnedThenReturns() {
// ... assertions
@WithMockUser(username="wrong")
@Test
void readAccountWhenNotOwnedThenAccessDenied() {
@Test
fun readAccountWhenOwnedThenReturns() {
// ... assertions
@Test
fun readAccountWhenNotOwnedThenAccessDenied() {
@PostAuthorize also can be a meta-annotation, be defined at the class or interface level, and use SpEL Authorization Expressions.
@PostAuthorize
is particularly helpful when defending against Insecure Direct Object Reference.
In fact, it can be defined as a meta-annotation like so:
Java
Kotlin
@Target({ ElementType.METHOD, ElementType.TYPE })
public @interface RequireOwnership {}
@Target(ElementType.METHOD, ElementType.TYPE)
annotation class RequireOwnership
Allowing you to instead annotate the service in the following way:
Java
Kotlin
@Component
@RequireOwnership
@Component
@RequireOwnership
The result is that the above method will only return the Account
if its owner
attribute matches the logged-in user’s name
If not, Spring Security will throw an AccessDeniedException
and return a 403 status code.
Filtering Method Parameters with @PreFilter
When Method Security is active, you can annotate a method with the @PreFilter
annotation like so:
Java
Kotlin
@Component
@PreFilter("filterObject.owner == authentication.name")
public Collection<Account> updateAccounts(Account... accounts) {
// ... `accounts` will only contain the accounts owned by the logged-in user
return updated;
@Component
fun updateAccounts(vararg accounts: Account): Collection<Account> {
return updated
This is meant to filter out any values from accounts
where the expression filterObject.owner == authentication.name
fails.
filterObject
represents each account
in accounts
and is used to test each account
You can then test the class in the following way to confirm it is enforcing the authorization rule:
Java
Kotlin
@Autowired
@Test
void updateAccountsWhenOwnedThenReturns() {
Account ownedBy = ...
Account notOwnedBy = ...
Collection<Account> updated = this.bankService.updateAccounts(ownedBy, notOwnedBy);
assertThat(updated).containsOnly(ownedBy);
@Autowired
lateinit var bankService: BankService
@Test
fun updateAccountsWhenOwnedThenReturns() {
val ownedBy: Account = ...
val notOwnedBy: Account = ...
val updated: Collection<Account> = bankService.updateAccounts(ownedBy, notOwnedBy)
@PreFilter also can be a meta-annotation, be defined at the class or interface level, and use SpEL Authorization Expressions.
@PreFilter
supports arrays, collections, maps, and streams (so long as the stream is still open).
For example, the above updateAccounts
declaration will function the same way as the following other four:
Java
Kotlin
public Collection<Account> updateAccounts(Account[] accounts)
public Collection<Account> updateAccounts(Collection<Account> accounts)
@PreFilter("filterObject.value.owner == authentication.name")
public Collection<Account> updateAccounts(Map<String, Account> accounts)
public Collection<Account> updateAccounts(Stream<Account> accounts)
fun updateAccounts(accounts: Array<Account>): Collection<Account>
fun updateAccounts(accounts: Collection<Account>): Collection<Account>
fun updateAccounts(accounts: Map<String, Account>): Collection<Account>
fun updateAccounts(accounts: Stream<Account>): Collection<Account>
The result is that the above method will only have the Account
instances where their owner
Filtering Method Results with @PostFilter
When Method Security is active, you can annotate a method with the @PostFilter
annotation like so:
Java
Kotlin
@Component
@PostFilter("filterObject.owner == authentication.name")
public Collection<Account> readAccounts(String... ids) {
// ... the return value will be filtered to only contain the accounts owned by the logged-in user
return accounts;
@Component
fun readAccounts(vararg ids: String): Collection<Account> {
return accounts
This is meant to filter out any values from the return value where the expression filterObject.owner == authentication.name
fails.
filterObject
in accounts
You can then test the class like so to confirm it is enforcing the authorization rule:
Java
Kotlin
@Autowired
@Test
void readAccountsWhenOwnedThenReturns() {
Collection<Account> accounts = this.bankService.updateAccounts("owner", "not-owner");
assertThat(accounts).hasSize(1);
assertThat(accounts.get(0).getOwner()).isEqualTo("owner");
@Autowired
@Test
fun readAccountsWhenOwnedThenReturns() {
val accounts: Collection<Account> = bankService.updateAccounts("owner", "not-owner")
assertThat(accounts[0].owner).isEqualTo("owner")
@PostFilter also can be a meta-annotation, be defined at the class or interface level, and use SpEL Authorization Expressions.
@PostFilter
For example, the above readAccounts
declaration will function the same way as the following other three:
Java
Kotlin
public Account[] readAccounts(String... ids)
@PostFilter("filterObject.value.owner == authentication.name")
public Map<String, Account> readAccounts(String... ids)
public Stream<Account> readAccounts(String... ids)
fun readAccounts(vararg ids: String): Array<Account>
fun readAccounts(vararg ids: String): Map<String, Account>
fun readAccounts(vararg ids: String): Stream<Account>
The result is that the above method will return the Account
In-memory filtering can obviously be expensive, and so be considerate of whether it is better to filter the data in the data layer instead. |
Authorizing Method Invocation with @Secured
@Secured
is a legacy option for authorizing invocations.
@PreAuthorize
supercedes it and is recommended instead.
To use the @Secured
annotation, you should first change your Method Security declaration to enable it like so:
Java
Kotlin
Xml
@EnableMethodSecurity(securedEnabled = true)
<sec:method-security secured-enabled="true"/>
This will cause Spring Security to publish the corresponding method interceptor that authorizes methods, classes, and interfaces annotated with @Secured
Authorizing Method Invocation with JSR-250 Annotations
In case you would like to use JSR-250 annotations, Spring Security also supports that.
@PreAuthorize
has more expressive power and is thus recommended.
To use the JSR-250 annotations, you should first change your Method Security declaration to enable them like so:
Java
Kotlin
Xml
@EnableMethodSecurity(jsr250Enabled = true)
<sec:method-security jsr250-enabled="true"/>
This will cause Spring Security to publish the corresponding method interceptor that authorizes methods, classes, and interfaces annotated with @RolesAllowed
, @PermitAll
, and @DenyAll
Declaring Annotations at the Class or Interface Level
It’s also supported to have Method Security annotations at the class and interface level.
