Among its other logout mechanisms, Spring Security ships with support for RP- and AP-initiated SAML 2.0 Single Logout.
Briefly, there are two use cases Spring Security supports:
RP-Initiated - Your application has an endpoint that, when POSTed to, will logout the user and send a
saml2:LogoutRequest
to the asserting party. Thereafter, the asserting party will send back asaml2:LogoutResponse
and allow your application to respond -
AP-Initiated - Your application has an endpoint that will receive a
saml2:LogoutRequest
from the asserting party. Your application will complete its logout at that point and then send asaml2:LogoutResponse
In the AP-Initiated scenario, any local redirection that your application would do post-logout is rendered moot.
Once your application sends a saml2:LogoutResponse , it no longer has control of the browser.
Minimal Configuration for Single Logout
To use Spring Security’s SAML 2.0 Single Logout feature, you will need the following things:
First, the asserting party must support SAML 2.0 Single Logout
Second, the asserting party should be configured to sign and POST
saml2:LogoutRequest
s andsaml2:LogoutResponse
s your application’s/logout/saml2/slo
endpoint -
Third, your application must have a PKCS#8 private key and X.509 certificate for signing
saml2:LogoutRequest
s
You can achieve this in Spring Boot in the following way:
spring:
security:
saml2:
relyingparty:
registration:
metadata:
signing.credentials: (3)
- private-key-location: classpath:credentials/rp-private.key
certificate-location: classpath:credentials/rp-certificate.crt
singlelogout.url: "{baseUrl}/logout/saml2/slo" (2)
assertingparty:
metadata-uri: https://ap.example.com/metadata (1)
1 | - The metadata URI of the IDP, which will indicate to your application its support of SLO |
2 | - The SLO endpoint in your application |
3 | - The signing credentials to sign <saml2:LogoutRequest> s and <saml2:LogoutResponse> s |
An asserting party supports Single Logout if their metadata includes the `<SingleLogoutService>` element in their metadata.
And that’s it!
Spring Security’s logout support offers a number of configuration points. Consider the following use cases:
Understand how the above minimal configuration works
Get a picture of the overall architecture
Allow users to logout out of the app only
Customize logout endpoints
Storing
<saml2:LogoutRequests>
somewhere other than the session
Startup Expectations
When these properties are used, in addition to login, SAML 2.0 Service Provider will automatically configure itself facilitate logout by way of <saml2:LogoutRequest>
s using either RP- or AP-initiated logout.
It achieves this through a deterministic startup process:
Query the Identity Server Metadata endpoint for the
element -
Scan the metadata and cache any public signature verification keys
Prepare the appropriate endpoints
A consequence of this process is that the identity server must be up and receiving requests in order for Service Provider to successfully start up.
If the identity server is down when Service Provider queries it (given appropriate timeouts), then startup will fail. |
Runtime Expectations
Given the above configuration any logged-in user can send a POST /logout
to your application to perform RP-initiated SLO.
