Spring Security provides Spring Data integration that allows referring to the current user within your queries. It is not only useful but necessary to include the user in the queries to support paged results since filtering the results afterwards would not scale.spring-doc.cn
Spring Data & Spring Security Configuration
To use this support, add org.springframework.security:spring-security-data dependency and provide a bean of type SecurityEvaluationContextExtension. In Java Configuration, this would look like:spring-doc.cn
public SecurityEvaluationContextExtension securityEvaluationContextExtension() {
	return new SecurityEvaluationContextExtension();
fun securityEvaluationContextExtension(): SecurityEvaluationContextExtension {
    return SecurityEvaluationContextExtension()
In XML Configuration, this would look like:spring-doc.cn
<bean class="org.springframework.security.data.repository.query.SecurityEvaluationContextExtension"/>
Security Expressions within @Query
Now Spring Security can be used within your queries. For example:spring-doc.cn
@Repository
public interface MessageRepository extends PagingAndSortingRepository<Message,Long> {
	@Query("select m from Message m where m.to.id = ?#{ principal?.id }")
	Page<Message> findInbox(Pageable pageable);
@Repository
interface MessageRepository : PagingAndSortingRepository<Message?, Long?> {
    fun findInbox(pageable: Pageable?): Page<Message?>?
This checks to see if the Authentication.getPrincipal().getId() is equal to the recipient of the Message. Note that this example assumes you have customized the principal to be an Object that has an id property. By exposing the SecurityEvaluationContextExtension bean, all of the Common Security Expressions are available within the Query.spring-doc.cn