If it is at the class level like so:
Java
Kotlin
@Controller
@PreAuthorize("hasAuthority('ROLE_USER')")
public class MyController {
@GetMapping("/endpoint")
public String endpoint() { ... }
@Controller
open class MyController {
fun endpoint(): String { ... }
then all methods inherit the class-level behavior.
Or, if it’s declared like the following at both the class and method level:
Java
Kotlin
@Controller
@PreAuthorize("hasAuthority('ROLE_ADMIN')")
@Controller
then methods declaring the annotation override the class-level annotation.
The same is true for interfaces, with the exception that if a class inherits the annotation from two different interfaces, then startup will fail. This is because Spring Security has no way to tell which one you want to use.
In cases like this, you can resolve the ambiguity by adding the annotation to the concrete method.
Using Meta Annotations
Method Security supports meta annotations. This means that you can take any annotation and improve readability based on your application-specific use cases.
For example, you can simplify @PreAuthorize("hasRole('ADMIN')")
to @IsAdmin
like so:
Java
Kotlin
public @interface IsAdmin {}
annotation class IsAdmin
And the result is that on your secured methods you can now do the following instead:
Java
Kotlin
@Component
@IsAdmin
@Component
@IsAdmin
This results in more readable method definitions.
Templating Meta-Annotation Expressions
You can also opt into using meta-annotation templates, which allow for much more powerful annotation definitions.
First, publish the following bean:
Java
Kotlin
static AnnotationTemplateExpressionDefaults templateExpressionDefaults() {
return new AnnotationTemplateExpressionDefaults();
companion object {
fun templateExpressionDefaults(): AnnotationTemplateExpressionDefaults {
return AnnotationTemplateExpressionDefaults()
Now instead of @IsAdmin
, you can create something more powerful like @HasRole
like so:
Java
Kotlin
@PreAuthorize("hasRole('{value}')")
public @interface HasRole {
String value();
annotation class HasRole(val value: String)
Java
Kotlin
@Component
@HasRole("ADMIN")
@Component
@HasRole("ADMIN")
Note that this works with method variables and all annotation types, too, though you will want to be careful to correctly take care of quotation marks so the resulting SpEL expression is correct.
For example, consider the following @HasAnyRole
annotation:
Java
Kotlin
@PreAuthorize("hasAnyRole({roles})")
public @interface HasAnyRole {
String[] roles();
annotation class HasAnyRole(val roles: Array<String>)
In that case, you’ll notice that you should not use the quotation marks in the expression, but instead in the parameter value like so:
Java
Kotlin
@Component
@HasAnyRole(roles = { "'USER'", "'ADMIN'" })
@Component
@HasAnyRole(roles = arrayOf("'USER'", "'ADMIN'"))
so that, once replaced, the expression becomes @PreAuthorize("hasAnyRole('USER', 'ADMIN')")
Enabling Certain Annotations
You can turn off @EnableMethodSecurity
's pre-configuration and replace it with you own.
You may choose to do this if you want to customize the AuthorizationManager
or Pointcut
Or you may simply want to only enable a specific annotation, like @PostAuthorize
You can do this in the following way:
Java
Kotlin
Xml
@EnableMethodSecurity(prePostEnabled = false)
class MethodSecurityConfig {
Advisor postAuthorize() {
fun postAuthorize() : Advisor {
<sec:method-security pre-post-enabled="false"/>
<aop:config/>
<bean id="postAuthorize"
class="org.springframework.security.authorization.method.AuthorizationManagerBeforeMethodInterceptor"
factory-method="postAuthorize"/>
The above snippet achieves this by first disabling Method Security’s pre-configurations and then publishing the @PostAuthorize
interceptor itself.
Authorizing with <intercept-methods>
While using Spring Security’s annotation-based support is preferred for method security, you can also use XML to declare bean authorization rules.
If you need to declare it in your XML configuration instead, you can use <intercept-methods>
like so:
Xml
<bean class="org.mycompany.MyController">
<intercept-methods>
<protect method="get*" access="hasAuthority('read')"/>
<protect method="*" access="hasAuthority('write')"/>
</intercept-methods>
</bean>
This only supports matching method by prefix or by name. If your needs are more complex than that, use annotation support instead. |
Authorizing Methods Programmatically
As you’ve already seen, there are several ways that you can specify non-trivial authorization rules using Method Security SpEL expressions.
There are a number of ways that you can instead allow your logic to be Java-based instead of SpEL-based. This gives use access the entire Java language for increased testability and flow control.
Using a Custom Bean in SpEL
The first way to authorize a method programmatically is a two-step process.
First, declare a bean that has a method that takes a MethodSecurityExpressionOperations
instance like the following:
Java
Kotlin
@Component("authz")
public class AuthorizationLogic {
public boolean decide(MethodSecurityExpressionOperations operations) {
// ... authorization logic
@Component("authz")
open class AuthorizationLogic {
fun decide(val operations: MethodSecurityExpressionOperations): boolean {
Then, reference that bean in your annotations in the following way:
Java
Kotlin
@Controller
@PreAuthorize("@authz.decide(#root)")
@Controller
fun String endpoint() {
Spring Security will invoke the given method on that bean for each method invocation.
What’s nice about this is all your authorization logic is in a separate class that can be independently unit tested and verified for correctness. It also has access to the full Java language.
In addition to returning a Boolean , you can also return null to indicate that the code abstains from making a decision.
If you want to include more information about the nature of the decision, you can instead return a custom AuthorizationDecision
like this:
Java
Kotlin
@Component("authz")
public AuthorizationDecision decide(MethodSecurityExpressionOperations operations) {
return new MyAuthorizationDecision(false, details);
@Component("authz")
fun decide(val operations: MethodSecurityExpressionOperations): AuthorizationDecision {
return MyAuthorizationDecision(false, details)
Or throw a custom AuthorizationDeniedException
instance.