Your application will then do the following:
Logout the user and invalidate the session
Produce a
and POST it to the associated asserting party’s SLO endpoint -
Then, if the asserting party responds with a
, the application with verify it and redirect to the configured success endpoint
Also, your application can participate in an AP-initiated logout when the asserting party sends a <saml2:LogoutRequest>
to /logout/saml2/slo
When this happens, your application will do the following:
Verify the
Produce a
and POST it back to the asserting party’s SLO endpoint
Minimal Configuration Sans Boot
Instead of Boot properties, you can also achieve the same outcome by publishing the beans directly like so:
Java
Kotlin
public class SecurityConfig {
@Value("${private.key}") RSAPrivateKey key;
@Value("${public.certificate}") X509Certificate certificate;
RelyingPartyRegistrationRepository registrations() {
Saml2X509Credential credential = Saml2X509Credential.signing(key, certificate);
RelyingPartyRegistration registration = RelyingPartyRegistrations
.fromMetadataLocation("https://ap.example.org/metadata") (1)
.registrationId("metadata")
.singleLogoutServiceLocation("{baseUrl}/logout/saml2/slo") (2)
.signingX509Credentials((signing) -> signing.add(credential)) (3)
return new InMemoryRelyingPartyRegistrationRepository(registration);
SecurityFilterChain web(HttpSecurity http) throws Exception {
http
.authorizeHttpRequests((authorize) -> authorize
.anyRequest().authenticated()
.saml2Login(withDefaults())
.saml2Logout(withDefaults()); (4)
return http.build();
class SecurityConfig(@Value("${private.key}") val key: RSAPrivateKey,
@Value("${public.certificate}") val certificate: X509Certificate) {
fun registrations(): RelyingPartyRegistrationRepository {
val credential = Saml2X509Credential.signing(key, certificate)
val registration = RelyingPartyRegistrations
.signingX509Credentials({ signing: List<Saml2X509Credential> -> signing.add(credential) }) (3)
.build()
return InMemoryRelyingPartyRegistrationRepository(registration)
fun web(http: HttpSecurity): SecurityFilterChain {
http {
authorizeHttpRequests {
anyRequest = authenticated
saml2Login {
saml2Logout { (4)
return http.build()
3 | - The signing credentials to sign <saml2:LogoutRequest> s and <saml2:LogoutResponse> s, which you can also add to multiple relying parties |
4 | - Second, indicate that your application wants to use SAML SLO to logout the end user |
Adding saml2Logout adds the capability for logout to your service provider as a whole.
Because it is an optional capability, you need to enable it for each individual RelyingPartyRegistration .
You do this by setting the RelyingPartyRegistration.Builder#singleLogoutServiceLocation property as seen above.
How Saml 2.0 Logout Works
Next, let’s see the architectural components that Spring Security uses to support SAML 2.0 Logout in servlet-based applications, like the one we just saw.
For RP-initiated logout:
Spring Security executes its logout flow, calling its
LogoutHandler
s to invalidate the session and perform other cleanup.
It then invokes the Saml2RelyingPartyInitiatedLogoutSuccessHandler
The logout success handler uses an instance of
Saml2LogoutRequestResolver
to create, sign, and serialize a <saml2:LogoutRequest>
It uses the keys and configuration from the RelyingPartyRegistration
that is associated with the current Saml2AuthenticatedPrincipal
Then, it redirect-POSTs the <saml2:LogoutRequest>
to the asserting party SLO endpoint
The browser hands control over to the asserting party.
If the asserting party redirects back (which it may not), then the application proceeds to step .
The
Saml2LogoutResponseFilter
deserializes, verifies, and processes the <saml2:LogoutResponse>
with its Saml2LogoutResponseValidator
If valid, then it completes the local logout flow by redirecting to
/login?logout
, or whatever has been configured.
If invalid, then it responds with a 400.
For AP-initiated logout:
The
Saml2LogoutRequestFilter
deserializes, verifies, and processes the <saml2:LogoutRequest>
with its Saml2LogoutRequestValidator
If valid, then the filter calls the configured
LogoutHandler
s, invalidating the session and performing other cleanup.
It uses a
Saml2LogoutResponseResolver
to create, sign and serialize a <saml2:LogoutResponse>
derived from the endpoint or from the contents of the <saml2:LogoutRequest>
Then, it redirect-POSTs the <saml2:LogoutResponse>
to the asserting party SLO endpoint.
Configuring Logout Endpoints
There are three behaviors that can be triggered by different endpoints:
RP-initiated logout, which allows an authenticated user to
POST
and trigger the logout process by sending the asserting party a<saml2:LogoutRequest>
AP-initiated logout, which allows an asserting party to send a
to the application -
AP logout response, which allows an asserting party to send a
in response to the RP-initiated<saml2:LogoutRequest>
The first is triggered by performing normal POST /logout
when the principal is of type Saml2AuthenticatedPrincipal
The second is triggered by POSTing to the /logout/saml2/slo
endpoint with a SAMLRequest
signed by the asserting party.
The third is triggered by POSTing to the /logout/saml2/slo
endpoint with a SAMLResponse
Because the user is already logged in or the original Logout Request is known, the registrationId
is already known.
For this reason, {registrationId}
is not part of these URLs by default.
This URL is customizable in the DSL.