Note, though, that returning an object is preferred as this doesn’t incur the expense of generating a stacktrace.
Then, you can access the custom details when you customize how the authorization result is handled.
Using a Custom Authorization Manager
The second way to authorize a method programmatically is to create a custom AuthorizationManager
First, declare an authorization manager instance, perhaps like this one:
Java
Kotlin
@Component
public class MyAuthorizationManager implements AuthorizationManager<MethodInvocation>, AuthorizationManager<MethodInvocationResult> {
public AuthorizationDecision check(Supplier<Authentication> authentication, MethodInvocation invocation) {
public AuthorizationDecision check(Supplier<Authentication> authentication, MethodInvocationResult invocation) {
@Component
class MyAuthorizationManager : AuthorizationManager<MethodInvocation>, AuthorizationManager<MethodInvocationResult> {
override fun check(authentication: Supplier<Authentication>, invocation: MethodInvocation): AuthorizationDecision {
override fun check(authentication: Supplier<Authentication>, invocation: MethodInvocationResult): AuthorizationDecision {
Then, publish the method interceptor with a pointcut that corresponds to when you want that AuthorizationManager
to run.
For example, you could replace how @PreAuthorize
and @PostAuthorize
work like so:
Java
Kotlin
Xml
Advisor preAuthorize(MyAuthorizationManager manager) {
return AuthorizationManagerBeforeMethodInterceptor.preAuthorize(manager);
Advisor postAuthorize(MyAuthorizationManager manager) {
return AuthorizationManagerAfterMethodInterceptor.postAuthorize(manager);
fun preAuthorize(val manager: MyAuthorizationManager) : Advisor {
fun postAuthorize(val manager: MyAuthorizationManager) : Advisor {
<aop:config/>
<bean id="preAuthorize"
factory-method="preAuthorize">
<constructor-arg ref="myAuthorizationManager"/>
</bean>
class="org.springframework.security.authorization.method.AuthorizationManagerAfterMethodInterceptor"
factory-method="postAuthorize">
</bean>
You can place your interceptor in between Spring Security method interceptors using the order constants specified in |
Customizing Expression Handling
Or, third, you can customize how each SpEL expression is handled.
To do that, you can expose a custom MethodSecurityExpressionHandler
, like so:
Java
Kotlin
Xml
static MethodSecurityExpressionHandler methodSecurityExpressionHandler(RoleHierarchy roleHierarchy) {
DefaultMethodSecurityExpressionHandler handler = new DefaultMethodSecurityExpressionHandler();
handler.setRoleHierarchy(roleHierarchy);
return handler;
companion object {
fun methodSecurityExpressionHandler(val roleHierarchy: RoleHierarchy) : MethodSecurityExpressionHandler {
val handler = DefaultMethodSecurityExpressionHandler()
return handler
<sec:method-security>
<sec:expression-handler ref="myExpressionHandler"/>
</sec:method-security>
<bean id="myExpressionHandler"
class="org.springframework.security.messaging.access.expression.DefaultMessageSecurityExpressionHandler">
<property name="roleHierarchy" ref="roleHierarchy"/>
</bean>
We expose |
You can also subclass DefaultMessageSecurityExpressionHandler
to add your own custom authorization expressions beyond the defaults.
Working with AOT
Spring Security will scan all beans in the application context for methods that use @PreAuthorize
or @PostAuthorize
When it finds one, it will resolve any beans used inside the security expression and register the appropriate runtime hints for that bean.
If it finds a method that uses @AuthorizeReturnObject
, it will recursively search inside the method’s return type for @PreAuthorize
and @PostAuthorize
annotations and register them accordingly.
For example, consider the following Spring Boot application:
Java
Kotlin
@Service
public class AccountService { (1)
@PreAuthorize("@authz.decide()") (2)
@AuthorizeReturnObject (3)
public Account getAccountById(String accountId) {
public class Account {
private final String accountNumber;
@PreAuthorize("@accountAuthz.canViewAccountNumber()") (4)
public String getAccountNumber() {
return this.accountNumber;
@AuthorizeReturnObject (5)
public User getUser() {
return new User("John Doe");
public class User {
private final String fullName;
@PostAuthorize("@myOtherAuthz.decide()") (6)
public String getFullName() {
return this.fullName;
@Service
fun getAccountById(accountId: String): Account {
class Account(private val accountNumber: String) {
fun getAccountNumber(): String {
fun getUser(): User {
return User("John Doe")
class User(private val fullName: String) {
fun getFullName(): String {
1 | Spring Security finds the AccountService bean |
2 | Finding a method that uses @PreAuthorize , it will resolve any bean names used inside the expression, authz in that case, and register runtime hints for the bean class |
3 | Finding a method that uses @AuthorizeReturnObject , it will look into the method’s return type for any @PreAuthorize or @PostAuthorize |
4 | Then, it finds a @PreAuthorize with another bean name: accountAuthz ; the runtime hints are registered for the bean class as well |
5 | Finding another @AuthorizeReturnObject it will look again into the method’s return type |
6 | Now, a @PostAuthorize is found with yet another bean name used: myOtherAuthz ; the runtime hints are registered for the bean class as well |
There will be many times when Spring Security cannot determine the actual return type of the method ahead of time since it may be hidden in an erased generic type.
Consider the following service:
Java
Kotlin
@Service
public List<Account> getAllAccounts() {
@Service
fun getAllAccounts(): List<Account> {
In this case, the generic type is erased and so it isn’t apparent to Spring Security ahead-of-time that Account
needs to be visited in order to check for @PreAuthorize
and @PostAuthorize
To address this, you can publish a PrePostAuthorizeExpressionBeanHintsRegistrar
like so:
Java
Kotlin
static SecurityHintsRegistrar registerTheseToo() {
return new PrePostAuthorizeExpressionBeanHintsRegistrar(Account.class);
fun registerTheseToo(): SecurityHintsRegistrar {
return PrePostAuthorizeExpressionBeanHintsRegistrar(Account::class.java)
We expose |
Authorizing with AspectJ
Matching Methods with Custom Pointcuts
Being built on Spring AOP, you can declare patterns that are not related to annotations, similar to request-level authorization. This has the potential advantage of centralizing method-level authorization rules.
For example, you can use publish your own Advisor
or use <protect-pointcut>
to match AOP expressions to authorization rules for your service layer like so:
Java
Kotlin
Xml
import static org.springframework.security.authorization.AuthorityAuthorizationManager.hasRole
static Advisor protectServicePointcut() {
AspectJExpressionPointcut pattern = new AspectJExpressionPointcut()
pattern.setExpression("execution(* com.mycompany.*Service.*(..))")
return new AuthorizationManagerBeforeMethodInterceptor(pattern, hasRole("USER"))
companion object {
fun protectServicePointcut(): Advisor {
val pattern = AspectJExpressionPointcut()
<protect-pointcut expression="execution(* com.mycompany.*Service.*(..))" access="hasRole('USER')"/>
Integrate with AspectJ Byte-weaving
Performance can at times be enhanced by using AspectJ to weave Spring Security advice into the byte code of your beans.
After setting up AspectJ, you can quite simply state in the @EnableMethodSecurity
annotation or <method-security>
element that you are using AspectJ:
Java
Kotlin
Xml
@EnableMethodSecurity(mode=AdviceMode.ASPECTJ)
<sec:method-security mode="aspectj"/>
And the result will be that Spring Security will publish its advisors as AspectJ advice so that they can be woven in accordingly.
Specifying Order
As already noted, there is a Spring AOP method interceptor for each annotation, and each of these has a location in the Spring AOP advisor chain.
Namely, the @PreFilter
method interceptor’s order is 100, @PreAuthorize
's is 200, and so on.
The reason this is important to note is that there are other AOP-based annotations like @EnableTransactionManagement
that have an order of Integer.MAX_VALUE
In other words, they are located at the end of the advisor chain by default.
At times, it can be valuable to have other advice execute before Spring Security.
For example, if you have a method annotated with @Transactional
and @PostAuthorize
, you might want the transaction to still be open when @PostAuthorize
runs so that an AccessDeniedException
will cause a rollback.
To get @EnableTransactionManagement
to open a transaction before method authorization advice runs, you can set @EnableTransactionManagement
's order like so:
Java
Kotlin
Xml
@EnableTransactionManagement(order = 0)
<tx:annotation-driven ref="txManager" order="0"/>
Since the earliest method interceptor (@PreFilter
) is set to an order of 100, a setting of zero means that the transaction advice will run before all Spring Security advice.
Expressing Authorization with SpEL
You’ve already seen several examples using SpEL, so now let’s cover the API a bit more in depth.
Spring Security encapsulates all of its authorization fields and methods in a set of root objects.
The most generic root object is called SecurityExpressionRoot
and it forms the basis for MethodSecurityExpressionRoot
Spring Security supplies this root object to MethodSecurityEvaluationContext
when preparing to evaluate an authorization expression.
Using Authorization Expression Fields and Methods
The first thing this provides is an enhanced set of authorization fields and methods to your SpEL expressions. What follows is a quick overview of the most common methods:
permitAll
- The method requires no authorization to be invoked; note that in this case, theAuthentication
is never retrieved from the session -
denyAll
- The method is not allowed under any circumstances; note that in this case, theAuthentication
hasAuthority
- The method requires that theAuthentication
have aGrantedAuthority
that matches the given value -
hasRole
- A shortcut forhasAuthority
that prefixesROLE_
or whatever is configured as the default prefix -
hasAnyAuthority
that matches any of the given values -
hasAnyRole
- A shortcut forhasAnyAuthority
that prefixesROLE_
hasPermission
- A hook into yourPermissionEvaluator
instance for doing object-level authorization
And here is a brief look at the most common fields:
authentication
- TheAuthentication
instance associated with this method invocation -
principal
- TheAuthentication#getPrincipal
Having now learned the patterns, rules, and how they can be paired together, you should be able to understand what is going on in this more complex example:
Java
Kotlin
Xml
@Component
public class MyService {
@PreAuthorize("denyAll") (1)
MyResource myDeprecatedMethod(...);
@PreAuthorize("hasRole('ADMIN')") (2)
MyResource writeResource(...)
@PreAuthorize("hasAuthority('db') and hasRole('ADMIN')") (3)
MyResource deleteResource(...)
@PreAuthorize("principal.claims['aud'] == 'my-audience'") (4)
MyResource readResource(...);
@PreAuthorize("@authz.check(authentication, #root)")
MyResource shareResource(...);
@Component
open class MyService {
fun myDeprecatedMethod(...): MyResource
fun writeResource(...): MyResource
fun deleteResource(...): MyResource
fun readResource(...): MyResource
@PreAuthorize("@authz.check(#root)")
fun shareResource(...): MyResource
<protect-pointcut expression="execution(* com.mycompany.*Service.myDeprecatedMethod(..))" access="denyAll"/> (1)
<protect-pointcut expression="execution(* com.mycompany.*Service.writeResource(..))" access="hasRole('ADMIN')"/> (2)
<protect-pointcut expression="execution(* com.mycompany.*Service.deleteResource(..))" access="hasAuthority('db') and hasRole('ADMIN')"/> (3)
<protect-pointcut expression="execution(* com.mycompany.*Service.readResource(..))" access="principal.claims['aud'] == 'my-audience'"/> (4)
<protect-pointcut expression="execution(* com.mycompany.*Service.shareResource(..))" access="@authz.check(#root)"/> (5)
1 | This method may not be invoked by anyone for any reason |
2 | This method may only be invoked by Authentication s granted the ROLE_ADMIN authority |
3 | This method may only be invoked by Authentication s granted the db and ROLE_ADMIN authorities |
4 | This method may only be invoked by Princpal s with an aud claim equal to "my-audience" |
5 | This method may only be invoked if the bean authz 's check method returns true |
You can use a bean like |
Using Method Parameters
Additionally, Spring Security provides a mechanism for discovering method parameters so they can also be accessed in the SpEL expression as well.
For a complete reference, Spring Security uses DefaultSecurityParameterNameDiscoverer
to discover the parameter names.