For example, if you are migrating your existing relying party over to Spring Security, your asserting party may already be pointing to GET /SLOService.saml2
To reduce changes in configuration for the asserting party, you can configure the filter in the DSL like so:
Java
Kotlin
http
.saml2Logout((saml2) -> saml2
.logoutRequest((request) -> request.logoutUrl("/SLOService.saml2"))
.logoutResponse((response) -> response.logoutUrl("/SLOService.saml2"))
http {
saml2Logout {
logoutRequest {
logoutUrl = "/SLOService.saml2"
logoutResponse {
You should also configure these endpoints in your RelyingPartyRegistration
Also, you can customize the endpoint for triggering logout locally like so:
Java
Kotlin
http
.saml2Logout((saml2) -> saml2.logoutUrl("/saml2/logout"));
http {
saml2Logout {
logoutUrl = "/saml2/logout"
Separating Local Logout from SAML 2.0 Logout
In some cases, you may want to expose one logout endpoint for local logout and another for RP-initiated SLO. Like is the case with other logout mechanisms, you can register more than one, so long as they each have a different endpoint.
So, for example, you can wire the DSL like so:
Java
Kotlin
http
.logout((logout) -> logout.logoutUrl("/logout"))
http {
logout {
logoutUrl = "/logout"
saml2Logout {
and now if a client sends a POST /logout
, the session will be cleared, but there won’t be a <saml2:LogoutRequest>
sent to the asserting party.
But, if the client sends a POST /saml2/logout
, then the application will initiate SAML 2.0 SLO as normal.
Customizing <saml2:LogoutRequest>
Resolution
It’s common to need to set other values in the <saml2:LogoutRequest>
than the defaults that Spring Security provides.
By default, Spring Security will issue a <saml2:LogoutRequest>
and supply:
The
Destination
attribute - fromRelyingPartyRegistration#getAssertingPartyDetails#getSingleLogoutServiceLocation
The
ID
attribute - a GUID -
The
<Issuer>
element - fromRelyingPartyRegistration#getEntityId
The
<NameID>
element - fromAuthentication#getName
To add other values, you can use delegation, like so:
Java
Kotlin
Saml2LogoutRequestResolver logoutRequestResolver(RelyingPartyRegistrationRepository registrations) {
OpenSaml4LogoutRequestResolver logoutRequestResolver =
new OpenSaml4LogoutRequestResolver(registrations);
logoutRequestResolver.setParametersConsumer((parameters) -> {
String name = ((Saml2AuthenticatedPrincipal) parameters.getAuthentication().getPrincipal()).getFirstAttribute("CustomAttribute");
String format = "urn:oasis:names:tc:SAML:2.0:nameid-format:transient";
LogoutRequest logoutRequest = parameters.getLogoutRequest();
NameID nameId = logoutRequest.getNameID();
nameId.setValue(name);
nameId.setFormat(format);
return logoutRequestResolver;
open fun logoutRequestResolver(registrations:RelyingPartyRegistrationRepository?): Saml2LogoutRequestResolver {
val logoutRequestResolver = OpenSaml4LogoutRequestResolver(registrations)
logoutRequestResolver.setParametersConsumer { parameters: LogoutRequestParameters ->
val name: String = (parameters.getAuthentication().getPrincipal() as Saml2AuthenticatedPrincipal).getFirstAttribute("CustomAttribute")
val format = "urn:oasis:names:tc:SAML:2.0:nameid-format:transient"
val logoutRequest: LogoutRequest = parameters.getLogoutRequest()
val nameId: NameID = logoutRequest.getNameID()
Then, you can supply your custom Saml2LogoutRequestResolver
in the DSL as follows:
Java
Kotlin
http
.logoutRequestResolver(this.logoutRequestResolver)
http {
saml2Logout {
logoutRequest {
logoutRequestResolver = this.logoutRequestResolver
Customizing <saml2:LogoutResponse>
Resolution
It’s common to need to set other values in the <saml2:LogoutResponse>
By default, Spring Security will issue a <saml2:LogoutResponse>
and supply:
The
Destination
attribute - fromRelyingPartyRegistration#getAssertingPartyDetails#getSingleLogoutServiceResponseLocation
The
ID
The
<Issuer>
The
<Status>
element -SUCCESS
Java
Kotlin