By default, the following options are tried for a method.
If Spring Security’s
@P
annotation is present on a single argument to the method, the value is used. The following example uses the@P
annotation:-
Java
Kotlin
import org.springframework.security.access.method.P; ... @PreAuthorize("hasPermission(#c, 'write')") public void updateContact(@P("c") Contact contact);
import org.springframework.security.access.method.P ... @PreAuthorize("hasPermission(#c, 'write')") fun doSomething(@P("c") contact: Contact?)
The intention of this expression is to require that the current
Authentication
havewrite
permission specifically for thisContact
instance.Behind the scenes, this is implemented by using
AnnotationParameterNameDiscoverer
, which you can customize to support the value attribute of any specified annotation. -
If Spring Data’s
@Param
annotation is present on at least one parameter for the method, the value is used. The following example uses the@Param
annotation:-
Java
Kotlin
import org.springframework.data.repository.query.Param; ... @PreAuthorize("#n == authentication.name") Contact findContactByName(@Param("n") String name);
import org.springframework.data.repository.query.Param ... @PreAuthorize("#n == authentication.name") fun findContactByName(@Param("n") name: String?): Contact?
name
be equal toAuthentication#getName
for the invocation to be authorized.Behind the scenes, this is implemented by using
If you compile your code with the
-parameters
argument, the standard JDK reflection API is used to discover the parameter names. This works on both classes and interfaces. -
Finally, if you compile your code with debug symbols, the parameter names are discovered by using the debug symbols. This does not work for interfaces, since they do not have debug information about the parameter names. For interfaces, either annotations or the
-parameters
approach must be used.
Authorizing Arbitrary Objects
Spring Security also supports wrapping any object that is annotated its method security annotations.
The simplest way to achieve this is to mark any method that returns the object you wish to authorize with the @AuthorizeReturnObject
annotation.
For example, consider the following User
class:
Java
Kotlin
public class User {
private String name;
private String email;
public User(String name, String email) {
this.name = name;
this.email = email;
public String getName() {
return this.name;
@PreAuthorize("hasAuthority('user:read')")
public String getEmail() {
return this.email;
class User (val name:String, @get:PreAuthorize("hasAuthority('user:read')") val email:String)
Given an interface like this one:
Java
Kotlin
public class UserRepository {
Optional<User> findByName(String name) {
fun findByName(name:String?): Optional<User?>? {
Then any User
that is returned from findById
will be secured like other Spring Security-protected components:
Java
Kotlin
@Autowired
UserRepository users;
@Test
void getEmailWhenProxiedThenAuthorizes() {
Optional<User> securedUser = users.findByName("name");
assertThatExceptionOfType(AccessDeniedException.class).isThrownBy(() -> securedUser.get().getEmail());
import jdk.incubator.vector.VectorOperators.Test
import java.nio.file.AccessDeniedException
import java.util.*
@Autowired
var users:UserRepository? = null
@Test
fun getEmailWhenProxiedThenAuthorizes() {
val securedUser: Optional<User> = users.findByName("name")
assertThatExceptionOfType(AccessDeniedException::class.java).isThrownBy{securedUser.get().getEmail()}
Using @AuthorizeReturnObject
at the class level
can be placed at the class level. Note, though, that this means Spring Security will attempt to proxy any return object, including String
, Integer
and other types.
This is often not what you want to do.
If you want to use @AuthorizeReturnObject
on a class or interface whose methods return value types, like int
, String
, Double
or collections of those types, then you should also publish the appropriate AuthorizationAdvisorProxyFactory.TargetVisitor
as follows:
Java
Kotlin
static Customizer<AuthorizationAdvisorProxyFactory> skipValueTypes() {
return (factory) -> factory.setTargetVisitor(TargetVisitor.defaultsSkipValueTypes());
open fun skipValueTypes() = Customizer<AuthorizationAdvisorProxyFactory> {
it.setTargetVisitor(TargetVisitor.defaultsSkipValueTypes())
You can set your own |
Programmatically Proxying
You can also programmatically proxy a given object.
To achieve this, you can autowire the provided AuthorizationProxyFactory
instance, which is based on which method security interceptors you have configured.
If you are using @EnableMethodSecurity
, then this means that it will by default have the interceptors for @PreAuthorize
, @PostAuthorize
, @PreFilter
, and @PostFilter
You can proxy an instance of user in the following way:
Java
Kotlin
@Autowired
AuthorizationProxyFactory proxyFactory;
@Test
User user = new User("name", "email");
assertThat(user.getEmail()).isNotNull();
User securedUser = proxyFactory.proxy(user);
assertThatExceptionOfType(AccessDeniedException.class).isThrownBy(securedUser::getEmail);
@Autowired
var proxyFactory:AuthorizationProxyFactory? = null
@Test
val user: User = User("name", "email")
val securedUser: User = proxyFactory.proxy(user)
assertThatExceptionOfType(AccessDeniedException::class.java).isThrownBy(securedUser::getEmail)
Manual Construction
You can also define your own instance if you need something different from the Spring Security default.
For example, if you define an AuthorizationProxyFactory
instance like so:
Java
Kotlin
import org.springframework.security.authorization.method.AuthorizationAdvisorProxyFactory.TargetVisitor;
import static org.springframework.security.authorization.method.AuthorizationManagerBeforeMethodInterceptor.preAuthorize;
AuthorizationProxyFactory proxyFactory = AuthorizationAdvisorProxyFactory.withDefaults();
// and if needing to skip value types
proxyFactory.setTargetVisitor(TargetVisitor.defaultsSkipValueTypes());
import org.springframework.security.authorization.method.AuthorizationManagerBeforeMethodInterceptor.preAuthorize
val proxyFactory: AuthorizationProxyFactory = AuthorizationProxyFactory(preAuthorize())
Then you can wrap any instance of User
as follows:
Java
Kotlin
@Test
@Test
val proxyFactory: AuthorizationProxyFactory = AuthorizationAdvisorProxyFactory.withDefaults()
Proxying Collections
supports Java collections, streams, arrays, optionals, and iterators by proxying the element type and maps by proxying the value type.
This means that when proxying a List
of objects, the following also works:
Java
@Test
List<User> users = List.of(ada, albert, marie);
List<User> securedUsers = proxyFactory.proxy(users);
securedUsers.forEach((securedUser) ->
assertThatExceptionOfType(AccessDeniedException.class).isThrownBy(securedUser::getEmail));
Proxying Classes
In limited circumstances, it may be valuable to proxy a Class
itself, and AuthorizationProxyFactory
also supports this.
This is roughly the equivalent of calling ProxyFactory#getProxyClass
in Spring Framework’s support for creating proxies.
One place where this is handy is when you need to construct the proxy class ahead-of-time, like with Spring AOT.
Support for All Method Security Annotations
supports whichever method security annotations are enabled in your application.
It is based off of whatever AuthorizationAdvisor
classes are published as a bean.
Since @EnableMethodSecurity
publishes @PreAuthorize
, @PostAuthorize
, @PreFilter
, and @PostFilter
advisors by default, you will typically need to do nothing to activate the ability.
SpEL expressions that use |
Custom Advice
If you have security advice that you also want applied, you can publish your own AuthorizationAdvisor
like so:
Java
Kotlin
class SecurityConfig {
static AuthorizationAdvisor myAuthorizationAdvisor() {
return new AuthorizationAdvisor();
internal class SecurityConfig {
fun myAuthorizationAdvisor(): AuthorizationAdvisor {
return AuthorizationAdvisor()
And Spring Security will add that advisor into the set of advice that AuthorizationProxyFactory
adds when proxying an object.
Working with Jackson
One powerful use of this feature is to return a secured value from a controller like so:
Java
Kotlin
@RestController
public class UserController {
@Autowired
@GetMapping
User currentUser(@AuthenticationPrincipal User user) {
return this.proxyFactory.proxy(user);
@RestController
@Autowired
var proxyFactory: AuthorizationProxyFactory? = null
@GetMapping
fun currentUser(@AuthenticationPrincipal user:User?): User {
return proxyFactory.proxy(user)
You will need to add a MethodAuthorizationDeniedHandler
like this one:
Java
Kotlin
@Component
public class Null implements MethodAuthorizationDeniedHandler {
public Object handleDeniedInvocation(MethodInvocation methodInvocation, AuthorizationResult authorizationResult) {
return null;
@HandleAuthorizationDenied(handlerClass = Null.class)
public class User {
@Component
class Null : MethodAuthorizationDeniedHandler {
override fun handleDeniedInvocation(methodInvocation: MethodInvocation?, authorizationResult: AuthorizationResult?): Any? {
return null
open class User {
Then, you’ll see a different JSON serialization based on the authorization level of the user.
If they don’t have the user:read
authority, then they’ll see:
"name" : "name",
"email" : null
And if they do have that authority, they’ll see:
"name" : "name",
"email" : "email"
You can also add the Spring Boot property |
Working with AOT
Spring Security will scan all beans in the application context for methods that use @AuthorizeReturnObject
When it finds one, it will create and register the appropriate proxy class ahead of time.
It will also recursively search for other nested objects that also use @AuthorizeReturnObject
Java
Kotlin
@SpringBootApplication
public class MyApplication {
@RestController
public static class MyController { (1)
@GetMapping
Message getMessage() { (2)
return new Message(someUser, "hello!");
public static class Message { (3)
User to;
String text;
public User getTo() { (4)
return this.to;
public static class User { (5)
SpringApplication.run(MyApplication.class);
open class MyApplication {
@RestController
open class MyController { (1)
@GetMapping
fun getMessage():Message { (2)
return Message(someUser, "hello!")
open class Message { (3)
val to: User
val test: String
fun getTo(): User { (4)
return this.to
open class User { (5)
fun main(args: Array<String>) {
1 | - First, Spring Security finds the MyController bean |
2 | - Finding a method that uses @AuthorizeReturnObject , it proxies Message , the return value, and registers that proxy class to RuntimeHints |
3 | - Then, it traverses Message to see if it uses @AuthorizeReturnObject |
4 | - Finding a method that uses @AuthorizeReturnObject , it proxies User , the return value, and registers that proxy class to RuntimeHints |
5 | - Finally, it traverses User to see if it uses @AuthorizeReturnObject ; finding nothing, the algorithm completes |
There will be many times when Spring Security cannot determine the proxy class ahead of time since it may be hidden in an erased generic type.
Consider the following change to MyController
Java
Kotlin
@RestController
@GetMapping
List<Message> getMessages() {
return List.of(new Message(someUser, "hello!"));
@RestController
@GetMapping
fun getMessages(): Array<Message> = arrayOf(Message(someUser, "hello!"))
In this case, the generic type is erased and so it isn’t apparent to Spring Security ahead-of-time that Message
will need to be proxied at runtime.
To address this, you can publish AuthorizeProxyFactoryHintsRegistrar
like so:
Java
Kotlin
static SecurityHintsRegsitrar registerTheseToo(AuthorizationProxyFactory proxyFactory) {
return new AuthorizeReturnObjectHintsRegistrar(proxyFactory, Message.class);
fun registerTheseToo(proxyFactory: AuthorizationProxyFactory?): SecurityHintsRegistrar {
return AuthorizeReturnObjectHintsRegistrar(proxyFactory, Message::class.java)
Spring Security will register that class and then traverse its type as before.
Providing Fallback Values When Authorization is Denied
There are some scenarios where you may not wish to throw an AuthorizationDeniedException
when a method is invoked without the required permissions.
Instead, you might wish to return a post-processed result, like a masked result, or a default value in cases where authorization denied happened before invoking the method.
Spring Security provides support for handling authorization denied on method invocation by using the @HandleAuthorizationDenied
The handler works for denied authorizations that happened in the @PreAuthorize
and @PostAuthorize
annotations as well as AuthorizationDeniedException
thrown from the method invocation itself.