public Saml2LogoutResponseResolver logoutResponseResolver(RelyingPartyRegistrationRepository registrations) {
OpenSaml4LogoutResponseResolver logoutRequestResolver =
new OpenSaml4LogoutResponseResolver(registrations);
if (checkOtherPrevailingConditions(parameters.getRequest())) {
parameters.getLogoutRequest().getStatus().getStatusCode().setCode(StatusCode.PARTIAL_LOGOUT);
open fun logoutResponseResolver(registrations: RelyingPartyRegistrationRepository?): Saml2LogoutResponseResolver {
val logoutRequestResolver = OpenSaml4LogoutResponseResolver(registrations)
logoutRequestResolver.setParametersConsumer { LogoutResponseParameters parameters ->
Then, you can supply your custom Saml2LogoutResponseResolver
Java
Kotlin
http
http {
saml2Logout {
logoutRequest {
Authentication
To customize validation, you can implement your own Saml2LogoutRequestValidator
At this point, the validation is minimal, so you may be able to first delegate to the default Saml2LogoutRequestValidator
like so:
Java
Kotlin
@Component
public class MyOpenSamlLogoutRequestValidator implements Saml2LogoutRequestValidator {
private final Saml2LogoutRequestValidator delegate = new OpenSamlLogoutRequestValidator();
public Saml2LogoutRequestValidator logout(Saml2LogoutRequestValidatorParameters parameters) {
// verify signature, issuer, destination, and principal name
Saml2LogoutValidatorResult result = delegate.authenticate(authentication);
LogoutRequest logoutRequest = // ... parse using OpenSAML
// perform custom validation
@Component
open class MyOpenSamlLogoutRequestValidator: Saml2LogoutRequestValidator {
private val delegate = OpenSamlLogoutRequestValidator()
fun logout(parameters: Saml2LogoutRequestValidatorParameters): Saml2LogoutRequestValidator {
val result = delegate.authenticate(authentication)
val logoutRequest: LogoutRequest = // ... parse using OpenSAML
Then, you can supply your custom Saml2LogoutRequestValidator
Java
Kotlin
http
.logoutRequestValidator(myOpenSamlLogoutRequestValidator)
http {
saml2Logout {
logoutRequest {
logoutRequestValidator = myOpenSamlLogoutRequestValidator
Authentication
To customize validation, you can implement your own Saml2LogoutResponseValidator
At this point, the validation is minimal, so you may be able to first delegate to the default Saml2LogoutResponseValidator
like so:
Java
Kotlin
@Component
public class MyOpenSamlLogoutResponseValidator implements Saml2LogoutResponseValidator {
private final Saml2LogoutResponseValidator delegate = new OpenSamlLogoutResponseValidator();
public Saml2LogoutValidatorResult logout(Saml2LogoutResponseValidatorParameters parameters) {
// verify signature, issuer, destination, and status
Saml2LogoutValidatorResult result = delegate.authenticate(parameters);
LogoutResponse logoutResponse = // ... parse using OpenSAML
@Component
open class MyOpenSamlLogoutResponseValidator: Saml2LogoutResponseValidator {
private val delegate = OpenSamlLogoutResponseValidator()
fun logout(parameters: Saml2LogoutResponseValidatorParameters): Saml2LogoutResponseValidator {
val logoutResponse: LogoutResponse = // ... parse using OpenSAML
Then, you can supply your custom Saml2LogoutResponseValidator
Java
Kotlin
http
.logoutResponseAuthenticator(myOpenSamlLogoutResponseAuthenticator)
http {
saml2Logout {
logoutResponse {
logoutResponseValidator = myOpenSamlLogoutResponseValidator
storage
When your application sends a <saml2:LogoutRequest>
, the value is stored in the session so that the RelayState
parameter and the InResponseTo
attribute in the <saml2:LogoutResponse>
can be verified.
If you want to store logout requests in some place other than the session, you can supply your custom implementation in the DSL, like so:
Java
Kotlin
http
.logoutRequestRepository(myCustomLogoutRequestRepository)
http {
saml2Logout {
logoutRequest {
logoutRequestRepository = myCustomLogoutRequestRepository
Further Logout-Related References
Logging Out in section CSRF Caveats