Let’s consider the example from the previous section, but instead of creating the AccessDeniedExceptionInterceptor
to transform an AccessDeniedException
to a null
return value, we will use the handlerClass
attribute from @HandleAuthorizationDenied
Java
Kotlin
public class NullMethodAuthorizationDeniedHandler implements MethodAuthorizationDeniedHandler { (1)
return null;
public class SecurityConfig {
@Bean (2)
public NullMethodAuthorizationDeniedHandler nullMethodAuthorizationDeniedHandler() {
return new NullMethodAuthorizationDeniedHandler();
public class User {
@PreAuthorize(value = "hasAuthority('user:read')")
@HandleAuthorizationDenied(handlerClass = NullMethodAuthorizationDeniedHandler.class)
return this.email;
class NullMethodAuthorizationDeniedHandler : MethodAuthorizationDeniedHandler { (1)
override fun handleDeniedInvocation(methodInvocation: MethodInvocation, authorizationResult: AuthorizationResult): Any {
return null
@Bean (2)
fun nullMethodAuthorizationDeniedHandler(): NullMethodAuthorizationDeniedHandler {
return MaskMethodAuthorizationDeniedHandler()
class User (val name:String, @PreAuthorize(value = "hasAuthority('user:read')") @HandleAuthorizationDenied(handlerClass = NullMethodAuthorizationDeniedHandler::class) val email:String) (3)
1 | Create an implementation of MethodAuthorizationDeniedHandler that returns a null value |
2 | Register the NullMethodAuthorizationDeniedHandler as a bean |
3 | Annotate the method with @HandleAuthorizationDenied and pass the NullMethodAuthorizationDeniedHandler to the handlerClass attribute |
And then you can verify that a null
value is returned instead of the AccessDeniedException
You can also annotate your class with |
Java
Kotlin
@Autowired
@Test
void getEmailWhenProxiedThenNullEmail() {
assertThat(securedUser.get().getEmail()).isNull();
@Autowired
@Test
fun getEmailWhenProxiedThenNullEmail() {
Using the Denied Result From the Method Invocation
There are some scenarios where you might want to return a secure result derived from the denied result. For example, if a user is not authorized to see email addresses, you might want to apply some masking on the original email address, i.e. [email protected] would become use******@example.com.
For those scenarios, you can override the handleDeniedInvocationResult
from the MethodAuthorizationDeniedHandler
, which has the MethodInvocationResult
as an argument.
Let’s continue with the previous example, but instead of returning null
, we will return a masked value of the email:
Java
Kotlin
public class EmailMaskingMethodAuthorizationDeniedHandler implements MethodAuthorizationDeniedHandler { (1)
return "***";
public Object handleDeniedInvocationResult(MethodInvocationResult methodInvocationResult, AuthorizationResult authorizationResult) {
String email = (String) methodInvocationResult.getResult();
return email.replaceAll("(^[^@]{3}|(?!^)\\G)[^@]", "$1*");
@Bean (2)
public EmailMaskingMethodAuthorizationDeniedHandler emailMaskingMethodAuthorizationDeniedHandler() {
return new EmailMaskingMethodAuthorizationDeniedHandler();
public class User {
@PostAuthorize(value = "hasAuthority('user:read')")
@HandleAuthorizationDenied(handlerClass = EmailMaskingMethodAuthorizationDeniedHandler.class)
return this.email;
class EmailMaskingMethodAuthorizationDeniedHandler : MethodAuthorizationDeniedHandler {
return "***"
override fun handleDeniedInvocationResult(methodInvocationResult: MethodInvocationResult, authorizationResult: AuthorizationResult): Any {
val email = methodInvocationResult.result as String
return email.replace("(^[^@]{3}|(?!^)\\G)[^@]".toRegex(), "$1*")
fun emailMaskingMethodAuthorizationDeniedHandler(): EmailMaskingMethodAuthorizationDeniedHandler {
return EmailMaskingMethodAuthorizationDeniedHandler()
class User (val name:String, @PostAuthorize(value = "hasAuthority('user:read')") @HandleAuthorizationDenied(handlerClass = EmailMaskingMethodAuthorizationDeniedHandler::class) val email:String) (3)
1 | Create an implementation of MethodAuthorizationDeniedHandler that returns a masked value of the unauthorized result value |
2 | Register the EmailMaskingMethodAuthorizationDeniedHandler as a bean |
3 | Annotate the method with @HandleAuthorizationDenied and pass the EmailMaskingMethodAuthorizationDeniedHandler to the handlerClass attribute |
And then you can verify that a masked email is returned instead of an AccessDeniedException
Since you have access to the original denied value, make sure that you correctly handle it and do not return it to the caller. |
Java
Kotlin
@Autowired
@Test
void getEmailWhenProxiedThenMaskedEmail() {
// email is [email protected]
assertThat(securedUser.get().getEmail()).isEqualTo("use******@example.com");
@Autowired
@Test
fun getEmailWhenProxiedThenMaskedEmail() {
When implementing the MethodAuthorizationDeniedHandler
you have a few options on what type you can return:
A
null
value. -
A non-null value, respecting the method’s return type.
Throw an exception, usually an instance of
. This is the default behavior. -
A
Mono
type for reactive applications.
Note that since the handler must be registered as beans in your application context, you can inject dependencies into them if you need a more complex logic.
In addition to that, you have available the MethodInvocation
or the MethodInvocationResult
, as well as the AuthorizationResult
for more details related to the authorization decision.
Deciding What to Return Based on Available Parameters
Consider a scenario where there might be multiple mask values for different methods, it would be not so productive if we had to create a handler for each of those methods, although it is perfectly fine to do that.
In such cases, we can use the information passed via parameters to decide what to do.
For example, we can create a custom @Mask
annotation and a handler that detects that annotation to decide what mask value to return:
Java
Kotlin
import org.springframework.core.annotation.AnnotationUtils;
public @interface Mask {
String value();
public class MaskAnnotationDeniedHandler implements MethodAuthorizationDeniedHandler {
Mask mask = AnnotationUtils.getAnnotation(methodInvocation.getMethod(), Mask.class);
return mask.value();
public MaskAnnotationDeniedHandler maskAnnotationDeniedHandler() {
return new MaskAnnotationDeniedHandler();
@Component
@HandleAuthorizationDenied(handlerClass = MaskAnnotationDeniedHandler.class)
@Mask("***")
public String foo() {
return "foo";
@Mask("???")
public String bar() {
return "bar";
@Target(AnnotationTarget.FUNCTION, AnnotationTarget.CLASS)
@Retention(AnnotationRetention.RUNTIME)
annotation class Mask(val value: String)
class MaskAnnotationDeniedHandler : MethodAuthorizationDeniedHandler {
val mask = AnnotationUtils.getAnnotation(methodInvocation.method, Mask::class.java)
return mask.value
fun maskAnnotationDeniedHandler(): MaskAnnotationDeniedHandler {
return MaskAnnotationDeniedHandler()
@Component
class MyService {
@HandleAuthorizationDenied(handlerClass = MaskAnnotationDeniedHandler::class)
@Mask("***")
fun foo(): String {
return "foo"
@Mask("???")
fun bar(): String {
return "bar"
Now the return values when access is denied will be decided based on the @Mask
annotation:
Java
Kotlin
@Autowired
MyService myService;
@Test
void fooWhenDeniedThenReturnStars() {
String value = this.myService.foo();
assertThat(value).isEqualTo("***");
@Test
void barWhenDeniedThenReturnQuestionMarks() {
assertThat(value).isEqualTo("???");
@Autowired
var myService: MyService
@Test
fun fooWhenDeniedThenReturnStars() {
val value: String = myService.foo()
@Test
fun barWhenDeniedThenReturnQuestionMarks() {
Combining with Meta Annotation Support
You can also combine the @HandleAuthorizationDenied
with other annotations in order to reduce and simplify the annotations in a method.
Let’s consider the example from the previous section and merge @HandleAuthorizationDenied
with @Mask
Java
Kotlin
String value();
@Mask("***")
public String myMethod() {
@Mask("***")
fun myMethod(): String {
Now you do not have to remember to add both annotations when you need a mask behavior in your method. Make sure to read the Meta Annotations Support section for more details on the usage.
Migrating from @EnableGlobalMethodSecurity
If you are using @EnableGlobalMethodSecurity
, you should migrate to @EnableMethodSecurity
Replace global method security with method security
and <global-method-security>
are deprecated in favor of @EnableMethodSecurity
and <method-security>
, respectively.
The new annotation and XML element activate Spring’s pre-post annotations by default and use AuthorizationManager
internally.
This means that the following two listings are functionally equivalent:
Java
Kotlin
Xml
@EnableGlobalMethodSecurity(prePostEnabled = true)
<global-method-security pre-post-enabled="true"/>
and:
Java
Kotlin
Xml
<method-security/>
For applications not using the pre-post annotations, make sure to turn it off to avoid activating unwanted behavior.
For example, a listing like:
Java
Kotlin
Xml
@EnableGlobalMethodSecurity(securedEnabled = true)
<global-method-security secured-enabled="true"/>
should change to:
Java
Kotlin
Xml
@EnableMethodSecurity(securedEnabled = true, prePostEnabled = false)
<method-security secured-enabled="true" pre-post-enabled="false"/>
Use a Custom @Bean
instead of subclassing DefaultMethodSecurityExpressionHandler
As a performance optimization, a new method was introduced to MethodSecurityExpressionHandler
that takes a Supplier<Authentication>
instead of an Authentication
This allows Spring Security to defer the lookup of the Authentication
, and is taken advantage of automatically when you use @EnableMethodSecurity
instead of @EnableGlobalMethodSecurity
However, let’s say that your code extends DefaultMethodSecurityExpressionHandler
and overrides createSecurityExpressionRoot(Authentication, MethodInvocation)
to return a custom SecurityExpressionRoot
instance.
This will no longer work because the arrangement that @EnableMethodSecurity
sets up calls createEvaluationContext(Supplier<Authentication>, MethodInvocation)
instead.
Happily, such a level of customization is often unnecessary. Instead, you can create a custom bean with the authorization methods that you need.
For example, let’s say you are wanting a custom evaluation of @PostAuthorize("hasAuthority('ADMIN')")
You can create a custom @Bean
like this one:
Java
Kotlin
class MyAuthorizer {
boolean isAdmin(MethodSecurityExpressionOperations root) {
boolean decision = root.hasAuthority("ADMIN");
// custom work ...
return decision;
fun isAdmin(val root: MethodSecurityExpressionOperations): boolean {
val decision = root.hasAuthority("ADMIN");
// custom work ...
return decision;
and then refer to it in the annotation like so:
Java
Kotlin
@PreAuthorize("@authz.isAdmin(#root)")
I’d still prefer to subclass DefaultMethodSecurityExpressionHandler
If you must continue subclassing DefaultMethodSecurityExpressionHandler
, you can still do so.
Instead, override the createEvaluationContext(Supplier<Authentication>, MethodInvocation)
method like so:
Java
Kotlin
@Component
class MyExpressionHandler extends DefaultMethodSecurityExpressionHandler {
public EvaluationContext createEvaluationContext(Supplier<Authentication> authentication, MethodInvocation mi) {
StandardEvaluationContext context = (StandardEvaluationContext) super.createEvaluationContext(authentication, mi);
MethodSecurityExpressionOperations delegate = (MethodSecurityExpressionOperations) context.getRootObject().getValue();
MySecurityExpressionRoot root = new MySecurityExpressionRoot(delegate);
context.setRootObject(root);
return context;
@Component
class MyExpressionHandler: DefaultMethodSecurityExpressionHandler {
override fun createEvaluationContext(val authentication: Supplier<Authentication>,
val mi: MethodInvocation): EvaluationContext {
val context = super.createEvaluationContext(authentication, mi) as StandardEvaluationContext
val delegate = context.getRootObject().getValue() as MethodSecurityExpressionOperations
val root = MySecurityExpressionRoot(delegate)
return context
Further Reading
Now that you have secured your application’s requests, please secure its requests if you haven’t already. You can also read further on testing your application or on integrating Spring Security with other aspects of you application like the data layer or tracing and metrics.
